Bama_WJ's Build Thread - Page 38 - JeepForum.com
post #556 of 1481 Old 11-22-2010, 01:02 PM
chicagoniner
How far are you? Might be worth it, how much would ya charge me?
02 Subie REX
Looking for Custom Drums? Check out
chicagoniner is offline
post #557 of 1481 Old 11-22-2010, 01:23 PM Thread Starter
Bama_WJ
Chicago is like 2 hours away from me. Maybe a tad more.
Charge you to do what?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #558 of 1481 Old 11-22-2010, 01:39 PM
chicagoniner
for you to do all my lift duh! =]
02 Subie REX
post #559 of 1481 Old 11-22-2010, 01:48 PM
biggoofy
Do it yourself noob.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #560 of 1481 Old 11-22-2010, 01:57 PM
chicagoniner
**** IT! Busting out the JB weld.
02 Subie REX
post #561 of 1481 Old 11-22-2010, 02:49 PM Thread Starter
Bama_WJ
Well I don't have a welder or anything, so that might be a problem since you got some claytons stuff.
Daniel
Bama_WJ is offline
post #562 of 1481 Old 11-22-2010, 02:50 PM
chicagoniner
Yeah, that might not work lmfao.
02 Subie REX
post #563 of 1481 Old 11-23-2010, 12:08 AM
RedZJ
Super glue!!!
RedZJ is offline
post #564 of 1481 Old 11-23-2010, 07:39 AM
chicagoniner
Naw, it's fine, they're going on with JB Weld tomorrow.
02 Subie REX
post #565 of 1481 Old 11-27-2010, 11:32 PM Thread Starter
Bama_WJ
Well, I don't know how many of you saw any of my facebook status from the other day, but I think my D30 is on its last leg. I was on my way to Indy airport for my flight back home and was noticing some intermittent vibrations from under my feet. My first thought was driveshafts. I stopped at a rest stop cause I just had to figure out what was going on or else it was drive me nuts. I park it and pull out my tools so I can tighten all the ujoint straps on the front and rear yokes. Everything was tight though.
My next thought was the front diff. My 30 has been making quite a lot of noise for maybe the last 6 months. More so probably in the last 3 or 4 months. It's actually pretty bad. Around 40-50 and under load, the front diff is way loud. I figured while I have my tools and I'm under the Jeep I might as well just take the front driveshaft off and see what happens. And what do you know, the rest of my drive was quiet (for a Jeep anyways) and vibration free. It drove real good for once.
I'm pretty sure its my bearings that are toast. But hell, this is as good of an excuse as any to upgrade axles.
Daniel
Bama_WJ is offline
post #566 of 1481 Old 11-28-2010, 07:06 AM
lakailimited06
maybe just a bad u joint in your driveshaft? even with your front shaft out all the internals are still moving in the 30 no?
my front driveshaft went from being squeaky to making some vibrations becuase i held off on replacing the u joints and just tried greasing them to get rid of the squeaks...
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #567 of 1481 Old 11-28-2010, 07:17 AM
RedZJ
SHHH. He is going to upgrade his axle. Dont ruin this.
RedZJ is offline
post #568 of 1481 Old 11-28-2010, 07:45 AM
squashman702
1994 ZJ
This. Did you check the unit bearings as well?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #569 of 1481 Old 11-28-2010, 08:58 AM Thread Starter
Bama_WJ
Guess that's true. Wouldn't have thought bad ujoints would make that much noise.
Daniel
Bama_WJ is offline
post #570 of 1481 Old 11-28-2010, 12:07 PM
lakailimited06
shaft could also just be slightly unbalanced
99WJ 4.0
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
