Body protection, exoskeleton tubing size. - Page 3 - JeepForum.com
post #31 of 47 Old 06-02-2013, 10:32 PM Thread Starter
Trick440
1994 ZJ
Originally Posted by WhiteOut View Post
With that kind of setup you're still going to run the possibility of dents and it won't keep tree limbs and branches off the body.
I understand this. This is only going to stop 90% of the dents, thats a percentage I can live with. Scratches I have a ton already.
Trick440 is offline
post #32 of 47 Old 06-02-2013, 10:33 PM
WhiteOut
WhiteOut's Avatar
Conduit is not DOM. DOM has more strength under load before failure or deformation.
As for your comments, weren't you asking about identifying lifts and how to set up a 5.5" lift 6 months ago? Then paying someone $60 to adjust your drag link?
WhiteOut is offline
post #33 of 47 Old 06-02-2013, 10:41 PM
Bama_WJ
If you would have provided that example picture in the first post, we probably would have had a better idea of what you were talking about. Either way, sounds like you've already made up your mind.
I suggest taking this question over to Pirate and seeing what their opinion is.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #34 of 47 Old 06-02-2013, 10:46 PM Thread Starter
Trick440
1994 ZJ
I didn't say dom, I said steel tubing. Dom is more strength under load because its one piece with no welds, other tubing is joined by a weld.
Yup I asked about lifts, not sure about the drag link, never paid anyone. Not sure how thats relivent either, unless your trying to imply I couldn't possibly know anything because 6 months ago I asked a question. I read a lot and tend to have great ideas frequently. This is also a new hobby, but just like every hobby before it, I go all in and become proficient quickly. I'm kinda a baller like that.
Trick440 is offline
post #35 of 47 Old 06-02-2013, 10:48 PM
WhiteOut
WhiteOut's Avatar
Actually, do this. No one on this site wheels, certainly no one in this thread.
WhiteOut is offline
post #36 of 47 Old 06-02-2013, 10:54 PM Thread Starter
Trick440
1994 ZJ
I'm staying here you guise make me feel smart.
Edit: Jkjk, i'm stopping at this point i'm just trolling for my own amusement.
Trick440 is offline
post #37 of 47 Old 06-03-2013, 08:15 AM
sandman92k
any time your in california, send me a PM i would love to take you wheeling and show you some very interesting trails, just make sure you bring a trailer to put your rig on so you can get it home.
sandman92k is offline
post #38 of 47 Old 06-03-2013, 08:25 AM Thread Starter
Trick440
1994 ZJ
I always trailer the jeep. If you come to michigan I'll extend a similar offer. We have the huge rocks and the tight trails take your pic you can get stuck on either.
Trick440 is offline
post #39 of 47 Old 06-03-2013, 08:28 AM
sandman92k
that sounds cool, if your refering to my profile pic, thats my backyard.
post #40 of 47 Old 06-03-2013, 09:57 AM
biggoofy
This brings the lulz that's for sure you can't fix stupid!!!
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #41 of 47 Old 06-03-2013, 11:09 PM
mtnmarc
As others have said, it seems like you already have the idea you want. This type of tube sounds similar to HREW. I've seen bumpers made of it. Its cheaper, but not as strong as DOM because the welded seam.
I wheel nearly once every other week. If not more. With some local trails, Rubicon and fordyce aren't far.
That tube will still bend on hard hits. I've dented my DOM sliders. And they weren't even really hard hits.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #42 of 47 Old 06-04-2013, 12:00 AM
Timo_90xj
Timo_90xj's Avatar
It's not just seamless/ welded tube that makes the strength difference, there's a lot of different types of steel manufactured. DOM tubing is typically higher quality steel than HREW or some other crap quality steel tubing.
OP, as for the body protection why don't you fab tube fenders? Make 'em wide enough on the front to cover your tires and you've provided protection for the front fenders. Rear is a different story unless you make the tube fenders or exo- cage stupidly wide, which makes 'em look like crap. Building an exo cage/ half- exo like on the Wrangler pic you posted, you're going to be denting the roof area anyways when hitting a tree. There are a lot of tight trails around here with big trees and slippery mud, there's really no way to avoid dents if you try wheeling on trails like that unless going very slow and winching all the time because of that.
I agree with others, if you're looking to avoiding dents on either your doors or rear quarter panels, you need rolled mild steel plating to protect them. If you're looking a t keeping the weight down, use thin abrasive- resistant steel plate and bend them to follow the body lines. 0.088 or .125 is plenty thick if you get high quality steel and it'll keep the weight down. using tubing the weight increases suprisingly rapidly, and does not give you the protection you're looking for.
I've built tube fenders on my ZJ (check my build thread), I've got box steel rocker replacement with rocker tubes - and I've got dent on both of my rear quarters. You're talking about fitting on tight trails, and looking at widening your ZJ by at least 1.5" in the rear on both sides if you want to keep the panels away from trees with the tube. Something doesn't match here, right?
***Under construction***
Timo_90xj is offline
post #43 of 47 Old 06-08-2013, 04:52 PM
fast540
Originally Posted by Trick440
Says right in the first post, from the bumper to the rock slides. Let me guess someone is going to ask how I plan to mount it to the front bumper?
You guys do realize I wheel this thing every 2 weeks and we go pretty hard. Is there even anyone posting in this thread that wheels even once a month yr round? Even the hard core wheelers around here only average 6-8 trips a yr.
This is basically what I'm doing, except a lot less yellow and preferably not so ugly. Mines gonna be tied into the sliders way smoother, no gaps. You guys act like I invented this idea. ..
I was just playin with ya. I get out 8-9 times a year with a few romps in the local woods thrown in and kinda sacrificed the body work in process so connecting my bumpers sliders ect would be pointless but I still smile picturing your wj wraped in bubble wrap and romex :-)
fast540 is offline
post #44 of 47 Old 06-11-2013, 01:43 PM
roughknight69
Why not just do something like this for the rear? Seems alot easier then what your trying to do
Build thread
roughknight69 is offline
post #45 of 47 Old 06-12-2013, 06:35 PM Thread Starter
Trick440
1994 ZJ
Is there a link to this?
With a few design mods I could like that.
Trick440 is offline
