The Billzcat1 Build Thread - Page 27 - JeepForum.com
post #391 of 563 Old 10-14-2012, 07:36 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
If the fluid was overheating and building too much pressure, wouldn't it catastrophically... explode? Or even putting too much pressure on the o-rings.
To test for a blockage in the cooler, could you disco the lines and try and to put a compressor up to one end it and see if it blows fluid out the the other side. hah.
You should post some pictures of, anything if you want.
Secondly, we can trade Jeep if you want too. Ill give you mine and throw in a few G's.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #392 of 563 Old 10-14-2012, 11:11 PM
Cirruslydakota
Depends, usually in a pressure system the weakest link will fail, in this case probably the shaft seal between the pump housing and reservoir. Beyond that it would be an o-ring and on up the line. Looks like its time to put a gauge on it and check your pump pressures. Theres a table in section 19-5 in the FSM detailing the procedure. Mines showing relief pressure for the V8 being 75 psi.
Also, didn't you already have the factory filter on the system already? I thought they came with one, you do have the hydraulic fan setup right?
Before I installed my cooler I pressure checked it and cleaned it out at work but we have a radiator/cooler shop and not everyone has access to those. You might want to call around a few places to see if they do it. Ours takes anything no matter the make, model, or type.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #393 of 563 Old 10-15-2012, 09:03 PM Thread Starter
billzcat1
Chicken in a Turkey Suit
2003 WJ
Well, I did a slightly ghetto fix today and it seems to have worked for the moment. Drilled a 1/16" hole in the reservoir cap (a spare). No more leak. I was planning on grabbing an IR thermometer from work to test my cooler theory but I forgot. But it's just more proof that the problem is high pressure in the reservoir. Now to find the cause.
~Richard
billzcat1 is offline
post #394 of 563 Old 10-15-2012, 09:05 PM Thread Starter
billzcat1
2003 WJ
Oh, and no, I didn't have a factory filter in any of the lines. That feature was phased out through the years. The parts fiche shows a filter in the return hose but it doesn't exist, that's just an inaccurate, out of date diagram.
~Richard
post #395 of 563 Old 10-16-2012, 09:09 AM
Cirruslydakota
You would think that the cap would have a vent already in place on it, maybe its too small to handle the pressure build up you're expierencing. Hmm.
Bear - 99 WJ Laredo
post #396 of 563 Old 10-16-2012, 09:14 AM
snobrdrkid07
WJ for Life
I would have to say that it is odd that the pressure in the reservoir cap is there in the first place.
-Michael-
post #397 of 563 Old 10-16-2012, 09:26 AM Thread Starter
billzcat1
2003 WJ
The cap has a large spring assembly and multiple layers of "stuff" in it. I think it is supposed to be a pressure relief but it isn't working. Even with a brand new Mopar cap. The pressure is the real baffling thing.
~Richard
post #398 of 563 Old 10-16-2012, 09:36 AM
snobrdrkid07
WJ for Life
This is so weird. A high pressure line mixed up with a low pressure line in the reservoir? It seems like something has got to be backwards. Not to insult you or anything. A valid next step, as you said, was your p.s. fluid cooler. Is the reservoir supposed to be under minimal pressure? Maybe need to find a diagram of the flow through the entire system and see if there is blockage somewhere that could cause back pressure in the reservoir and cause the leak.
-Michael-
post #399 of 563 Old 10-16-2012, 09:58 AM Thread Starter
billzcat1
2003 WJ
Trust me, it only goes together one way. One high pressure line out to hydro fan assembly. Line from hydro fan to steering box. Return line from hydro fan to reservoir. Line from steering box to cooler, line from cooler to reservoir.
From what I understand, the only pressure that is supposed to build in the reservoir is due to the expansion of the fluid. It is the low-pressure side of the pump. Day 2 with a hole in the cap, no leak. I still think the cooler must be blocked or otherwise ineffective for this problem to even occur. Externally it looks fine. My lead on a good-used one fell through. I'm not paying $150 for a lousy cooler. Maybe get another aftermarket trans cooler and replace it all with flex line. I don't know.
~Richard
post #400 of 563 Old 10-16-2012, 10:16 AM
snobrdrkid07
WJ for Life
I figured the least that it was all hooked up right, just wanted to toss it out there.
If the cooler is blocked, I'd spend 50 on another "transmission cooler" from e-trailer that is plate fin style and very efficient.
Looking at the diagram, I just do not get how there can be high pressure in the reservoir! Unless the control solenoid is throwing high pressure into the low pressure return line...
-Michael-
post #401 of 563 Old 10-16-2012, 11:33 AM
Upside
On the ZJs shipped to Europe the power steering cooler was just another OEM trans cooler flipped over and mounted to the driver's side. I used one on my ZJ with no issues, if I remember correctly it was a 6"x8" cooler. If that's your issue it sounds like a good upgrade from the stock cooler.
Upside is offline
post #402 of 563 Old 10-17-2012, 09:33 AM Thread Starter
billzcat1
2003 WJ
I got ahold of an infrared thermometer and temped the cooler after I got home from work (a short but hilly 3.9 mile drive).
Fluid in the reservoir: 105
Cooler on the leading edge of the top bar: 95 - sounds about right
Cooler on the trailing edge of the top bar: 64 - this should the same as the leading edge - this is all the "hot" side of the cooler.
So, at least part of my theory is correct - the entire cooler should be roughly the same temperature across each of the end tanks. Whether that's causing the issue or not I can't say. I'm still intending on replacing it.
Also, the 01-03 V8 power steering cooler is giant. It doesn't need an upgrade. It needs to work properly. It's roughly 10x10, bar and plate style. It's larger than the transmission cooler I just installed. Chrysler was pretty concerned with fluid temp with the hydraulic powered fan.
~Richard
post #403 of 563 Old 10-27-2012, 02:00 PM Thread Starter
billzcat1
2003 WJ
Well, the PS leak still isn't cured but it is manageable. Still rocking the cap with a hole in it and the original cooler, likely mostly plugged.
I've noticed lower coolant temps now with the transmission cooler and the transmission is much more willing to hold in top gear going up hills on the freeway where it would normally unlock the converter and possibly downshift. So I'm pretty happy with that setup.
But the main reason I'm checking in... something funny happened in the Jeep last night. Cruising along the freeway in a lovely Washington rainstorm, front and rear wipers going. Heard a Click. Looked back and there's a wiper arm stuck just above the rest position and the blade was gone! Apparently the plastic clip where it goes into the arm failed and my rear wiper fell off.
~Richard
post #404 of 563 Old 10-27-2012, 02:18 PM
Thomahawk
Time for a rear Viper delete Billz.
Buildthread
Thomahawk is offline
post #405 of 563 Old 10-27-2012, 05:42 PM
compcrasher86
Why would you wanna delete the rear wiper O_o?!
Matt
compcrasher86 is offline
My '05 WK build thread. ogie WK Grand Cherokee & XK Commander Forum 36 02-12-2015 08:42 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 03:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 08:10 PM
