Bama_WJ's Build Thread - Page 87 - JeepForum.com
post #1291 of 1481 Old 05-02-2013, 05:44 AM Thread Starter
Bama_WJ
I don't know who all has seen the WJ that one of the IRO employees runs, but I love how he did the trimming in the rear. I'd really like to do something like this...
(Image courtesy of IRO Facebook page)
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #1292 of 1481 Old 05-02-2013, 09:04 AM
mtnmarc
They finally painted it. Last time I saw pictures of it, it was multiple colors. Haha.
I like it. Its really clean. At first glance I seriously thought it was a zj for some reason.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #1293 of 1481 Old 05-02-2013, 10:03 AM
TJSWJ
x2 when I looked at in on my phone I thought it was a zj
TJSWJ is offline
post #1294 of 1481 Old 05-02-2013, 11:48 AM
mtnmarc
I've thought about doing a cut like biggoofys on his zj. And also something like Greg's. Where the wheel well is cut and extended a few inches.
mtnmarc is offline
post #1295 of 1481 Old 05-02-2013, 01:20 PM Thread Starter
Bama_WJ
Just wish I could see how he filled in the gaps from the inner and outer body panels. I got a bunch 22-ish gauge stainless sheet metal that I can use to fill any larger gaps if need be.
Daniel
Bama_WJ is offline
post #1296 of 1481 Old 05-03-2013, 09:18 PM Thread Starter
Bama_WJ
Got a wild hair and pulled the grinder out today...
Might have taken a little much on the bottom side, but oh well. I think it turned out pretty good. I've only done the driver side as of right now. I'll get around to the other side later this weekend probably. Now the inside of the fender needs some "massaging" to get the most out of the fender trimming.
Daniel
Bama_WJ is offline
post #1297 of 1481 Old 05-03-2013, 09:31 PM
dillonjm
2013 WK
Looks good.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #1298 of 1481 Old 05-03-2013, 09:43 PM
TJSWJ
Looking good! Thats what I have to do to mine before my next wheeling trip. I have the rears done, just never got around to doing the front.
TJSWJ is offline
post #1299 of 1481 Old 05-04-2013, 03:56 PM Thread Starter
Bama_WJ
Thanks guys. I worked on getting the fender I did yesterday painted up. Figured I try that paint match spray paint from Duplicolor again after good results on my 44a diff cover.
Turned out somewhat decent. I'll probably work on it again after it cures. I don't think I'm going to tape off the other fender when it comes time to paint. The paint matches awesome, so it'll blend with the factory paint pretty well.
Daniel
Bama_WJ is offline
post #1300 of 1481 Old 05-04-2013, 07:15 PM
clgielin
2003 WJ
The trimming looks good! I had to do a lot of additional cutting of the fender bracket behind the headlights. A quick coat of black undercoat will make the fenderwell 'look bigger'.
Chris
2003 WJ 4.7L
Build Thread Here:
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #1301 of 1481 Old 05-05-2013, 07:00 PM Thread Starter
Bama_WJ
Thanks man. Some more trimming on the inside is still on my to do list. Thinking about just getting rid of everything outside of the "frame rails".
And the inner fender definitely will get a coat of black when its all said and done. It needed it either way.
Daniel
Bama_WJ is offline
post #1302 of 1481 Old 05-17-2013, 10:13 PM Thread Starter
Bama_WJ
Cleaned up some more of the inner fender on the driver side and got the passenger side cut and painted. Had all the intentions of cutting everything outside the 'frame rails' but don't really know where to mount stuff after its cut off. There is a decent size box and horns on the passenger side and something for the evap system on the driver side. I've been cruising the net for pictures but haven't had any luck.
Part I'm talking about. Everything right of the frame hole I want to take off.
I feel like I'm trimming for 40s instead of 37s.
Daniel
Bama_WJ is offline
post #1303 of 1481 Old 05-18-2013, 08:30 PM
TJSWJ
I would think that by time you have to cut that much out, you would also have to worry about contacting the headlights. You plannin on 40's now?
TJSWJ is offline
post #1304 of 1481 Old 05-18-2013, 10:31 PM Thread Starter
Bama_WJ
After looking at it for a little while, I figured everything out. Relocated the horn and evap stuff so all is well.
Right now a few coats of gloss black are drying over the whole front end. Also gave the inner fenders some new paint, too.
Eh, I don't know yet. Maybe when the 37s I got wear out. I'll have enough gear in the axles to warrant 40s if I want.
Daniel
Bama_WJ is offline
post #1305 of 1481 Old 05-19-2013, 03:27 PM Thread Starter
Bama_WJ
I got my front end "trimming" project finished up today:
I really like how it turned out. Now I just have to do the rear...
Daniel
Bama_WJ is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
