BLACKzj52's Build Thread - Page 77 - JeepForum.com
post #1141 of 1985 Old 02-28-2010, 08:28 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You need to get a better pattern on there. Can't tell anything from what you have there...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #1142 of 1985 Old 02-28-2010, 08:31 PM
Virmagicus
Virmagicus's Avatar
Originally Posted by Greengc4x4 View Post
Post it up on MC and ask them
Yeah ... we don't know **** here.
Jeff
Virmagicus is offline
post #1143 of 1985 Old 02-28-2010, 08:35 PM Thread Starter
BLACKzj52
Originally Posted by Virmagicus View Post
Do you have the illustration from the FSM showing the drive side and the coast side contact patterns?
I have the FSM, and iv got the yukon books that came with the gears that show acceptable patterns. Mine seems to be good, but figured Id get others opinions as well.
Originally Posted by 96DCZJ View Post
just did my front on sat, as we talked about on FB, and I had .007"
spec for the 30 is .005-.009. and .003-.006 for the 44a
the pattern looks clear to me
BLACKzj52 is offline
post #1144 of 1985 Old 02-28-2010, 09:02 PM Thread Starter
BLACKzj52
well, my buddy who has rebuild ~14 D44a's (and ~150 axles total) says I've got a good pattern and my BL is about perfect (he likes to set his at .004 though).
post #1145 of 1985 Old 02-28-2010, 09:09 PM
Virmagicus
Virmagicus's Avatar
Well IMHO it looks to deep and the paint does not show enough contact ... i am by no means an expert though.
Jeff
post #1146 of 1985 Old 02-28-2010, 09:13 PM
Greengc4x4
Sorry, but MC has many more people with gear experience than Jeepforum ZJ technicle section
Greengc4x4 is offline
post #1147 of 1985 Old 02-28-2010, 10:01 PM
MiniTubbedNova
Pattern Looks good. a tiny tiny tiny bit on the shallow pinion depth. but if it was me id would leave it as is.
how much did the regearing stuff cost you. im looking to regear my soon when i get my 33's and looking for estimates
MiniTubbedNova takes no responsibility for the comments above...
1970 Nova SS -355-Th-350
1996 Jeep Grand Cherokee - 4.0L-
IRO 4.5" - 33" MT's
Originally Posted by -n8man1068
Jeeps don't get stuck. They just take a nap when they're tired of being awesome.
MiniTubbedNova is offline
post #1148 of 1985 Old 02-28-2010, 10:08 PM Thread Starter
BLACKzj52
I was thinking it may be a little deep if anything.
Ill break it down for you:
- D44a and Hp30 Yukon master install kits $222 shipped
- D44a 4.56 Yukon gears ~$260 shipped
- HP30 4.56 Yukon gears ~$140 shipped
- Dial indicator $30
- In/lb BEAM STYLE torque wrench ~$50 shipped
- 1 5/16" socket ~$20
I think that's about everything
post #1149 of 1985 Old 02-28-2010, 11:23 PM
Greengc4x4
We're meeting up for pics as soon as this thing is done. lol
post #1150 of 1985 Old 03-01-2010, 02:22 AM Thread Starter
BLACKzj52
^sounds good
cleaned up the gear teeth and removed all excess marking compound and ran the pattern again. With the excess compound removed, the gear pattern looks much better and I am very happy with the results
Drive side:
This area was not originally marked with the compound, but was covered by some left over from the pinion
and coast side:
got to work on the hp30 a little bit. Started with stock shim sizes and couldn't even turn the pinion when meshed with the carrier, lol. Played around with some different combos. Started to get a decent pattern but had NO backlash whatsoever. So I loosened it up a little bit and got this
Spec calls for .005-.009, it's on the tight side, which I prefer (no pun intended)
but heres the thing: I was thinking, and I came up with a question. The question was, what is considered the drive and coast pattern on a front axle gear setup thats reverse rotation? It was messing with me a little bit and I couldn't figure it out (tired). I just assumed that when spinning the gears (simulating the Jeep in drive/forward), the side of the gear getting "pushed" is the drive..Correct? So in the case of an hp30, it would be the opposite of the 44a gears. Am I right to assume that or am I overthinking this?
to put images to words, heres some pics, with patterns..
Coast (?) side:
Drive (?) side:
somebody correct me if I am wrong and I will edit my post so I dont confuse anybody. How do those look to you guys?
post #1151 of 1985 Old 03-01-2010, 03:32 AM
torchd
2003 WJ
How did you prep to paint your wood grain trim? I want to paint mine black too. What paint did you use?
torchd is offline
post #1152 of 1985 Old 03-01-2010, 07:24 AM
ArloGuthroJeep
Mr. Hyde!
Originally Posted by BLACKzj52 View Post
Example of a pattern that is "properly" painted. Just put more resistance on the pinion/ring gears when rotating.
Also, use less paint in the future. You only need to paint a couple teeth. That way if you don't get the pattern right on the first few tries there is some ring gear left to see the new pattern on. Likewise less paint then what you put on will make it easier to get a readable pattern out of it
post #1153 of 1985 Old 03-01-2010, 08:02 AM
MiniTubbedNova
sweet thanks man..
and yeah for some reason i was in the middle of typing the pattern is a tiny bit on the indside to much... it was late and i got confused. looks good. cant wait to see it all finished up
IRO 4.5" - 33" MT's
post #1154 of 1985 Old 03-01-2010, 12:02 PM Thread Starter
BLACKzj52
Only prep I did was to clean the woodgrain with soap and water. Then I used rustoleum Auto primer to prime (probably the last thing you would expect ) then I used a couple coats of Krylon Fusion Black
oh ok thanks for the advice. Believe it or not I only painted 3-4 teeth on my ring gear, then painted another 3-4 on the other side. Musta gone a little overboard with the marking compound
made a post on MC, feel free to make any input
sweet thanks man..
no prob. I know how it goes when trying to think through mechanics when tired.
post #1155 of 1985 Old 03-01-2010, 12:54 PM
Greengc4x4
We must not know anything over here
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
