The Billzcat1 Build Thread - Page 13 - JeepForum.com
 11Likes
post #181 of 572 Old 04-13-2012, 01:12 AM
=KZ=
I was thinking if I wanted to go that route on my next set of tires I would custom space my rig up to 3.5" front. Won't you loose your foglights as well? It would be great if you guinea pigged it since your a reliable source of info as far as actually discoing and getting it right.
I was also wondering if having adjustable upper and lower CA would enable you to bring the wheel as far back in the wheel well as possible, (while keeping pinion angle reasonable) to avoid rubbing in the front, as a trick to keep the fogs. Just a thought.
=KZ= is offline
post #182 of 572 Old 04-13-2012, 02:31 AM
compcrasher86
You've got the emissions behind the rear bumper I believe so you shouldnt have much trouble retrofitting in a ZJ washer bottle under the hood.
Matt
compcrasher86 is offline
post #183 of 572 Old 04-13-2012, 11:27 AM Thread Starter
billzcat1
Chicken in a Turkey Suit
2003 WJ
Yeah, there's a little solenoid there behind the airbox but nothing major. ZJ bottle can go there between the brake MC and fender.
I guess what might happen (should I come across a set) is I'll try them, see just how far they would need to be trimmed and whatnot. If it doesn't work out, I can always resell without taking a loss. I've got a good place to test flex in my driveway - a lovely giant rock. It always gets funny looks from the neighbors...
~Richard
billzcat1 is offline
post #184 of 572 Old 04-13-2012, 12:48 PM
=KZ=
Are you gonna run the take offs full time or as a set of offroading shoes? I was thinking of getting a set of chains for the rear in case I need to contend with mud with my SA's. I would get fronts but figured that clearance may be an issue.
=KZ= is offline
post #185 of 572 Old 04-13-2012, 01:28 PM Thread Starter
billzcat1
2003 WJ
Eh, it's kind of a hassle to change tires all the time. I don't know what I'm going to do with any degree of certainty or if I will even wind up with a set. My plan would be to run them full-time.
~Richard
post #186 of 572 Old 04-22-2012, 01:27 AM Thread Starter
billzcat1
2003 WJ
Well, after some good discussion with =KZ=, I have decided not to run the Rubicon take offs. While the price, tires, and wheels are all very attractive, I wasn't happy with the degree of cutting required and the very limited uptravel that would result. So when the time comes, I'm back to square 1, definitely going 31s.
Today was a big "car day" where a large group of friends gets together at someone's house to work on cars. It was big one, 9 cars needed work - 2 e36s, a Lotus Elise, a Porsche Cayman S, an XJ, my WJ, a Toyota Pickup, an e30 325iS, and an S2000.
My project was really simple, just make a couple bumpstop extensions up front to protect my shocks from bottoming out. I picked up some 6061 aluminum from the metal scrapyard, nice 2x2 box tubing. Cut it in the bandsaw, marked it to match the holes on the bump stop cups, went to town. I painted them black because they were kind of ugly having been stored outside, and I didn't want shiny aluminum poking out in my wheel wells. As they get dirty, they'll just blend into the undercarriage.
As for the rest of the day, I spent a lot of effort and time working on the XJ, the same one I installed TREs and an IRO track bar a couple weeks ago. Today was a big project. We did C4x4 Tow Hooks (VERY burly, amazing quality), the radiator, fan clutch, alternator, thermostat, serpentine belt, replaced the battery terminals and wiring to power block and starter. Tried to do the water pump, but the bolts were frozen solid and the pump wasn't bad, just wanted to do preventative maintenance. Decided it was best to just let it be for now and cross that bridge if the pump fails. Anyway, it was a LOT of work, worked from about 2PM to 9PM and got it all done. TIRED.
~Richard
post #187 of 572 Old 04-25-2012, 03:54 PM
krnkimchi702
1995 XJ Cherokee
thanks to you, i now want a front diff cover....
btw thats a nice looking red cherokee lol
krnkimchi702 is offline
post #188 of 572 Old 04-25-2012, 04:20 PM Thread Starter
billzcat1
2003 WJ
Ehhhhh it's alright.
For the diff cover, yeah that's a good mod to keep in mind. I popped my ZJ's diff cover into a rock on Fortune Creek trail. It wasn't enough to puncture it, just enough to break the RTV seal and make it leak.
So if you do a diff cover, get a Lubelocker with it. That way it stays sealed as long as the bolts are still in it. The SOLID diff covers are a really good deal at $65 each. I got a heck of a deal on the Riddler diff cover and a Lubelocker from a forum vendor and also got free shipping which was nice, the diff cover is heavy. Another thing that maybe you have already gleaned from the thread - get Grade 8 bolts for the cover. The Grade 5s that came with my diff cover won't hold enough torque for the Lubelocker to stay compressed, at least mine started stretching when I changed the fluid (after that trip through the water holes at Tahuya). Had to go Grade 8 anyway, might as well do it up front. And this time we'll skip the True Value. 3 bolts, what's the deal with that?!
~Richard
post #189 of 572 Old 04-25-2012, 10:52 PM
krnkimchi702
1995 XJ Cherokee
btw i enjoyed reading your trip reports.. hopefully i'll be able to join the pictures soon. im crossing my fingers that with all the snow we got, the trails didn't get washed out
post #190 of 572 Old 04-25-2012, 11:17 PM Thread Starter
billzcat1
2003 WJ
Most definitely. We'll probably hit Tahuya again in May, just because there's nothing else we can get to right now that isn't either closed or under 4' of snow. The great wheeling up in the Cle Elum area won't be passable until late July. That's my favorite place to go and there are 2 or 3 good trails up there that I haven't fully explored.
~Richard
post #191 of 572 Old 04-28-2012, 10:56 PM Thread Starter
billzcat1
2003 WJ
Man this thing hauls a load. I've been freshening up the landscaping here when I can, replacing bare dirt with bark. I've been picking up bark in 2 cu ft bags. Hauled 20 bags today and could have easy gone to 25 possibly 30. And it didn't squat down under load. Love it.
Power steering is leaking enough that it has it's own 6" spot on the floor next to the 6" oil spot from the driver's side valve cover gasket. The hoses look fine, it appears to be a reservoir leak.
~Richard
post #192 of 572 Old 04-28-2012, 10:58 PM
narnwv
narnwv's Avatar
I believe that's the Jeep's self-lubricating chassis.
~Aaron
narnwv is offline
post #193 of 572 Old 04-29-2012, 12:02 AM Thread Starter
billzcat1
2003 WJ
It's not nearly as self-lubricating as say... a British car. Those don't just self-lubricate, they get rustproofing!
~Richard
post #194 of 572 Old 04-29-2012, 01:01 AM
krnkimchi702
1995 XJ Cherokee
speaking of oil, az has 5qt/filter on their mobil 1 for either 32.99 or 34.99
post #195 of 572 Old 04-29-2012, 01:33 AM Thread Starter
billzcat1
2003 WJ
Yeah, I have to make a special trip to the Walmart in Everett (20 miles from home) to get the 5-qt jugs. The closer store (12 miles) has a spot for it but is ALWAYS sold out. I did the 6-1 qt bottles thing, it was too spendy for my taste.
I might be hitting up Autozone pretty soon here. I'm about 700 miles from my 6000 mile mark. Oddly enough, after putting 22k on in my first 12 months of ownership, I've only put on 5300 miles since last July. A big part of that is my 3- mile commute (when working) followed by almost 4 months of unemployment. Another part is that we take the VW everywhere since it averages 41mpg and pulls 47 freeway.
~Richard
My '05 WK build thread. ogie WK Grand Cherokee & XK Commander Forum 36 02-12-2015 09:42 AM
ZJ dd build as i go thread BlackDaddyZJ Grand Cherokee General Discussion 151 11-05-2012 04:58 PM
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 01:45 PM
My Build Thread zjrick812 ZJ Grand Cherokee Forum 5 11-16-2010 09:10 PM
