Bama_WJ's Build Thread - Page 40 - JeepForum.com
post #586 of 1481 Old 12-23-2010, 02:03 AM
gatorayde
Originally Posted by Bama_WJ View Post
Ok, now I find this.
Dana 60 straight front axle with lee springs
Is someone wrong here? Both ads I've posted say the axle(s) came out of a '79 F-250. Were some F-250s 1 tons and some 3/4 tons?
Basically, yes. Some 78/79 F-250s (Snofighter and High GVW packages) came with D60's.
gatorayde is offline
post #587 of 1481 Old 12-23-2010, 02:11 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Oh ok. I've just started reading the "Dana 60 Bible" over on Pirate and just saw that.
Hmm, kingpin for $600. Don't those go for like $1000 or more most the time?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #588 of 1481 Old 12-23-2010, 02:27 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Posting this more for my reference:
Ford 73 thru 79 F 250 parting out
I could maybe get the rear 60 out of that part out for pretty cheap and then get the kingpin.
Another reference link:
http://nashville.craigslist.org/pts/2051496237.html
Daniel
Bama_WJ is offline
post #589 of 1481 Old 12-23-2010, 02:49 AM
AgitatedPancake
Damn I will tell you right now that's a screamin deal on that front 60. $1000 is pretty common. You should do it! That's the same exact one I'm building for Andy's jeep
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #590 of 1481 Old 12-23-2010, 11:47 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well it turned out to good to be true. I just called the person and they said it was a 44, not a 60. I was going to pick it up today if it was a kingpin 60.
I'm still contemplating the HP44 and 60 though.
Daniel
Bama_WJ is offline
post #591 of 1481 Old 12-23-2010, 02:49 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
DANA 60 Axles
Says F/R are out of a 2001 F-250. The Pirate "Bible" doesn't list them as being offered in that truck. Just did a search and found that it's a Dana 50 which is often confused for a Dana 60.
Whats the thoughts on a Dana 50?
Edit: Jeez, the Dana 50 is just as bad as the 44A when it comes to aftermarket goodies. I'll pass.
Daniel
Bama_WJ is offline
post #592 of 1481 Old 12-24-2010, 01:57 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well, looks like I have a promising lead on some axles. I called the guy from this listing:
Called him up and talked to him for about 10 minutes about the truck and axles. He said it was a 1978 F-250 with the HP44 and 60. Tags verified the 4.10 gearing. He also told me something about the hubs being the small hubs and not the large ones. Said the axles were in real good shape for being 1978 truck. I asked him how much he wanted out of them and he said he'd have to get $400 for them. Which I don't think it that bad of a price.
What you guys think?
Daniel
Bama_WJ is offline
post #593 of 1481 Old 12-24-2010, 06:43 PM
MMjeep
so if you go that route what are you gonna do with the 44a? im pretty local and i been looking for one of those.
edit: wow only 400 for both thats a deal heck the 44a's ive priced have been 400 and up.
01 Tacoma DoubleCab Prerunner TRD 3.4v6 203k, 4x4/5 speed swap, 3in saw 2.0s, 315/75-16 MTR kevlar, locked f/r, TRD goodies
97 4runner Limited 3.4v6 324k: 3in OME, 265/75-16 mtr
My WJ build:
MMjeep is offline
post #594 of 1481 Old 12-24-2010, 07:02 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
If the axle plans do pan out to what I'm hoping, I'll be selling the stock axles if I can. I probably will try to sell them as a whole with all the goodies on/in them. But just so everyone knows, this axle swap is going to be a drawn out ordeal. I'm in no rush to put them in. So no one hold their breath just yet.
Anyone got any words of wisdom about these axles? Good deal? Any fab problems that could arise because of the axle itself? Come on AP, I know you got some knowledge to dish out!
Daniel
Bama_WJ is offline
post #595 of 1481 Old 12-24-2010, 07:09 PM
MMjeep
i mustve missed it what goodies are you refering too?
ive read somewhere the 78-79 f250 axles are pretty sought after when it comes to axle swaps so it mus be a good thing.
My WJ build:
MMjeep is offline
post #596 of 1481 Old 12-24-2010, 07:11 PM
patrick983
i have no specific direction to offer you except my jealousy but take a look at what the JK guys are doing as im sure people have used these axles under a JK before, axle swaps are a dime a dozen with those and with similar setups to WJ's(ie hub bolt pattern, abs, brakes etc), you could kinda "copy" one of those. theres alot more support for JK's and i know ive seen CA mount kits for axle swaps for those before, i would imagine HP44's and a 60 would be common choices for axle swaps. just a thought
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #597 of 1481 Old 12-24-2010, 07:29 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well, basically all the "goodies" are on/in the 44a. On the 44a I got the MVC truss, BTF cover and the Aussie Locker. Only thing really of value on the 30 is the JKS tie rod and maybe the IRO SS relocation stuff.
Yea, seems like a pretty common swap. That being said, I definitely have quite a bit of info already thats out there for me to follow. I just got all these questions running around my head cause this is the biggest thing I've ever thought about doing to my Jeep. Right now, my biggest concerns are brakes (with e-brake) and getting a speedo signal.
Daniel
Bama_WJ is offline
post #598 of 1481 Old 12-24-2010, 08:16 PM
MMjeep
ya i havent seen a ebrake so far on all the wj swaps on mallcrawlin seems to be a hard thing to swap over. As far as speedo goes ive seen 2 differant things 1. wire the rear abs to the fronts and use those to pic up speed 2. use t case speedo. Heres the write up
swapping axles in a WJ and keeping the speedo - MallCrawlin.com Forums
My WJ build:
MMjeep is offline
post #599 of 1481 Old 12-24-2010, 09:07 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Yea, I have that link saved to my favorites on my browser. Good info in there. I was thinking about throwing a 231 in so I could get the speed sensor.
For the e-brake, I've read you can use '78 Caddy Eldarado calipers cause they have an integrated e-brake within the caliper. I would assume I could use the stock cables for the e-brake with them. Don't know yet. I've also been thinking about the brake booster/master cylinder and if they are going to be enough for the new brake setup and 37s.
Daniel
Bama_WJ is offline
post #600 of 1481 Old 12-24-2010, 09:29 PM
MMjeep
i read somewhere where someone bought lokar cables for the caddi brakes and it "kind of" worked. Not to sure about using the stock cables. This is why i havent went 1 tons i would love to have a 9" in the rear but it seems complicated when you get down to keeping a dd rig.
My WJ build:
MMjeep is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 03:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
