Quantcast BLACKzj52's Build Thread - Page 77 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > BLACKzj52's Build Thread
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 02-28-2010, 09:28 PM   #1141
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You need to get a better pattern on there. Can't tell anything from what you have there...
ArloGuthroJeep is offline   Reply With Quote
Old 02-28-2010, 09:31 PM   #1142
Virmagicus
Headed Out West
Virmagicus's Avatar
Originally Posted by Greengc4x4 View Post
Post it up on MC and ask them
Yeah ... we don't know **** here.
Virmagicus is offline   Reply With Quote
Old 02-28-2010, 09:35 PM   #1143
BLACKzj52
Originally Posted by Virmagicus View Post
Do you have the illustration from the FSM showing the drive side and the coast side contact patterns?
I have the FSM, and iv got the yukon books that came with the gears that show acceptable patterns. Mine seems to be good, but figured Id get others opinions as well.
Originally Posted by 96DCZJ View Post
just did my front on sat, as we talked about on FB, and I had .007"
spec for the 30 is .005-.009. and .003-.006 for the 44a
the pattern looks clear to me
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 02-28-2010, 10:02 PM   #1144
BLACKzj52
well, my buddy who has rebuild ~14 D44a's (and ~150 axles total) says I've got a good pattern and my BL is about perfect (he likes to set his at .004 though).
My Build Thead
Facebook
RIP Troy Edwards
Old 02-28-2010, 10:09 PM   #1145
Virmagicus
Headed Out West
Virmagicus's Avatar
Well IMHO it looks to deep and the paint does not show enough contact ... i am by no means an expert though.
Old 02-28-2010, 10:13 PM   #1146
Greengc4x4
Sorry, but MC has many more people with gear experience than Jeepforum ZJ technicle section
Greengc4x4 is offline   Reply With Quote
Old 02-28-2010, 11:01 PM   #1147
MiniTubbedNova
Pattern Looks good. a tiny tiny tiny bit on the shallow pinion depth. but if it was me id would leave it as is.
how much did the regearing stuff cost you. im looking to regear my soon when i get my 33's and looking for estimates
MiniTubbedNova takes no responsibility for the comments above...
1970 Nova SS -355-Th-350
1996 Jeep Grand Cherokee - 4.0L-
IRO 4.5" - 33" MT's
Originally Posted by -n8man1068
Jeeps don't get stuck. They just take a nap when they're tired of being awesome.
MiniTubbedNova is offline   Reply With Quote
Old 02-28-2010, 11:08 PM   #1148
BLACKzj52
I was thinking it may be a little deep if anything.
Ill break it down for you:
- D44a and Hp30 Yukon master install kits $222 shipped
- D44a 4.56 Yukon gears ~$260 shipped
- HP30 4.56 Yukon gears ~$140 shipped
- Dial indicator $30
- In/lb BEAM STYLE torque wrench ~$50 shipped
- 1 5/16" socket ~$20
I think that's about everything
My Build Thead
Facebook
RIP Troy Edwards
Old 03-01-2010, 12:23 AM   #1149
Greengc4x4
We're meeting up for pics as soon as this thing is done. lol
Old 03-01-2010, 03:22 AM   #1150
BLACKzj52
^sounds good
cleaned up the gear teeth and removed all excess marking compound and ran the pattern again. With the excess compound removed, the gear pattern looks much better and I am very happy with the results
Drive side:
This area was not originally marked with the compound, but was covered by some left over from the pinion
and coast side:
got to work on the hp30 a little bit. Started with stock shim sizes and couldn't even turn the pinion when meshed with the carrier, lol. Played around with some different combos. Started to get a decent pattern but had NO backlash whatsoever. So I loosened it up a little bit and got this
Spec calls for .005-.009, it's on the tight side, which I prefer (no pun intended)
but heres the thing: I was thinking, and I came up with a question. The question was, what is considered the drive and coast pattern on a front axle gear setup thats reverse rotation? It was messing with me a little bit and I couldn't figure it out (tired). I just assumed that when spinning the gears (simulating the Jeep in drive/forward), the side of the gear getting "pushed" is the drive..Correct? So in the case of an hp30, it would be the opposite of the 44a gears. Am I right to assume that or am I overthinking this?
to put images to words, heres some pics, with patterns..
Coast (?) side:
Drive (?) side:
somebody correct me if I am wrong and I will edit my post so I dont confuse anybody. How do those look to you guys?
My Build Thead
Facebook
RIP Troy Edwards
Old 03-01-2010, 04:32 AM   #1151
torchd
How did you prep to paint your wood grain trim? I want to paint mine black too. What paint did you use?
torchd is offline   Reply With Quote
Old 03-01-2010, 08:24 AM   #1152
ArloGuthroJeep
Mr. Hyde!
Originally Posted by BLACKzj52 View Post
Example of a pattern that is "properly" painted. Just put more resistance on the pinion/ring gears when rotating.
Also, use less paint in the future. You only need to paint a couple teeth. That way if you don't get the pattern right on the first few tries there is some ring gear left to see the new pattern on. Likewise less paint then what you put on will make it easier to get a readable pattern out of it
Old 03-01-2010, 09:02 AM   #1153
MiniTubbedNova
sweet thanks man..
and yeah for some reason i was in the middle of typing the pattern is a tiny bit on the indside to much... it was late and i got confused. looks good. cant wait to see it all finished up
IRO 4.5" - 33" MT's
Old 03-01-2010, 01:02 PM   #1154
BLACKzj52
Only prep I did was to clean the woodgrain with soap and water. Then I used rustoleum Auto primer to prime (probably the last thing you would expect ) then I used a couple coats of Krylon Fusion Black
oh ok thanks for the advice. Believe it or not I only painted 3-4 teeth on my ring gear, then painted another 3-4 on the other side. Musta gone a little overboard with the marking compound
made a post on MC, feel free to make any input
sweet thanks man..
no prob. I know how it goes when trying to think through mechanics when tired.
My Build Thead
Facebook
RIP Troy Edwards
Old 03-01-2010, 01:54 PM   #1155
Greengc4x4
We must not know anything over here
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
