Bama_WJ's Build Thread - Page 21 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-24-2010, 11:38 PM   #301
Bama_WJ
Well, got a BTF 44a cover on the way. Hopefully it will be here by Saturday. Any suggestions on some good colors? Maybe a dark red or gunmetal?
Pulling the transfer case tomorrow to replace some seals. Going to clean it up real good. Hell, might throw a coat of dark silver on it to make it look new.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 06-25-2010, 04:32 PM   #302
Bama_WJ
Ok, some questions.
Pulled the transfer case out just now. Was going to replace the input seal to the transfer case and that was it, but it seems that the bad seal is the output of the 42RE. Reason I say that is I brought the Jeep up to temp and checked the trans level while in neutral and the line of ATF didn't even reach the first hole on the cold part of the stick. Yikes. Would an input seal to the transfer case just be evident by ATF coming out of the weep hole at the bottom or what? My leak had shown up all the way up on the side of the trans/transfer case. Would this assumption be right?
Anyone know a part number for a 42RE output seal at advanced, autozone, or somewhere?
Daniel
North Alabama Jeep
Unread 06-25-2010, 10:12 PM   #303
Bama_WJ
Well, just got the Jeep back together. Went ahead and put a new trans output seal on since the case was off. Input and output on the transfer case were changed. Hopefully that will stop my leaks from that area.
The rear diff is still leaking. I'll probably fix it with this...
This BTF cover is bulletproof. Soooo beefy its ridiculous. Think I'm going to paint it a dark red.
Daniel
North Alabama Jeep
Unread 06-25-2010, 10:21 PM   #304
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
Pure beef.. but personally I love the look of black, or that gunmetal than clninja has.
MoonyJohn is online now   Reply With Quote Quick reply to this message
Unread 06-25-2010, 10:37 PM   #305
WJ04
I think you should paint it the color of your jeep. I painted mine Silver and added the same decal I have on my fender to the diff, my jeeps name is ''The Punisher" so I found it fitting.
My jeep:
My 44hd:
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote Quick reply to this message
Unread 06-26-2010, 09:31 AM   #306
RedZJ
Taste Like Chicken
RedZJ's Avatar
Woah beefy. I think you should do it the color of the jeep.
RedZJ is offline   Reply With Quote Quick reply to this message
Unread 06-26-2010, 12:14 PM   #307
Bama_WJ
Yea, just picked up some red paint to match it pretty good.
So the output of my transfer case is STILL leaking. I don't know what the hell is wrong with it.
Edit: Going to replace the breather hose with one that goes up to the engine department. Maybe that will help, cause I don't see how a seal can go bad after less than 30 miles.
Daniel
North Alabama Jeep
Unread 06-26-2010, 12:53 PM   #308
SaturnICL
Tailshaft bushing is probably worn.
[QUOTE=FPKites;7800928]You're all wrong....he's making side stingers
:rofl: :rofl: :rofl:[/QUOTE]:)
SaturnICL is offline   Reply With Quote Quick reply to this message
Unread 06-26-2010, 01:01 PM   #309
Bama_WJ
The bushing on the crossmember?
Daniel
North Alabama Jeep
Unread 06-26-2010, 01:21 PM   #310
SaturnICL
No it is a brass bushing in the tail housing of the t-case they wear out esp. with a lift.
Unread 06-26-2010, 02:07 PM   #311
Bama_WJ
Do you maybe have a part number or something? I don't remember a brass bushing when I took it apart to put a new chain in. I don't have a 242HD, just a regular one. Maybe that's the difference?
Daniel
North Alabama Jeep
Unread 06-26-2010, 02:39 PM   #312
SaturnICL
I apologize I did not realize you had the 4.0 w/242 ignore me
Unread 06-27-2010, 01:00 AM   #313
Bama_WJ
Ok. I'm still stumped on this oil seal problem though. I guess I'll have a look at my transmission mount tomorrow. I'm getting really tired of smelling burnt ATF on my cat.
Daniel
North Alabama Jeep
Unread 06-27-2010, 09:41 AM   #314
fireman33
2003 WJ
I have the same problem on mine...cat is all gummed up with tc oil...if it would only be that its not so bad of a problem...its just that im scared the jeep catch on fire lol.
98% of Canadian say '' oh **** '' before taking the ditch in winter time. The other 2% are from New-Brunswick and say '' hold my beer and watch this ''
2003 WJ 4.0, 4'' IRO Critical Path, 31x10.5x15 goodyear wrangler territory on soft 8's, Tom Wood front drive shaft, Rough country SS, 4.56 G2 gears, D30 front, D35 rear/detroit trutrac, IRO adj. trackbar, Doetch tech 8000 shocks, nv242 TC, midland cb, 3' firefly antenna, Mopar TC Skid
My build thread--> http://www.jeepforum.com/forum/f197/...-build-957216/
fireman33 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2010, 01:01 PM   #315
Bama_WJ
Well, I pulled the driveshaft off again to look at the seal. It was fubar'd as I expected. What happened was the lip of the seal that contacts the shaft slipped into the groove where a lock ring is supposed to go and just screwed up the seal. Guess I'll be making a trip to the nearest Jeep dealer to buy some lock rings to hopefully stop this once and for all.
Going to prep and paint my diff cover right now.
Daniel
North Alabama Jeep
