Best Year - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Best Year
Jeep Tweaks at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep speedometer gears at rockridge4wd
Unread 11-07-2014, 02:28 PM   #1
4wheelgreg
Best Year
Just wondering what the best year for a grand cherokee for a miled build 36" tires . I have a line on a lown milage 04 but has the 6 cyl , how is that compared to the 8cyl .
Any better years for axles or trans ?
Thanks
Greg
4wheelgreg is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 03:00 PM   #2
ChrisHager
ChrisHager's Avatar
An 04 with 36" tires will be FAR from a mild build. A mildly built WJ would be a 2" lift and 31" tires. Medium build would be 3" on 32" tires with some trimming. 33" tires are getting up there for an in-depth build (when done properly).
Have a look at what dillonjm did to set his WJ up on 37s: 2001 on 37s - Building it up
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 03:08 PM   #3
derekmac
derekmac's Avatar
If a WJ on 36's is mild for you, I'd love to see your idea of wild!! Personally, I'd opt for a V8 with the 242 t-case for a starting point.
2002 WJ Olympics Commemorative Edition
245/70-17 Duratracs
2" BB
Future: 4" lift and lockers
Build thread.
derekmac is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 06:31 PM   #4
4wheelgreg
I'm new around here but my builds usually involve cummins turbo diesel ... its not a jeep but last one I built 6bt , nv4500 , 205 transfer , dana 60s with lockers , custom frame .
42"s are about average for my builds so 36's are mild .
