Bama_WJ's Build Thread - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Bama_WJ's Build Thread
Ruffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-08-2010, 01:43 AM   #166
Shinobi
looking good man !! I want one now
Shinobi is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 07:51 AM   #167
tennesseewj
That is sweet
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 04:32 PM   #168
Bama_WJ
The axle is back in! Finally. Me and some buddies put it in with it about 20 degrees out and snowing. We didn't really have any problems at all, so that was nice. Locker works awesome and the truss looks great!
I really need to do the gas tank lift...
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 10:28 PM   #169
TX-WJ
TX-WJ's Avatar
Good stuff man! Keep it up.
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 10:31 PM   #170
GraKee99
Rapist Wit
GraKee99's Avatar
*cough cough* I need mine. *cough*
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2010, 12:05 PM   #171
XJ_Renegade
Your gas tank looks all beat up like mine does. Is that a factory skid plate, or the "brush guard"? I'm still trying to figure out what mine has.
Truss looks sweet, btw.
1999 XJ - 31s on 6"
1998 ZJ - I'll show you my Niner if you show me yours.
XJ_Renegade is offline   Reply With Quote Quick reply to this message
Unread 01-28-2010, 10:39 AM   #172
BoostinNRS
What did you finish your rock sliders with? I think I'm going to order some soon.
98 xj
04 SRT-4 (sold)
BoostinNRS is offline   Reply With Quote Quick reply to this message
Unread 01-28-2010, 11:30 AM   #173
Bama_WJ
Just some semi-gloss rustoleum from a rattle can. I respray them like once a year.
Daniel
North Alabama Jeep
Unread 03-05-2010, 09:22 AM   #174
Bama_WJ
Just wanted to post in here real quick to see if I could gauge interest on selling my IRO adjustable track bar. I kind of decided I didn't need it anymore a while ago since I'll be buying the claytons 6" kit which already has the JKS adjustable track bar in it.
So any initial interest at all? $100 plus shipping maybe? Trade for a Herculiner UV kit?
Daniel
North Alabama Jeep
Unread 03-06-2010, 05:01 PM   #175
Bama_WJ
Looks like I'm going to be buying some Monstaliner early next week. That means I'll be doing some big fender cutting in a couple weeks. And while I'm at it, I might as well raise the gas tank.
Daniel
North Alabama Jeep
Unread 03-18-2010, 01:11 AM   #176
Bama_WJ
Hmm...
Daniel
North Alabama Jeep
Unread 03-18-2010, 01:23 AM   #177
lateralus3
1994 ZJ
no more dirty diaper lol
[CENTER][B]Jacob[/B]
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
[URL="http://www.jeepforum.com/forum/f197/lateralus3s-slow-build-thread-1042086/"]my build thread[/URL][/CENTER]
[CENTER][SIZE="5"][COLOR="Red"]FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED[/COLOR][/SIZE][/CENTER]
lateralus3 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2010, 06:19 AM   #178
GraKee99
Rapist Wit
GraKee99's Avatar
Sweet.... harbor freight angle grinder.
Brian
WJ, WK, CJ5
Unread 03-21-2010, 12:39 AM   #179
Bama_WJ
Well, my spring break has come to a close. I kept myself pretty busy with the Jeep over the past week.
Pulled my sliders off and repainted them. Gloss black this time instead of the satin that I've had on there. There was so much rust on them...
Next, as the picture in the above post implies, I did the gas tank lift. This marked the first metal to ever be cut on my Jeep. I basically followed Lakai's gas tank lift procedure. First, I took the bumper off. Found a nice little suprise there. Guess the PO got rear ended and never reported it, so it didn't show up on the carfax.
Looks like it tweaked my skid pretty good as well.
From there, I dropped the tank. You just unbolt the skid from the "frame" and it falls right down.
Undo the straps from the top of the tank and just pull the tank out. It helped me alot since I had like no gas in it.
I had about 1/4" of mud/sand in between the gas tank and the skid plate itself. There was alot of it...
Taped off the tub so I could make a decent straight cut with the grinder.
That first cut into the Jeep was the hardest. After that, its cake.
Tub completely out.
Next, I cut the top of the skid in order to keep the finished product "bolt-on". Made sure to keep enough to weld to as well. Then I cut maybe 3" off the sides to make the skid shorter.
Moved to the tub next. Did the same thing as SaturnICL did on this part. Cut off about 4" off the top of the tub. I didn't have duck bills, so I just used two channel locks to bend the outsides of the tub outward.
Mounts welded back up.
Daniel
North Alabama Jeep
Unread 03-21-2010, 12:42 AM   #180
Bama_WJ
When it came time to put things together and cover the hole with the bottom of the original tub, it did not want to cooperate at all. Guess I didn't bend the metal out far enough. So, I ended up abondoning the whole tub covering the hole idea. My girlfriends stepdad has a HVAC business and he let me buy an almost 5'x5' sheet of 24G stainless from him for $20 so I could cover the hole in the back of my Jeep.
Did some cutting and measuring and came up with this...
Laid it down under the carpet and used zip screws to secure it. Sealed it up with clear gutter silicon.
Cover back on. Don't even know anything is out of place.
All done. Where'd it go!?
Decided to clean the axle up and paint it since it can be seen by everyone else now.
I was planning on cutting the fenders up this week as well, but didn't have enough time. I got the bedliner in, so I can do that when I get back home from school. Well, that's about it for now.
Daniel
North Alabama Jeep
