BLACKzj52's Build Thread - Page 46 - JeepForum.com
post #676 of 1985 Old 10-24-2009, 05:24 PM
MyZJ98
Originally Posted by ratmonkey View Post
meh, just put a full set of kappa speakers and the 5ch amp in my car.
i had the reference in another vehicle before, there's a definite jump in quality between the two lines.
Which do you like better, the kappas or references?
Derek
'98 ZJ Laredo, 4.0L, 140K, NP242, stock. (Sold @205k)
'99 WJ Laredo, 4.7L, 175K, NP249, stock. (Sold @240k)
'97 ZJ Limited, 4.0L, 109K, NP249, stock.(Current)
MyZJ98 is offline
post #677 of 1985 Old 10-25-2009, 01:16 AM
Greengc4x4
The kappas are amazing. i had them in my last 5.9
Greengc4x4 is offline
post #678 of 1985 Old 10-25-2009, 05:21 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you can afford it, get the kappas. Much better frequency response at the upper and lower limits of the speakers. The reference speakers just didn't have the low end or high frequency detail of the kappas.
Also running the 10" kappa sub in a sealed box to spec. It hits as hard enough being in a small convertible.
Using an eclipse cd7000 head unit.
The grand just has some middle of the road stuff. Front polk components and hifonics atlas 12's in the back.
ratmonkey is offline
post #679 of 1985 Old 10-25-2009, 09:47 PM Thread Starter
BLACKzj52
2 tone...
word?
10" power acoustics dual voice coil sub
let the interior tear down/major cleaning/sub install begin
i plan on pulling the carpet out and steam cleaning the hell out of it
new battery terminal
front skid for $5!
and last but not least
these are for sale
thats all
BLACKzj52 is offline
post #680 of 1985 Old 10-25-2009, 09:59 PM
Bama_WJ
Bama_WJ's Avatar
The two tone looks good.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #681 of 1985 Old 10-25-2009, 10:12 PM
MyZJ98
Wow, looks like you've got some work ahead of you, and by the looks of it, seems like that interior is a little overdue for a good cleaning, haha. Some good stuff to use on pretty much everything, even after steam cleaning, is Simple Green, you can get it cheap at wal mart, it sprays on like a foam, and then can be wiped and vacuumed up, and cleans EVERYTHING, stains, smells, stuck on stuff, everything, great stuff, and it leaves a nice scent after. Used it in the interior teardown in my dads ZJ, and he's a heavy smoker, and before, it reeked like smoke, and after, it smelt clean and fresh, you'd have never known it was a smokers car. a day or two later, and he made sure to change that... But anyways, give it a try, it works wonders.
I'm also due for a stereo system update. I used to build and install custom stereos for friends and customers, and I ALWAYS used to have a top notch system, but when I got the grand, I got so carried away with exterior mods, I forgot about the sound. But now I'm happy with the outside, my focus is back to the sound system, and it's time foran upgrade. It's been so long since I've done installing and working with systems, I've lost touch with what's the newest, most powerful, and best sounding equipment. I used to run a lot of kicker products, a lot of infinity, and a lot of kenwood stuff, and with my brand experience, they were usually the top three, and for the more budget minded shopper, pioneer was the way to go. I think next, after a good bit of research, and talking to the guys over at Crutchfield to help update me, I think I'm going to go with a full infinity kappa setup, although keeping my Kenwood headunit, but all Infinity kappas in the doors, and 2 12" Infinity Kappa subs and amp. I'm not looking forward to the price, but I am looking forward to the sound.
And let me know what you think of that power acoustic sub, I always like to learn about new products I've never heard, or heard of.
Good luck with all the cleaning!
Derek
MyZJ98 is offline
post #682 of 1985 Old 10-26-2009, 10:30 AM Thread Starter
BLACKzj52
haha it stared off as kind of a joke (got a free bumper from a friend who upgraded to aftermarket) and it actually came out looking decent
dont think ill keep it, but at some point id like to see what it looks like 2 tone with all bumpers and lower cladding
definitely do have a lot of interior work ahead of me. thanks for the tip.
iv heard the power acoustics sub before (was my friends old sub), and for a little 10" the thing hit pretty hard. definitely was impressed and will be pleased with it in my zj!
post #683 of 1985 Old 10-26-2009, 03:46 PM
MyZJ98
BTW, that two tone actually looks pretty good. You should borrow that same buddys back bumper and cladding and put it on and take some pictures to see how it looks. I think it would look pretty good, those are good color combinations.
Derek
MyZJ98 is offline
post #684 of 1985 Old 10-26-2009, 05:20 PM
ccmf22
hey were did u get the LED's for the dash??
WANTED:3.5" Front Springs
ccmf22 is offline
post #685 of 1985 Old 10-26-2009, 05:30 PM
squashman702
1994 ZJ
Nice red fuse box cover, ricer.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #686 of 1985 Old 10-26-2009, 08:35 PM Thread Starter
BLACKzj52
i kinda like it too actually. i still like the all black better tho
superbrightleds.com
why dont you got break a computer screen
i was just informed of the specs of my sub and amp
Dual 4 ohm voice coil
# Die cast aluminum
# Royal Blue Finish WithDiamond Cut
# Non-pressed laminated paper cone
# Chrome finish back plate
# Large foam rubber surround
# 1-piece rubber gasket
# Black poly-cotton spider
# Woven tinsel lead through spider
# Chrome push terminals
# 1600 watts power handling
# 600 Watts RMS
# 160 oz. magnet
# 2 BASV voice coil
# SPL 90 dB
# Fs: 36.8 Hz
# Vas: 0.99 cu.ft.
# Qms: 4.86
# Qes: 0.51
# Qts: 0.462
# Xmax: 0.4"
# Sealed box: .75 cu. Ft.
# Ported box: 1.5 cu.. Ft.
# Tuning: 40 Hz
# Port Size: 3(dia)x6.5(length)
# # of ports:1
amp
980watt peak
700 watt rms
i have no idea what any of that really means
BUT
i do know i have about a 1200 watt sound system now
post #687 of 1985 Old 10-26-2009, 08:48 PM
squashman702
1994 ZJ
I might, I'm stuck at work doing payroll right now, pushing towards a 15 hour day.
Think Twice Garage
post #688 of 1985 Old 10-26-2009, 09:00 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
superbrightleds.com
# Die cast aluminum
# 600 Watts RMS
# 160 oz. magnet
# 2 BASV voice coil
# SPL 90 dB
# Fs: 36.8 Hz
# Vas: 0.99 cu.ft.
# Qms: 4.86
# Qes: 0.51
# Qts: 0.462
# Xmax: 0.4"
# Tuning: 40 Hz
# # of ports:1
amp
980watt peak
700 watt rms
BUT
take those numbers with a huge grain of salt, power acoustik is one of the cheapest car audio brands out there.
i would say that sub is more of a 600w max 200rms based on experience. and those amplifier numbers make absolutely no sense at all.
post #689 of 1985 Old 10-26-2009, 09:53 PM
_Kyle_
_Kyle_'s Avatar
you dont have a lifted jeep anymore so your opinion doesnt matter
sub installed
got a front skid at the junkyard today for $5.. gonna go back for the gas tank skid tomorrow (er technically today) with a hi-lift (idiots set the jeep down on the gas tank) and get that too.
im starting to stock pile parts in my garage. each weekend that i come home to work on my jeep, i seem to bring more jeep parts with me
I still have my original ZJ, which I think i've owned a good bit longer than you've owned a Jeep.
I'm also cooking up plans to keep my ZJ around for a long time into the future.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #690 of 1985 Old 10-27-2009, 02:54 PM Thread Starter
BLACKzj52
this video is of no significance - we took it on the day that we got my jeep to work again. but i couldnt resist not posting it. the exhaust crackle gets me everytime
[YT]n6LYT2jp6Y4[/YT]
and yes my buddy's xj is running in the background so you can hear that a little bit
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
Alexsious's WJ Build Thread alexsious Grand Cherokee General Discussion 4 01-19-2011 02:28 AM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
