Bama_WJ's Build Thread - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
Unread 08-01-2010, 09:57 AM   #376
lakailimited06
i also needed an adjustable track bar with my first spacer lift i had bad DW as soon as id hit any little bump on the highway...all my steering/suspension components seem to be in good shape and i still get the occasional steering shimmy on certain bumps...
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 12:11 PM   #377
Bama_WJ
Originally Posted by GraKee99 View Post
I ran a JKS track bar with my BB.
When I did my last lift, I replaced my JKS bushing in the track bar with a new KOR bushings (the stiffer ones) and also replaced all my TRE on my draglink and tie rod and even picked up a JKS tie rod. Then, I finally moved my SS up higher so it is on the draglink and track bar. No death wobble to this point.
I would check the steering box being loose and then for an ovaled track bar hole.
I plan to check stuff tonight. Can't really do anything cause I have to drive 3.5 hours tomorrow to pick up my bumpers. Only thing I'm really worried about is the weight of the bumpers knocking the jeep out alignment and causing worse death wobble.
This a lot like what's happening to mine. Some bumps I can go over fine, while some make the jeep start wobbling but dampen off, while some cause me to go to straight death wobble.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 06:52 PM   #378
Bama_WJ
Well, I had someone steer the Jeep back and forth to see if anything looked out of place. Just wondering, does it matter if the Jeep is steered with the engine running? Or does it need to be off? I also tried tightening the steering box, but couldn't really tighten them anymore.
Well, I had the engine on, so it had power steering. It seems like the track bar at the frame moved quite a bit for only sitting still. Could the bushing be shot or do you think the hole is ovaled out? I don't really have time to mess with taking the track bar off right now since I have to drive it tomorrow. I guess I'll check it out when I get back from KMA tomorrow.
Daniel
North Alabama Jeep
Unread 08-01-2010, 07:18 PM   #379
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
It doesnt take much to take the bolt out and drop the TB.. i can adjust my tb in maybe less than 10 minutes. If the tb is moving then I would just go ahead and point at the problematic ovaled out hole. It seems like almost all WJ's have this problem. How many miles do you have on your jeep?
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 09:02 PM   #380
JJAMISON_
2015 JK Wrangler
Dan if you can't go over call me. I will be glad to put your bumpers on my heep.
JJAMISON_ is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 09:06 PM   #381
Bama_WJ
Yea, I know it doesn't take much, but I'd rather keep it together for a 300 mile round trip tomorrow. I mean my death wobble is not really a big serious problem. It's more of an annoyance. I can still drive the Jeep 95% of the time and not get death wobble. I've never gotten death wobble on the freeway either. So I'm not really concerned about it until I get back tomorrow night.
I'll check it out for sure tomorrow night.
Daniel
North Alabama Jeep
Unread 08-01-2010, 09:09 PM   #382
Bama_WJ
Nice try. I'll holler at ya if I have a problem though.
You're basically at the halfway point.
Daniel
North Alabama Jeep
Unread 08-01-2010, 09:46 PM   #383
JFox21
So you're getting the Wincher and Multi-Carrier tomorrow?
Jamie
Sophomore at Santa Clara University
JFox21 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2010, 10:50 PM   #384
Bama_WJ
That is correct.
Daniel
North Alabama Jeep
Unread 08-03-2010, 10:58 AM   #385
Bama_WJ
So I got my bumpers back home without much incident. Only got death wobble once cause I had to slow way down to about 50 and then hit a pot hole that would eat a Honda alive. I mean it was big and the deteriorating patchwork to somehow fix the hole made it that much worse. I'll be pulling the track bar tomorrow to see what's up.
As far as the bumpers, I'm pretty happy with them. I'll like them more once they are all painted up probably. I'll throw some pictures up tonight before I pull them off to paint them.
Daniel
North Alabama Jeep
Unread 08-03-2010, 02:33 PM   #386
lakailimited06
you notice any lag after having the bumpers put on? after making both of mine it is unreal how slow my WJ is lol DEFINITELY no way to overgear a WJ the lower the better...
99WJ 4.0
Unread 08-03-2010, 02:41 PM   #387
Bama_WJ
Yes, its real sluggish now. I need 4.10s to carry this extra weight around.
Daniel
North Alabama Jeep
Unread 08-03-2010, 04:29 PM   #388
HaViiK
Hurry and get pics of the bumper, I worked all day and I wanna see these bumpers. lol.
sorry for the hijack, but Lakai, how did the gears treat your gas mileage? just curious.
[SIZE="2"][COLOR="DarkRed"]Steven, New HaViiK[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f197/haviiks-01-wj-slow-build-1067820/"][COLOR="DarkRed"]Black HaViiK:[/COLOR][/URL] [COLOR="DarkRed"]2001 WJ, 4.0, 42re (rebuilt at 100k), 30/35, Rough Country X-Series, JCR Stage 3 Sliders, Yakima Megawarrior & Big Powderhound, Grille Guard, KC Daylighter 130w, Custom Sub Box & 2 Kicker 12" CVR
[/COLOR]
[SIZE="2"][URL="http://www.jeepforum.com/forum/f13/zj-wj-faqs-read-first-contact-mod-changes-additions-591821/"][COLOR="DarkRed"]WJ/ZJ FAQ[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.facebook.com/steven.T.wright"][COLOR="DarkRed"]Facebook. Wheeling stuff in there.[/COLOR][/URL][/SIZE]
[SIZE="2"][URL="http://www.youtube.com/user/Thunderheadrcx?feature=mhee"][COLOR="DarkRed"]Youtube Channel. GoPro/Wheeling stuff[/COLOR][/URL][/SIZE]
[QUOTE=rulppa(chat);10944366]whats with people (steve) with those monster sigs. reply is usually like ':E' then 2 pages of signature lol[/QUOTE]
[QUOTE=Sarahdactyl;11226293]THE WINNER IS REDHOTCHILIDOG!!!!111!!1!!!!(OBNXIOUS HUGE BEEFSTEW STYLE FONT) I will PM winner for details[/QUOTE]
HaViiK is offline   Reply With Quote Quick reply to this message
Unread 08-03-2010, 05:24 PM   #389
GraKee99
Rapist Wit
GraKee99's Avatar
I have already seen the front bumper on it.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2010, 05:36 PM   #390
Bama_WJ
Ask and you shall receive.
First off, I want to say Kyle at KMA tried his hardest to get me what I wanted on the bumpers. He gave me straight up honest answers to my questions and seemed to know what he was doing/talking about. So, a for that.
The front bumper fits great. Could use an extension on the sides to cover the fenders a bit better, but it's not a real big deal. The back however needs some work, especially if I wasn't going to be cutting my fenders. But since I am cutting the fenders sometime down the road, they will line up just about right looks like.
On to the pictures:
Already put a light coat on the carrier.
And one more...with the LF 240s.
Well, there you have it. Off to a lot of painting. Will have more pics once they are painted. Not to mention light output pictures.
Daniel
North Alabama Jeep
