The Billzcat1 Build Thread - Page 34 - JeepForum.com
post #496 of 563 Old 04-16-2013, 12:10 PM Thread Starter
billzcat1
Chicken in a Turkey Suit
2003 WJ
There are lots of things that could contribute, but TREs would be a good place to start. If you can pull them up/down or side-to-side then you REALLY need to replace them.
~Richard
billzcat1 is offline
post #497 of 563 Old 04-16-2013, 01:03 PM
Upside
All 4 TREs are new Moogs on my Jeep and it is pretty stiff to rotate the joints. My old ones with 120k on them were really easy to rotate and the new ones tightened everything up nicely. Also look at buying the newer track bar bolts if you haven't already done so.
Upside is offline
post #498 of 563 Old 04-16-2013, 01:06 PM Thread Starter
billzcat1
2003 WJ
I would also include a new tie rod and drag link if you live in the rust belt. They are cheap, the Moog ones are stronger than stock, and they are often so rusty you will never get them apart. They are typically listed as "adjusting sleeve".
New track bar bolts? I'm afraid I don't follow.
~Richard
post #499 of 563 Old 04-16-2013, 01:25 PM
Upside
The original track bar bolts have a tapered shank to make assembly easier at the factory. The updated part number doesn't use a tapered shank for a tighter fit. Similar to the new bolts and sleeves included in the KOR anti DW kit.
http://www.jeepforum.com/forum/f310/...himmy-1493062/
Upside is offline
post #500 of 563 Old 04-16-2013, 02:48 PM Thread Starter
billzcat1
2003 WJ
Interesting. Maybe next time I grease the JKS track bar I'll throw new bolts in there.
~Richard
post #501 of 563 Old 04-17-2013, 08:11 AM
ChrisHager
Administrator
ChrisHager's Avatar
Hmmm... That is interesting. I'll have to keep that in mind!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #502 of 563 Old 04-17-2013, 09:58 AM
snobrdrkid07
snobrdrkid07's Avatar
Same, I found that thread the other week and was considering it. Don't know if it would be too little too late for me with the ever so slight wallowing. But would keep the sleeve tight on the shank.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #503 of 563 Old 04-17-2013, 10:38 AM
Upside
Can you have a washer welded to the frame to fix the wallowed out hole?
Upside is offline
post #504 of 563 Old 04-17-2013, 11:11 AM Thread Starter
billzcat1
2003 WJ
That thick-shank bolt might be a good idea considering how one has to over-torque the bolts to keep the JKS bar happy.
In billzcat1-related news....
I installed a new PS cooler and all new return hoses as well as yet another new o-ring on a good OEM pump. I took extra care to ensure I didn't overfill the system... and she still leaks from the O-ring between pump and reservoir. Not nearly as bad as before, but bad enough that I'm not happy. It looks like when I'm installing the o-ring it is getting a little crooked as the hammer-on clamps affix the reservoir to the pump. I'll have to try again.
I have a camping trip coming in 2 weeks, heading to Neah Bay/Cape Flattery - the northwestern-most point of the 48 states. Tip of the country! But since our family has grown a bit since last time we camped, I am pressed for room in the Jeep. Several pages back I entertained a larger vehicle but for the moment we've decided to keep what we've got and see if we can make it work. So for Xmas I got the Harbor Freight hitch-mounted cargo basket (which I love)... the only issue there is that it hinders access to the liftgate area and big stuff might occlude the taillights.
So I also picked up a Rola basket with the center extension. Ordered yesterday, shipped today, be here on Friday! Quick turnaround! I ordered from www.ecustomhitch.com and they seemed to have the best price I could find. $144 for the normal Rola with free shipping, $72 for the extension, also free shipping. Can't beat that with a stick!
My garage door is kind of low so I am going to look at mounting alternatives instead of using the roof rack cross bars.
~Richard
post #505 of 563 Old 04-17-2013, 02:40 PM
snobrdrkid07
There was a guy on here who made custom tabs for mounting the Rola Rack. I believe 4 on each side, they mounted down into the channel of the side bars. It was a really nice setup and I believe met your goal of sitting nice and low, or at least lower than on top of the cross bars. I'll see if I can find and if I can I'll update this post with a link. I do what to point out that some people did have issues with the rola rack rusting internally if kept ontop of the Jeep at all times. Suggested that putting silicon in the section breaks can help alleviate this.
Edit: BINGO http://www.jeepforum.com/forum/f310/...l#post11393609
-Michael-
post #506 of 563 Old 04-17-2013, 03:11 PM Thread Starter
billzcat1
2003 WJ
Yeah, seen the rust issues. I have plenty of RTV black to seal it up. Good find on the mounting brackets. I'll see if I can come up with a no-weld version.
~Richard
post #507 of 563 Old 04-17-2013, 03:19 PM
snobrdrkid07
Glad I could finally help! I've been wanting one for awhile too, you found a good deal too. I'm just unsure of the wind noise but, they look sweet.
-Michael-
post #508 of 563 Old 04-17-2013, 03:25 PM Thread Starter
billzcat1
2003 WJ
I'll let you know how bad it gets.
~Richard
post #509 of 563 Old 04-17-2013, 06:27 PM Thread Starter
billzcat1
2003 WJ
Anyone reading this thread and interested in a Rockauto discount: got this discount code in my email: 142820595176324
"The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks.
This discount code expires on June 9, 2013; so don't wait!"
~Richard
post #510 of 563 Old 04-18-2013, 12:02 PM Thread Starter
billzcat1
2003 WJ
So I ordered that rola rack on Monday evening and it was delivered Wednesday morning. Now THAT'S quick shipping! Still waiting on the extension though, that's scheduled for Friday delivery.
~Richard
My '05 WK build thread. ogie WK Grand Cherokee & XK Commander Forum 36 02-12-2015 09:42 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
