Bama_WJ's Build Thread - Page 39 - JeepForum.com
post #571 of 1481 Old 12-13-2010, 03:55 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Got quite a bit of snow last night. Naturally, me and my buddies went out for a drift session.
YouTube - Purdue Snow Drift Session
Yea I know I posted the video already in the snow thread, but I feel like posting it here again so I can reminisce about it later.
No real updates with the Jeep though. Haven't really had the cash to do anything. Looks like I'll have a full time job here soon, so updates will be coming!
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #572 of 1481 Old 12-20-2010, 11:17 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
I'm finally a college graduate!
Now I just need a job.
Anyways, I finally made it home after a long day of driving in the Jeep. The noise I'm having still persists. I came up with some more detailed symptoms while I was driving it all day today.
With front driveshaft in:
- Speeds of 60+mph had a slight but constant vibration
- Vibration felt like it was under my feet
- Viration only happened while I had my foot on the gas
With front driveshaft out:
- Noise still persists; however, noise becomes lower (volume wise) when driveshaft is off
- No more vibration
- Noise is most noticable from about 35-55mph and is quite loud
- Noise is still heard under load
- Noise resembles more of a whirring/growling noise than anything
- When coming to a stop (10-0mph), I can feel something at the bottom of my feet, kind of like something grinding it feels and sounds like
- Noise seems to stop once I get to 60+mph
I also found it interesting that when I was pulling the front shaft off today that a little drip of gear lube came out the driver side tube. It was very dark. The lube was basically black. Which obviously means something in there is getting to hot and burning the lube. The only thing I really don't understand is its still making noise under load without the driveshaft (or with it installed for that matter since I stay in 2WD 99% of the time). I almost want to put the front shaft in and take the rear shaft out and drive around like that and see what happens. But the black gear lube makes me think it's the front axle.
If the general consensus is that its probably the axles, I'll just go ahead and start looking for beefier ones right now. I got another car I can drive and some grad/birthday/christmas (and hopefully full time job) money I can use for axles and whatnot. Because at this point, it's starting to concern me...
Daniel
Bama_WJ is offline
post #573 of 1481 Old 12-21-2010, 04:39 AM
patrick983
sounds exactly like front axle, pinion bearings most likely. perhaps the bearing is worn out and has destroyed the seal allowing lube past the yoke. can you wiggle the diff yoke laterally with the shaft off? if theres any play then thats another red flag for the diff.
2000 White V8 WJ LSR-6in-35's-LA's-242HD-Warn SOLD and missed very badly
06 GTO - BC Coilovers, JBA Catless mids, Svede Intake
patrick983 is offline
post #574 of 1481 Old 12-21-2010, 06:53 AM
drwolcot
what about your wheel bearings? I know I need to replace one of mine and it makes similar noises. If I am going straight or turning right it is very noticeable with the weight shifting to the driver side unit bearing. If I turn left and that weight is taken off the bearing it becomes much quieter. Just a suggestion..... I was thinking the worst as well till I figured it out.
2002 WJ Overland | 4.7 H.O. | Clayton 6in LA | LSR Bumper | JKS discos | JKS Track Bar | KOR SS | BFG KM2's 285/75/17 | Carolina Front/Rear Driveshaft | Quadradrive | 125k Miles
RIP
|4.7 | 242HD | 2WD-->4WD Conversion | Vari-Lock front D30 | D44a Aussie Locker | Hybrid RCX 4in + BB | IronMan FUCA's | D30 Solid Diff Cover | Carolina Front Driveshaft | JCR Stage 3 Sliders | E-Fan Conversion | Hard-KOR SS|
2003 WJ Overland - SOLD
drwolcot is offline
post #575 of 1481 Old 12-21-2010, 09:17 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Wheel bearings aren't to old. I know the front passenger side wheel bearing is 1.5 years old. The front driver side wheel bearing is probably around 2 years old. I've never touched anything on the rear axle.
I'll go ahead and check them as well.
Daniel
Bama_WJ is offline
post #576 of 1481 Old 12-21-2010, 10:19 AM
TJSWJ
congrats on gradumakating! as far as your noise is concerned, im having almost the same issue except mine if more of a rotational clunk noise. Im starting to think its in the t-case though. Yours sounds like more of a bearing or axle problem.
TJSWJ is offline
post #577 of 1481 Old 12-21-2010, 11:01 AM
patrick983
another thing worth mentioning is you could actually be hearing/feeling two separate problems, say the front pinion angle is off and a wheel bearing is going? as in the vibration is sourced from one place, and the noise from another. just food for thought, but if it were me judging by the symptoms id be looking closely at that front differential
post #578 of 1481 Old 12-21-2010, 04:51 PM
lakailimited06
im gonna link you this this recent thread maybe its the same thing..http://www.jeepforum.com/forum/f310/...nside-1135797/
if its similar to our problem it may just be the stupid 4.0 and 42re combo...on the other hand i would check your gear oil for torn up parts perhaps? and change it and see what happens its cheap enough to do...
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #579 of 1481 Old 12-21-2010, 06:20 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Hmm, it does sound fimiliar. However, the noise mine makes isn't just in OD.
Once the weather clears up, I'm going to check the wheel bearings, check gear oil and take the rear shaft out.
Daniel
Bama_WJ is offline
post #580 of 1481 Old 12-22-2010, 11:23 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Dana 60/44HP stock axles 4.10 ratio
What do you guys think? If I get beefier axles, I'm skipping 35s and going straight to 37s. Will a front HP44 handle 37s alright?
Daniel
Bama_WJ is offline
post #581 of 1481 Old 12-22-2010, 05:54 PM
gatorayde
Is the extra 1" of ground clearance (35 vs 37) worth the extra stress on the 44? Personally I'd say no, but a well built 44 should handle 37s fine. At that point though, you might have invested enough money into the 44 where you could've swapped in a 60 to begin with.
gatorayde is offline
post #582 of 1481 Old 12-22-2010, 08:36 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
I've just been entertaining the idea cause a decent set of axles showed up for an alright price. I want and have been looking for a set of 60s, but listings like that aren't very common around these parts. I guess I just have to play the waiting game and keep looking. Patience was never my strong suit.
Daniel
Bama_WJ is offline
post #583 of 1481 Old 12-22-2010, 08:46 PM
patrick983
wow thats a great deal, personally if that was here locally id jump on it. thats more than enough strength even running 37's. definitely still a major project, and looks like you'd be running 8 lug wheels/tires, but could be worth it if those things are in good shape!
post #584 of 1481 Old 12-22-2010, 11:01 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well, I just emailed the guy for some pictures. So I guess we'll see what they look like and then I'll make a decision.
Daniel
Bama_WJ is offline
post #585 of 1481 Old 12-23-2010, 12:38 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Ok, now I find this.
Dana 60 straight front axle with lee springs
Is someone wrong here? Both ads I've posted say the axle(s) came out of a '79 F-250. Were some F-250s 1 tons and some 3/4 tons?
Daniel
Bama_WJ is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
