Bama_WJ's Build Thread - Page 60 - JeepForum.com
post #886 of 1481 Old 07-12-2011, 08:05 PM
GraKee99
Rapist Wit
GraKee99's Avatar
I have been doing research on coilovers and have been talking with downtownCb over on mallcrawlin. He is an engineer and has them on his zj.
I got exactly what you need to run, specs and all and got spring rates from saturnicl so let me know if you change your mind.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #887 of 1481 Old 07-12-2011, 08:57 PM
AgitatedPancake
Ya know Brian, I'd actually be curious to see those numbers too! Sooner or later my WJ will end up on coilovers
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #888 of 1481 Old 07-12-2011, 09:10 PM
biggoofy
Im gonna go with sooner rather than later foo
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #889 of 1481 Old 07-12-2011, 09:19 PM
AgitatedPancake
haha they're pretty far down my project list, the 205 happens after this dovenose, and whatever else might try to break in the meantime
Build Thread:
post #890 of 1481 Old 07-12-2011, 10:21 PM
bracs4
those axles are sick i cant wait im hpin to do spring over and d60s so its guna be a huge jeep its a shame you arnt up at purdue anymore i havnt wheeled with anyone from the forums no very many jeeps as all my northern hillbilly friends have pickups so
bracs4 is offline
post #891 of 1481 Old 07-13-2011, 07:11 PM
mtnmarc
foa ftw
12's for the rear, and 14's for the front. no pics of the front right now
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #892 of 1481 Old 07-13-2011, 07:58 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Who knows what will happen. Go ahead and post those coilover specs if you want Brian, they may come in handy sometime down the road!
So I've been giving my gearing choice some thought today. I was originally going to do 5.13, but now I'm thinking 5.38. I figured since it's no longer my DD, I can afford to have a deeper ratio if I wanted. Plus after doing some tire size to rpm and gear ratio calculations, it came out to be pretty darn close to stock with the 37s and 5.38s. So I think I might go with 5.38s.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #893 of 1481 Old 07-14-2011, 12:59 AM
mtnmarc
Oh that's good to know about the gears. I have 37s, and I was planning on 5.13s. But 5.38s were in the back of my mind.
mtnmarc is offline
post #894 of 1481 Old 07-14-2011, 10:33 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
The choice of 5.38s was also based on the fact that I have the 4.0 and these axles probably weight twice as much as the stock ones.
Might be a good excuse for a stroker motor sometime down the road.
Daniel
Bama_WJ is offline
post #895 of 1481 Old 07-14-2011, 06:27 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
37" Kevlars are actually in stock for once for $323/tire. I'm so tempted to go ahead and buy them now just so I have them instead of risking them being on back order later.
Daniel
Bama_WJ is offline
post #896 of 1481 Old 07-14-2011, 08:42 PM
JJAMISON_
2015 JK Wrangler
don't do a stroker, Superchager it!
JJAMISON_ is offline
post #897 of 1481 Old 07-14-2011, 11:46 PM
bracs4
but have you decided one wheels
bracs4 is offline
post #898 of 1481 Old 07-15-2011, 08:28 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Haven't decided exactly what wheels I want yet. I'm still looking at beadlocks to be honest.
Daniel
Bama_WJ is offline
post #899 of 1481 Old 07-15-2011, 09:30 PM
bracs4
well if you order tires then that kind of limits your choices on whatr wheels just saying not meaning to rain on your parade
bracs4 is offline
post #900 of 1481 Old 07-16-2011, 08:51 AM
GraKee99
Rapist Wit
GraKee99's Avatar
He is going 17s, we already know that. Just get beadlocks, you will be running 37s.
And for specs on coilovers, here is what I found out.
For coilovers, reservior is the way to go. If you go foa, get the billet preload, billet cap qith replacable heims and the 90 degree swivel . High temp seals are optional, depends if you are going to be drive baja style with them. (I will ) As far as valving, Cody hasn't got back to me yet but seems for mainly rockcrawling, med is the way to go on both but don't quote me on that. I am still trying to figure that out. And for springs on the WJ, 250/300. That is what SaturnICL ran on his WJ both front and rear.
And my plan is 14" coilovers front and rear. Cody runs claytons on his zj and said that is max amount of travel you get out of it.
Brian
WJ, WK, CJ5
GraKee99 is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
