Bama_WJ's Build Thread - Page 62 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
1993-2004 Jeep Grand Cherokee Steering Damper Trail Boss (50" LED CREE Light Bar Pair With Wiring KitSteering and more from Ruffstuff!
Unread 07-17-2011, 10:27 AM   #916
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by JJAMISON_ View Post
Beadlocks aren't a bad idea for rock crawling and such but you shouldn't need them here unless you are airing down to 4psi
Most people don't air down that low. You start to lose to much clearance at that low of a psi. I run 8psi in mine and am probably going to bump up to 9 or 10 because it is almost to low. Look at my driver side tire at 8psi when flexed.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2011, 12:46 PM   #917
Bama_WJ
Going to switch gears here for a little bit and focus on the front R&P.
The Dana 60 has both a thick and a thin gear set available. As far as my knowledge goes, the think gears are only used so people can have a deeper ratio on a 4.10 and down carrier. Is there any strength benefit to the thick gears or is all the extra material on them just to act as a "spacer"?
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 01:12 AM   #918
mtnmarc
correct, thick gears are for gears such as 5.13s working on 4.10 and down carriers.
from my readings, the teeth themselves arent stronger, the whole ring is just thicker.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 07-18-2011, 05:06 PM   #919
Bama_WJ
Yea, I'm just going to run the 4.10 and down carrier with thick gears. About done making my aftermarket parts list. Will probably be ordering stuff within the next couple weeks.
Daniel
North Alabama Jeep
Unread 07-19-2011, 08:16 PM   #920
JerzeyBoyWJ
2003 WJ
how much for your 4:88 gear sets .. and would i run into any troubles installing them.. or would anything be weaker?
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline   Reply With Quote Quick reply to this message
Unread 07-19-2011, 08:41 PM   #921
Bama_WJ
PM sent about the gears.
I don't know about the 44a, but the pinion on the 30 gets kind of small with the 4.88s. Some say you need to take easy. That's about all I know relating to strength issues.
Daniel
North Alabama Jeep
Unread 07-19-2011, 10:39 PM   #922
bracs4
hows she comin have ya starting terring down orstill waitin on parts
bracs4 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2011, 05:00 PM   #923
Bama_WJ
Haven't worked on them here lately. It's hard to work on them when they are at my parents house that's almost an hour away. But I haven't even bought any parts for the axles. Well, the Warn hubs should be here, but that's it. I plan on buying the aftermarket stuff here soon. I got all the links saved to what I need, so I'm just waiting for funds. The lockers and gears ain't cheap!
Daniel
North Alabama Jeep
Unread 07-20-2011, 11:11 PM   #924
bracs4
ya i know im buying parts for the yj slowly as well im planning a huge overhal like you are doing except with a motor swap tosed in there so i totally get it
Unread 07-21-2011, 07:26 AM   #925
r_kelly252
Looking back at 2 pages... I think you should stroke it.
I mean its the same price as a supercharger really but
http://www.titanengines.com/index.ph...g5f6pi5oi1llr0
This one is 315hp 345 ft/lbs a compression of 8.9:1 if someone really had the coin to boot a supercharger on top of that i just want to see someone do it. i mean i dont have that kind of coin just yet either.
So Bama_WJ man this thing is really coming along, i mean 62 pages on a build thread Damn!
you have inspired me to do a 44 swap as well. only i wont be doing mine in a parking lot...lol
i have a question as far as experiences go? Was it really that easy to just bolt in? also drivshaft issue. i have the stock 35/242 transfer if i had the driveshaft from the 44 you think that be use able? or 247 have dif splines?
How much did it cost you to shorten your shaft?
Thanks for the help JF
r_kelly252 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2011, 02:51 PM   #926
Bama_WJ
Eh, I'll worry about the stroker motor once the 4.0 I got takes a dump. I'm already spending a pretty penny on these axles.
Thanks though! But yea, the swap was way easy. Just bolt up and go. It just takes a little bit of time. I would think the original 44a driveshaft would work, but don't quote me on that since I don't know if the 242/247 output spline counts are the same. Personally, I used my old driveshaft and had it shortened 1.5" by a local driveline shop for $35.
So I think I'm going to order my brackets and some other stuff either today or tomorrow. What yall think of this list?
Rear
BTF: Sterling 10.25 Rear Truss System
Ballistic Fab: Coil plate mounts with retainers
Ballistic Fab: Axle tube shock tabs
Ballistic Fab: Lower Axle Link Brackets
Front
BTF: Dana 50/60/70 Kryptonite Differential Cover
Ballistic Fab: Link bracket / coil spring / shock mount combo
Ballistic Fab: Offset Panhard / Tracbar mount
Clayton Offroad: Front Upper Control Arm Bracktets
Daniel
North Alabama Jeep
Unread 07-22-2011, 03:33 PM   #927
Bama_WJ
Forgot a couple things...
Steering
Ballistic Fab: Steering Kit 7/8" with High Misalignment Spacers
Ballistic Fab: Axle tube shock tabs (flat bottom) (2 sets for hydro assist ram)
Track Bar
Ballistic Fab: XM-12/14 7/8" w/ 3/4" ball CrMo rod end w/ kevlar liner (2)
Ballistic Fab: 7/8" 18tpi Hex Tube Adapter (2)
Ballistic Fab: 1.0" ID - 1.50" OD .250" wall DOM (4 ft)
Daniel
North Alabama Jeep
Unread 07-22-2011, 11:17 PM   #928
mtnmarc
That steering isn't street legal, well California at least.
No front truss?
Unread 07-23-2011, 11:12 AM   #929
JJAMISON_
Alabama has no legality issues like Commiefornia. you can pretty much do anything here as long as the headlights are no higher than 54" (i think that is right on the measurement)
[QUOTE=threeb]My wieners are hard and black now brb gotta eat.[/QUOTE]
JJAMISON_ is offline   Reply With Quote Quick reply to this message
Unread 07-23-2011, 11:57 AM   #930
RedlegWJ
He's just looking out. The thing is most states are just following the FEDERAL DOT standards when they make those laws. It could still flare up as an issue for you later. I think he was concerned about using welded inserts on the tie rod. That's the easy way out and they probably label it as offroad only to cover themselves. If you had the DOM threaded for the tie rods, you'd be compliant. Still enjoying your project, just don't like to see anybody caught off guard.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline   Reply With Quote Quick reply to this message
