Bama_WJ's Build Thread - Page 76 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 03-23-2012, 01:00 AM   #1126
85IrocZ-28
Originally Posted by AgitatedPancake View Post
Why are they wanting you to convert over to kingpin? I really havent heard that much bad stuff about the balljoint axles, especially when your trying to keep the costs down!
X2. Under a Jeep, that axle will be solid. And really...if you do need to replace a ball joint, it is pretty easy.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2012, 05:33 PM   #1127
Bama_WJ
Yea, I'm just going to run with the unit bearings and ball joints. I'm not thrilled about the unit bearings that cost $190 a piece, but it's better than a $3000 conversion though.
Called and talked to EOR this morning and had them take off the conversion costs. Also going to have them add the hybrid cage into the next estimate. With this next estimate, I think it'll be pretty close to the final revision. Just have to get my finances in order.
I'll probably be placing a huge RockAuto order for all my OEM replacement axle parts and getting a new battery here in the next few weeks. I'm itching to get this thing rolling...
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 03-23-2012, 09:53 PM   #1128
TX-WJ
TX-WJ's Avatar
Glad to see your parts are finally rolling in!. I'm also glad you got to keep your job, I want to see your Dub's transformation.
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 03-23-2012, 10:29 PM   #1129
Bama_WJ
Same here! And thanks man, can't do much without an income!
Also forgot to mention that EOR will be ditching the radius arms in favor of a 4 link. Should be a slick setup when it's done!
Daniel
North Alabama Jeep
Unread 03-23-2012, 11:35 PM   #1130
mrJ
2002 KJ Liberty
You're gonna love the 4 link
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 12:16 AM   #1131
mtnmarc
Is the rear gunna be 4 linked too?
Triangulated uppers?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 03-24-2012, 12:17 AM   #1132
mtnmarc
Unread 03-24-2012, 11:29 AM   #1133
Bama_WJ
Yea, the rear was always going to be 4 linked since I'm using a Clayton kit.
Daniel
North Alabama Jeep
Unread 03-24-2012, 02:42 PM   #1134
Bama_WJ
Figured I'd offer a bit of tech. So far, it's been a chore to try and find decent specs on the 99-04 Superduty D60 axles. Finally ran across an awesome PDF spec sheet of ALL the Dana axles.
Go here to view all the axle specs via PDF.
For 99-04 Ford Dana 60 SRW front axles:
  • BOM #: 611159
  • Part #: 2002694 (-1 and -2)
  • U-joint: 5-806X
  • 30 spline 1.31" stub shafts
  • 35 spline 1.5" inner shafts
Shaft specs:
Short side (driver side):
  • Overall length: 24.70"
  • Stub shaft: 9.31"
  • Inner shaft: 15.39"
Long side (passenger side):
  • Overall length: 46.93"
  • Stub shaft: 9.31"
  • Inner shaft: 37.62"
Daniel
North Alabama Jeep
Unread 03-25-2012, 08:48 AM   #1135
GraKee99
Rapist Wit
GraKee99's Avatar
Sounds like you almost shouldn't have bought anything for your jeep. :-P you still planning coilovers?
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 03-25-2012, 08:53 PM   #1136
Bama_WJ
It would have happened at one point or another.
And yea, still doing coilovers. I'm more than likely going to run 2.5 King IBP coilovers.
Daniel
North Alabama Jeep
Unread 03-30-2012, 01:35 PM   #1137
Bama_WJ
Finally got myself a new battery today. I picked up a stock sized (Group 65) DieHard Platinum. This thing has 930 CCA's! My Group 34 Optima only had 850. Can't wait to pick up another one for dual batteries. Then I'll have 1860 CCA's...nothing will stop me!
Daniel
North Alabama Jeep
Unread 04-01-2012, 02:58 PM   #1138
Bama_WJ
Looks like more parts are going up for sale...
- JCR Sliders
- HID LF 240s
I'll probably ship the lights. Going to be local only for the sliders.
(I'm sold on the Rigid LED lights. Now I'm planning on adding a 40" for the top of the hybrid cage. )
Daniel
North Alabama Jeep
Unread 04-01-2012, 03:14 PM   #1139
mrJ
2002 KJ Liberty
i hear ya on the rigid. a couple guys in the local club have the pairs of dually's on their jk's that they got on sale at 4wheelparts for $158/pair. and that's all they need. period. the light output is amazing. i'm going to pick up a pair for the dub. i think the 40" is a little overkill, but hey, if you got money to burn, more power to ya.
Unread 04-01-2012, 04:28 PM   #1140
Bama_WJ
Nice, I'm wanting to pick up some dually lights as well. The 40" is on my maybe list, but I still definitely want the 20" up front.
Daniel
North Alabama Jeep
