BLACKzj52's Build Thread - Page 86 - JeepForum.com
post #1276 of 1985 Old 04-19-2010, 03:16 PM
indredsnake99
Where did you get the harness and all the hid parts I am thinking about start to do a retrofit on my spare set headlights
indredsnake99 is offline
post #1277 of 1985 Old 04-19-2010, 03:28 PM Thread Starter
BLACKzj52
got em through DDM tuning. They are on slight backorder though. The harness came with my 9007 kit, which is why I was surprised. It's like a direct 12v power harness.
http://www.ddmtuning.com/index.php?p...=101&parent=85
BLACKzj52 is offline
post #1278 of 1985 Old 04-19-2010, 08:45 PM
bigbluezj94
1994 ZJ
that window looks nice... wish i had one
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #1279 of 1985 Old 04-19-2010, 08:49 PM Thread Starter
BLACKzj52
i sent them last week. should be seeing them soon. im gonna shoot ya a text
post #1280 of 1985 Old 04-19-2010, 08:56 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Nice to see it coming together, John.
Get the tires mounted so I can see.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #1281 of 1985 Old 04-20-2010, 08:49 PM Thread Starter
BLACKzj52
^soon
hoping to take my stuff to the shop friday and have my bearings pressed on. hoping to have my axles done (gears and paint) by the end of next week.
post #1282 of 1985 Old 04-20-2010, 09:08 PM
Bama_WJ
Bama_WJ's Avatar
So how would you gauge the difficulty of the gear job? I'm on the fence whether I could tackle it myself or not. Not having to spend the big chunk of change to have a shop do it would really be nice. I mean I know the whole idea and have a general grasp of how everything should look when setup, but having a shop do it would put my mind at ease. So thats why I'm kind of torn between the two right now.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #1283 of 1985 Old 04-20-2010, 09:13 PM Thread Starter
BLACKzj52
Its definitely doable. just read a lot of write ups and take your time and take notes when you try different shim combos. It really wasnt all that bad. yeah having a shop doing it puts your mind at ease, but I really couldn't justify coughing up the $700 when I could do it myself.
Here was my idea going into the entire process. Let me try this myself, if i cant get a good pattern, ill take it to a shop. Sure enough I got a good pattern. Id recommend atleast trying it yourself first if youre on the fence.
If you want I can send you a bunch of links to writeups I used. and Eventually I was going to maybe make a mini writeup or something myself, including some little things that other writeups dont include.
post #1284 of 1985 Old 04-20-2010, 09:27 PM
Greengc4x4
Might wanna make sure your setup works and doesnt explode before doing a write-up
Greengc4x4 is offline
post #1285 of 1985 Old 04-20-2010, 09:30 PM Thread Starter
BLACKzj52
thats what i was waiting for
although in all honesty i'll be good. my patterns were solid.
post #1286 of 1985 Old 04-20-2010, 09:32 PM
Greengc4x4
Psh, you know your *** hole is going to be tense on your first drive.
post #1287 of 1985 Old 04-20-2010, 09:34 PM
Ricochet88
if you have any questions about the projectors let me know
Rick "woody"
93 zj wagoneer pkg, 5in iro lift, 33/10.5/15 bfgoodrich km2
my build thread
R.I.P. TROY EDWARDS "bigbluezj94"
Ricochet88 is offline
post #1288 of 1985 Old 04-20-2010, 09:44 PM Thread Starter
BLACKzj52
oh god yeah i will be. I'm always kinda nervous on that first test drive after doing any extensive mod/repair.
you got it man. I was thinking about sending you a pm soon. you will probably be hearing from me. And thanks btw
post #1289 of 1985 Old 04-20-2010, 10:30 PM
Bama_WJ
Bama_WJ's Avatar
Yea, I've really thought about doing it myself. I have read a few write ups. The ones I can remember off the top of my head were from RockFrogs and Pirate4x4. If you got anymore good write ups, post them in my build thread or get them to me over facebook and I'll favorite them in my browser from there. Saving around $700 sounds really appealing. Would also give me the opportunity to paint the axles up with some Chassis Saver.
Daniel
Bama_WJ is offline
post #1290 of 1985 Old 04-20-2010, 11:00 PM
Redsand
John, you wanna take some more pics of the inside of the rear hatch? I am getting ready to rebuild the innards of mine and plan to line it with some sort of matting as well. I'm just curious to see how you laid it down. If you have pics somewhere else in this build thread my bad, haven't had a chance to look through the whole thing...
1998 5.9 Limited
• AEM BruteForce Intake • Mopar M1 Intake Manifold •BBK 52MM Throttle Body •Carsound Cat •Flowmaster Super 44 • Pro-Comp MX-6 Shocks
Custom SCT Tuned by Sean Powell "HEMIFEVER"
Redsand is offline
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
