Quantcast BLACKzj52's Build Thread - Page 88 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > BLACKzj52's Build Thread
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 04-22-2010, 11:24 AM   #1306
BLACKzj52
hah nice. well check them to make sure they didnt break. i put insurance on them.
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 04-23-2010, 10:09 PM   #1307
BLACKzj52
got my bearings pressed on today. guess what im doing tomorrow
My Build Thead
Facebook
RIP Troy Edwards
Old 04-23-2010, 10:16 PM   #1308
Virmagicus
Headed Out West
Virmagicus's Avatar
Uhhh trying to snag a hot girl?
Virmagicus is offline   Reply With Quote
Old 04-23-2010, 10:35 PM   #1309
BLACKzj52
hmm that somewhat accomplished last night. didnt "snag" her. but to give you an idea, she wanted to stay outside and talk to me for 3 hours where it was cold and her friend was passed out inside cuz she drank too much
but seriously, hoping to finish up the 44a tomorrow. then get it painted here soon
My Build Thead
Facebook
RIP Troy Edwards
Old 04-24-2010, 10:46 PM   #1310
Redsand
yooooo dude. so before i do all this work matting up the hatch....are the stock hatch struts strong enough to hold it up with the extra weight?
1998 5.9 Limited
• AEM BruteForce Intake • Mopar M1 Intake Manifold •BBK 52MM Throttle Body •Carsound Cat •Flowmaster Super 44 • Pro-Comp MX-6 Shocks
Custom SCT Tuned by Sean Powell "HEMIFEVER"
Redsand is offline   Reply With Quote
Old 04-25-2010, 01:40 AM   #1311
BLACKzj52
took this pic tonight for ya
no vice grips holding up my struts
started to set my 44a pinion bearing preload but am starting to take chunks off the nut because my socket is too thick and as it gets closer to the base of the yoke its only grabbing at the top of the pinion nut. so Im thinking ill have to grind some off of it tomorrow (the socket).
oh and 400 ft/lbs is A LOT! gotta use some extra pipes for more leverage.
My Build Thead
Facebook
RIP Troy Edwards
Old 04-25-2010, 02:07 AM   #1312
YERFDOG
How much rattling did the dynamat kill?
YERFDOG is offline   Reply With Quote
Old 04-25-2010, 02:09 AM   #1313
BLACKzj52
havnt tested it yet. and still dont have my entire interior back together so it would be hard to tell.
Also, I got Fatmat, not dynamat. just as good, but a lot cheaper.
My Build Thead
Facebook
RIP Troy Edwards
Old 04-25-2010, 02:16 AM   #1314
YERFDOG
Alright. I'm curious to see how much it helped. I plan to do it in the future, just haven't seen a ZJ's with it. Yea I've heard of fatmat and how it does the job just as good.
Old 04-25-2010, 11:00 PM   #1315
Redsand
I cant wait to get this done. My latch is is garbage so the door dosent tighten correctly or open. And since the latch is broke I have the panel off which just amplifies all of the rattles. So between all that it drives me fckin insane! ugh!
1998 5.9 Limited
Old 04-26-2010, 07:05 AM   #1316
ratmonkey
Living dead mod
ratmonkey's Avatar
what the heck are you trying to run up to 400ftlbs, max on the 44a pinion is 280ftlbs or 380nm.
you should have proper pinion preload way before that.
ratmonkey is offline   Reply With Quote
Old 04-26-2010, 10:53 AM   #1317
Greengc4x4
My thoughts exactly. He is going to break something, and blame his torque wrench again
Greengc4x4 is offline   Reply With Quote
Old 04-26-2010, 11:43 AM   #1318
spife7980
he already did break something...
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adjustable SA and TB, JKS Quick Discos, DT8Ks
265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid
spife7980 is offline   Reply With Quote
Old 04-26-2010, 12:26 PM   #1319
Greengc4x4
Seriously, John?!?! Lmao. Again?!?! Breaking a pipe wrench wasnt a clue that you were doing something wrong? haha. I hope you didnt hurt your axle or gears
Old 04-26-2010, 12:30 PM   #1320
BLACKzj52
First off, have a clue what your talking about before saying stuff. Actually I'm doing it right, you can think what you want. I talked to greg (superjeep on sf) who has rebuild 150+ rearends. He says he's done that before numerous time.
And yes it takes 400 ft/lbs, I've read that numerous times from numerous sources and greg confirmed that toi me yesterdat whe I called him up.
I'm not using a torque wrench. I wouldn't even know where to find a torque wrench that measures that high.
I have used the crap out of that pipe wrench in the past and it was its time. 400ft/lbs is A LOT.
My Build Thead
Facebook
RIP Troy Edwards
Glock Forum
