Bama_WJ's Build Thread - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-11-2009, 08:23 AM   #76
WJ04
Originally Posted by bigbluezj94 View Post
if it came off a 4.7 with a 242 behind it, (did they even produce a WJ with that combo?) then i can see the shaft being a different length. the engine blocks are different lengths....
Yes they did...V8 laredos with the HD242 said to be one of the most reliable combinations for a WJ
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 09:17 AM   #77
squashman702
1994 ZJ
axles really arent that bad to work on. as long as you know what youre getting into. I just did my first re-gear and it really wasnt as hard as i thought. VERY time consuming though. but swapping in a d44a from a 35 is just a couple bolts, bleeding the brakes and shortening the driveshaft afterwords.
If you leave your brakes attached to the Jeep, you don't even have to bleed them. That's what I did on my 5.9.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 01:02 PM   #78
bigbluezj94
1994 ZJ
unless you previously had drum brakes...
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 05:05 PM   #79
fast_man58
dont forget that the different engines also have different transmissions behind them as well. the 4.7 trans is shorter than the 4.0 trans (if memory serves me correct)
All of us could take a lesson from the weather. It pays no attention to criticism
night crew #078
fast_man58 is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 05:39 PM   #80
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Without taking off the boot and seeing how much of the slip/splines are showing it is hard to say for sure whether it is too short or not.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 07:29 PM   #81
Bama_WJ
I was thinking that earlier, I just haven't gone outside to mess with it since its been raining all day today. Didn't you have to convert over to a double cardan like I did, or did yours already come like that from the factory?
I'll probably pull the boot off tomorrow and see what's going on under there.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 08-11-2009, 08:46 PM   #82
ArloGuthroJeep
Mr. Hyde!
Neither of mine were DC...I converted both to DC.
Unread 08-11-2009, 10:49 PM   #83
Bama_WJ
I assume you did this after Claytons via Carolina Driveline?
Daniel
North Alabama Jeep
Unread 08-12-2009, 07:52 AM   #84
ArloGuthroJeep
Mr. Hyde!
Rear driveshaft is from Tom Wood (Installed the 242 SYE) and the front is a longer Carolina Driveline drive shaft (that replaced my Tom Wood drive shaft). I needed another new front drive shaft because when I pushed my axle forward to clear the 35's I was at the limit and was getting very mild vibes.
Unread 08-12-2009, 02:33 PM   #85
Bama_WJ
Just got done checking out the splines on the driveshaft.
Here is what it looks like when its in the yoke, just without the boot.
I didn't have a tape measure next to me, so I just marked the original position with my thumb.
What you guys think? Lengthen it or is it alright?
Daniel
North Alabama Jeep
Unread 08-12-2009, 03:13 PM   #86
ArloGuthroJeep
Mr. Hyde!
I would say it is right on the edge of needing to be lengthened. When it is assembled and both ends connected to the yokes, and you push/pull on the middle of the driveshaft where the two halves connect, do you have any play/slop in there? If you do, I would get around to replacing it at your earliest convenience and keep this one as a spare (that is what I did).
Unread 08-12-2009, 03:15 PM   #87
ArloGuthroJeep
Mr. Hyde!
Actually, I may be a bit confused in the pics. How much engagement do you have? It looks like you have 2-3" at least in the second pic which is plenty.
Unread 08-12-2009, 03:32 PM   #88
Bama_WJ
The second picture shows how much engagement I have. And yes, I would say at least 3" of splines are left.
Whew, glad I can put my mind at ease on that issue.
Daniel
North Alabama Jeep
Unread 08-12-2009, 04:49 PM   #89
skain8
Bama,
It came straight from my 4.7L. I'm not sure what the issue is with your set-up, unless your axle is pushed too far forward. In any event, if you have 3" splines left, I'd say you're set.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
Half-Ton axle swap guide
231HD build info
skain8 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2009, 06:41 PM   #90
Bama_WJ
Originally Posted by skain8 View Post
Bama,
Yea, I guess I just figured it would slip in there like CV shaft did; a bad assumption on my end. The only thing that was putting up a fight was the rubber boot which made it a chore to place into the axle yoke. I slid the top part of the boot down a little bit and its perfect now.
Thanks folks.
Daniel
North Alabama Jeep
