BLACKzj52's Build Thread - Page 89 - JeepForum.com
post #1321 of 1985 Old 04-26-2010, 01:00 PM
Greengc4x4
John, you would never admit you're wrong, even if you knew you were. lol. Lighten up and take a joke.
All the info I am finding, along with what Rat said, says max is just under 300 ft lbs. Lose the defensive attitude and realize that none of us want to see you **** **** up, which is why we are saying something.
Greengc4x4 is offline
post #1322 of 1985 Old 04-26-2010, 01:04 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
400 ft-lbs is way too much. But if you know what you're doing, run the 400 ft-lbs and prove us wrong
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #1323 of 1985 Old 04-26-2010, 01:41 PM
squashman702
1994 ZJ
John, do you have a FSM? I can check when I get home today if you want.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #1324 of 1985 Old 04-26-2010, 02:33 PM
ArloGuthroJeep
Mr. Hyde!
Pulled from my FSM for the D44a:
(10) Install yoke washer and a new nut on the
pinion gear and tighten the pinion nut until there is
zero bearing end-play.
(11) Tighten the nut to 298 Nm (220 ft. lbs.).
CAUTION: Never loosen pinion gear nut to decrease
pinion rotating torque and never exceed specified
preload torque. If preload torque or rotating torque
is exceeded a new collapsible spacer must be
installed.
NOTE: New collapsible spacers require high initial
torque to start the collapsing of the spacer. This
may reach 678 Nm (500 ft. lbs.).
(12) Using Spanner Wrench 6958 and a torque
wrench set at 380 Nm (280 ft. lbs.), (Fig. 88) slowly
tighten the nut in 6.8 Nm (5 ft. lbs.) increments
until the rotating torque is achieved. Measure the
rotating torque frequently to avoid
So perhaps the "NOTE" is what he is referring to
post #1325 of 1985 Old 04-26-2010, 02:35 PM
squashman702
1994 ZJ
installed.
Interesting. My 1998 ZJ FSM doesn't have that note in there . . . just says not to exceed 280 lbs. Makes sense though, I remember helping my buddies mess with a crush sleeve for a 14B and it involved 10' of cheater bars to get it started.
Think Twice Garage
post #1326 of 1985 Old 04-26-2010, 02:43 PM Thread Starter
BLACKzj52
couple things. i was annoyed (for other reasons not relating to this thread) when i responded, so maybe it came across defensive.
i wont admit im wrong when i know im right. and when i am wrong, ill be the first to admit it.
pinion nut torque is 2xx some odd torque. crushing a CRUSH SLEEVE is 400 ft/lbs.
sure thing
although you realized afterwards what i was talking about
yeah i have one
installed.
exactly what im referring to
other sources:
To get that crush sleeve to crush, takes alot of torque (about 300lbs), I use a pipe wrench on the yoke and a long pipe on the end of the wrench, lock that aginst my cart, then I have a large 3/4 breaker bar that I put a long pipe on. Once the crush sleeve begins to crush, it is then a little easier to turn.
^^ http://www.cherokeeforum.com/f52/d44...-install-5292/
The crush sleeve permanently distorts, or crushes, at approximately 300 to 400 pounds/feet of torque on the pinion nut.
from the yukon manual.
found here: http://www.yukongear.com/Downloads/T...structions.pdf
page 11.
BLACKzj52 is offline
post #1327 of 1985 Old 04-26-2010, 03:38 PM
Greengc4x4
John, the cherokeeforum write-up is the one I looked at. He says "about 300". That is one of the sources I looked at.
post #1328 of 1985 Old 04-26-2010, 03:49 PM Thread Starter
BLACKzj52
Cool.
It takes 300-400 ft/lbs.
Number doesn't really matter tho, what matters is the pinion bearing preload. And right now I have none which means my crush sleeve hasn't crushed . Meaning the nut needs to be tighter. That's ther last time I'm going to say that
post #1329 of 1985 Old 04-26-2010, 04:59 PM
97DCZJ
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #1330 of 1985 Old 04-26-2010, 05:02 PM
Greengc4x4
Pull the sand out of your vagina
post #1331 of 1985 Old 04-26-2010, 06:36 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
use a press to start the crush, it's what the guys who've done a couple hundred crush sleeve style differentials do.
ratmonkey is offline
post #1332 of 1985 Old 04-26-2010, 06:38 PM
BlackbeastZJ
Originally Posted by 96DCZJ View Post
x2 .....10 char
Sam-20: I love camo duct tape!
1995 Jeep Grand Cherokee Limited, blacked out
4.0 I6, NP249, D30-D35 with 3.73 gears
LED Interior and gauge lights, Silverstar Ultra's
Tinted tails, Baja fogs, Bedlined bumpers, removed cladding
Iron Rock Offroad 3.5" lift, 15x8 Cragar D Windows, 32" BFG A/T's
Curt trailer hitch, Cobra CB with 4ft RS antenna
Black Jeep Society
Christian Jeep Owners #37
BlackbeastZJ is offline
post #1333 of 1985 Old 04-26-2010, 06:42 PM
SHAKEnBLAKE
get it on the road!!
get it on the trail, rather...
Ohio4x4.com
SHAKEnBLAKE is offline
post #1334 of 1985 Old 04-26-2010, 07:44 PM
Greengc4x4
I had thought maybe a vice, but a press would be perfect!
post #1335 of 1985 Old 04-26-2010, 09:33 PM
JrMechanic
A vice doesn't even hold a candle to the power of a hydraulic press Roger
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
Alexsious's WJ Build Thread alexsious Grand Cherokee General Discussion 4 01-19-2011 02:28 AM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
