Bama_WJ's Build Thread - Page 58 - JeepForum.com
post #856 of 1481 Old 07-03-2011, 05:39 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Go to a local fab shop with a torchmate. They will able to cut out any shape you need. I'm sure there is someone around you that would be happy to make brackets to work perfectly. That is the route I would go. Then you have something different but designed exactly how you need them to be.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #857 of 1481 Old 07-03-2011, 06:06 PM
Shinobi
Saturnicl can make the brackets for you since he has done the swap before he maybe able to make exactly what you want.
Shinobi is offline
post #858 of 1481 Old 07-03-2011, 07:34 PM Thread Starter
Bama_WJ
I've gave that some thought. I'll have to look around. The thought of just handing the axles and WJ over to BTF has crossed my mind since they are 1.5 hours away. Labor charges might be the deal breaker though.
Haven't thought about that. I've been reading over his build a lot here lately. I might hit him up on Facebook soon.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #859 of 1481 Old 07-03-2011, 08:44 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Making the brackets shouldn't kill the bank. It will be the welding up of everything that does that.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #860 of 1481 Old 07-05-2011, 06:20 PM Thread Starter
Bama_WJ
Found a late model HP60 build thread over on Pirate. I may end up doing this and going with those ballistic combo brackets. Then I'll have a pro welder around here weld the tubes up and make a truss to keep the strength.
http://pirate4x4.com/forum/showthrea...hlight=dana+60
Sick welds on that sucker.
Daniel
Bama_WJ is offline
post #861 of 1481 Old 07-05-2011, 08:20 PM
AgitatedPancake
And I was thinking about unibody stiffening earlier. I planning on talking to Greg about some fish plates. Would be perfect for his Torchmate! Definitely thinking about putting some plate in the front where the springs are. Maybe Greg can enlighten the subject with a small amount of tech on this.
Build's lookin great man!
As for the stiffening, that's definately something we can start talking about . In all honesty, my unibody hasn't been reinforced beyond the claytons subframe and has survived so far. That doesn't mean I don't advocate all the reinforcement you can handle though haha, I just haven't gotten around to it on my own . I might have to start cutting some cardboard to see what I can come up with for some reinforcements. I want to go from my claytons to the front spring mount, and possibly the bumper area, then from claytons to the rear spring and possibly the rear bumper. Though my cage build will also help reinforce when I get to that
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #862 of 1481 Old 07-05-2011, 08:58 PM
TX-WJ
TX-WJ's Avatar
Whoa dude, your dub is onna be sick now!
congrats!
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd and locked JK Rubi D44s
TX-WJ is offline
post #863 of 1481 Old 07-05-2011, 09:31 PM Thread Starter
Bama_WJ
Thanks!
Sounds good man. I'll probably be hitting you up on Facebook soon then!
congrats!
Appreciate it man. I'm looking forward to having it "done"!
Daniel
Bama_WJ is offline
post #864 of 1481 Old 07-05-2011, 10:31 PM
JJAMISON_
2015 JK Wrangler
Looking good Dan! maybe you can have it built by xmas. and come down to Gray Rock and show them fools what a WJ can do!
JJAMISON_ is offline
post #865 of 1481 Old 07-06-2011, 05:50 PM Thread Starter
Bama_WJ
Thanks Jason. I'm hoping it's finished by the fall. But I'd be down for a trip to Grey Rock for sure to test it out!
Daniel
Bama_WJ is offline
post #866 of 1481 Old 07-07-2011, 07:55 PM Thread Starter
Bama_WJ
Another thing I've been thinking about is the steering situation for the D60. I'd love to put a high steer on it, but I think it would be TO high and cause problems during suspension compression. I could keep the knuckles stock and put a simple cross over steering kit on it like this one from Ballistic Fab:
http://www.ballisticfabrication.com/...rs_p_1335.html
Here are those high steer arms:
http://www.pirate4x4.com/forum/showthread.php?t=890475
Thoughts?
Daniel
Bama_WJ is offline
post #867 of 1481 Old 07-07-2011, 08:05 PM
MMjeep
Well, this whole time I thought I was going to be using Clayton's stuff for the axle brackets. Not anymore. In my research today I have found out that late model D60s have a 3.5" tube diameter instead of 3.125" found on earlier models. The S10.5 also has an axle tube diameter of 3.5". I also looked at T&T trusses, but they either don't have the right axle tube diameter or it wouldn't fit a WJ.
Was thinking about picking these up for the rear...
Truss/4-Link/Cover: http://www.bluetorchfab.com/Product/...ss-System.aspx
Coil Mounts: http://www.ballisticfabrication.com/...s-_p_1179.html
Control Arm Mounts: http://www.ballisticfabrication.com/...ts_p_1397.html
Shock Mounts: http://www.ballisticfabrication.com/...bs_p_1720.html
And for the front...
Combo Coil/Shock/Control Arm Mount: http://www.ballisticfabrication.com/...bo_p_1461.html
Track Bar Mount (don't what separation though): http://www.ballisticfabrication.com/...nt_p_1629.html
So, there are couple things I don't know about. First, what kind of angle are the control arm mounts at? They the same front and rear? Is it not good if they're not angled/perpendicular to the axle surface? Second, I don't know what I'm going to do for the radius arm mounts on the front axle. Didn't really see anything for bushing type links. Still have to worry about a truss system over the 60, as well.
Any suggestions/help would be awesome.
imusing the same brackets on my rear 9in as you mentioned above. As far as the angle of control arms if you look at the clayton kit the arm basically perpindicular to the ground. I set my at -10 degrees i think i can verify tommmorrow.
01 Tacoma DoubleCab Prerunner TRD 3.4v6 203k, 4x4/5 speed swap, 3in saw 2.0s, 315/75-16 MTR kevlar, locked f/r, TRD goodies
97 4runner Limited 3.4v6 324k: 3in OME, 265/75-16 mtr
My WJ build:
MMjeep is offline
post #868 of 1481 Old 07-07-2011, 08:15 PM Thread Starter
Bama_WJ
That'd be cool man. I was kind of leaning towards 10 degrees, but figured I'd ask anyway.
Sucks to hear about your Jeep though. However, you did give me an idea for a parking brake. I wouldn't have thought about a line lock!
Daniel
Bama_WJ is offline
post #869 of 1481 Old 07-08-2011, 12:57 AM
AgitatedPancake
Honestly, I really like how my steering came out and would do it again in a heartbeat. I have a high steer arm for the drag link to land on, but the tie rod lands on top of the factory knuckles (I reamed them out from the top for the 1 ton ends). Having the tie rod down low gives you all the space you need to make a very nice, long matching drag link and track bar.
Build Thread:
post #870 of 1481 Old 07-08-2011, 11:45 AM Thread Starter
Bama_WJ
Haven't thought about doing just one side high steer for the drag link. I might look into doing that and flipping the tie rod.
Daniel
Bama_WJ is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 03:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
