Bama_WJ's Build Thread - Page 59 - JeepForum.com
post #871 of 1481 Old 07-08-2011, 11:04 AM
AgitatedPancake
It makes it really nice for squeezing in all the components. With it done the way I did, you can actually fine tune the length of the high steer arm between where the drag link ends and the pivot point of the knuckle (kingpin/balljoint). For example on my 44 when I ran true crossover high steer, trying to squeeze both the tie rod and drag link onto a single steering arm basically forced my drag link to be as far out on the steering arm as possible, which in turn didn't allow me to have full turning. Now, I can drill a couple of holes on the arm and try out a few combinations to get absolute max turning out of it.
Also with crossover high steer like I had it was almost next to impossible to squeeze a well balanced track bar into the mix haha, which is a problem I eliminated with the new setup.
The stock tie rod points are actually pretty high up on the ford knuckles, so by simply drilling them from the top my tie rod actually sits pretty high up, at the top of the axle tube
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #872 of 1481 Old 07-08-2011, 12:03 PM Thread Starter
Bama_WJ
Good to know. I think I'll do that.
For anyone wanting to know about reaming for chevy one ton ends, go here. How to and correct reamer:
http://www.pirate4x4.com/forum/showthread.php?t=793122
And I found a right side knuckle for a high steer drag link. Just one cast knuckle, easy, no fuss:
http://completeoffroad.com/i-2748905...m71030-02.html
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #873 of 1481 Old 07-08-2011, 02:28 PM Thread Starter
Bama_WJ
Since I'm ditching the crappy vacuum hubs, I just bought myself some of these...
Daniel
Bama_WJ is offline
post #874 of 1481 Old 07-09-2011, 07:43 PM
HookEm
Lovin the dub. How much were you wanting for the 2.5 BB, are you selling the shocks with the pucks too? How many miles you think you have on them? Thanks
HookEm is offline
post #875 of 1481 Old 07-09-2011, 09:31 PM Thread Starter
Bama_WJ
Thanks man. PM sent about the lift and shocks.
So I went back to my parents house to work on the axles again today. Worked on the S10.5 for the most part. Cleaned it up a bit, took the massive axles out and got the braking hardware off. Tried getting the ball joints out of the driver side knuckle, but they wouldn't budge at all with my ball joint clamp. But for the most part, the axles are torn down to the point where I can order all the OEM replacement parts for them. So that's the next phase which will be a couple weeks out.
And I'm starting to hope that the coil pads on the axle won't be to far apart that the springs will be bending outwards. Cause there ain't much room for the coil pad on the passenger side even if I cut the casting back a bit.
Daniel
Bama_WJ is offline
post #876 of 1481 Old 07-10-2011, 09:02 PM
MoonyJohn
Nice man, you can always take a measurement from your coil springs where they are now and then measure the width of the axle. Id imagine that they might be a little wider than the wj, but hopefully not by much if it is.
MoonyJohn is offline
post #877 of 1481 Old 07-10-2011, 10:15 PM
AgitatedPancake
IIRC, my spring spacing on the axle is around 38" between the two.
While you have the knuckle loaded up under pressure in the ball joint clamp, spray the balljoint with WD-40 or penetrating oil. If that alone doesn't work, try shock loading the balljoint while under pressure. A few taps in the same direction as removal usually helps get them started
Build Thread:
post #878 of 1481 Old 07-11-2011, 12:03 AM
bracs4
im really digging the grand i came real close to buying one before i bought my yj added you on facebook by the way i really like the direction this is headed
bracs4 is offline
post #879 of 1481 Old 07-11-2011, 08:16 PM Thread Starter
Bama_WJ
From the looking around that I've done, I think the space between the inner knuckles is going to be JUST wide enough for the springs.
Yea, from looking over the Clayton CAD drawing for the front axle (FOUND HERE), the width between the spring center lines is pretty much right at 37-3/8". And according to BillaVista's 60 Bible, the leaf perches on the stock axles were 36-1/2" apart. So I think I'm sitting pretty as of right now.
And thanks for the ball joint tips. I'll have to try those out!
Thanks man! Good to see who it was that friended me.
Daniel
Bama_WJ is offline
post #880 of 1481 Old 07-11-2011, 09:19 PM
theksmith
2003 WJ
just read the last few pages and got caught up on your build - those axles are insane, can't wait to see it done.
theksmith is offline
post #881 of 1481 Old 07-11-2011, 10:04 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Just do coilovers. Problem solved.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #882 of 1481 Old 07-12-2011, 04:57 PM Thread Starter
Bama_WJ
Thanks! And you're not the only one!
Believe me, I've seriously thought about it. But I figured I'd try the springs that I already have. Need to spend money in other places.
Daniel
Bama_WJ is offline
post #883 of 1481 Old 07-12-2011, 06:16 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Have you looked at FOA? They actually aren't bad in price. They don't compare to kings or fox but are still nice.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #884 of 1481 Old 07-12-2011, 06:59 PM Thread Starter
Bama_WJ
As a matter of fact, I started looking at the King 2.0 coilovers. The coilovers are actually less than what I expected them to be. Just don't know a whole lot about spring rates/sizes, terminology and all that jazz. I was reading up on the MC topic of the month on coilovers to give me a general idea, but it seemed like it kind of turned into a pissing match.
Like I said, I'd like to try and use my Clayton 6" springs that I already have. However, the coilovers might be in the cards if complications arise. But I got a big boy transfer case to buy.
Daniel
Bama_WJ is offline
post #885 of 1481 Old 07-12-2011, 07:06 PM
JJAMISON_
2015 JK Wrangler
those FOAs are sweet! I just looked at them. i bet you could call them and tell them your application and they would make a few suggestions
JJAMISON_ is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
