Bama_WJ's Build Thread - Page 2 - JeepForum.com
post #16 of 1481 Old 04-16-2009, 11:45 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Thanks!
3 > 2
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #17 of 1481 Old 04-18-2009, 02:17 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Kind of a little update. I installed a new-to-me transfer case out of a 99. Its nothing to special, just another run of the mill 242. My old one was way messed up since the gear teeth that engages 4WD were chewed up and broken/missing. Here is what my magnet looked like in my old 242...
I would have more interesting stuff to post, but UPS didn't get my stuff in since there was "adverse weather conditions" on its way to my place. Some luck...
Daniel
Bama_WJ is offline
post #18 of 1481 Old 04-20-2009, 05:38 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Got some new goodies.
New CB antenna setup and my JF sticker!
Daniel
Bama_WJ is offline
post #19 of 1481 Old 04-20-2009, 05:40 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Nice, red to match the jeep. Also reminds me I need a spring.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #20 of 1481 Old 04-27-2009, 05:31 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Installed a new CB antenna setup yesterday. I was getting tired of the 4.5' Wilson 500 mag mount on top of my roof and kind of wanted something with a little cleaner look. I ended up following the lead of ///BHRPowered over at JU with this setup. I went with the MK184R mounting kit which is made for Ram/Dakota hoods. The kit came with a 18' cable and everything needed to connect to the CB; a very complete kit for $22. The mount iteslf is very sturdy. It actually needs to be bent a tad in order to have the antenna stand straight up. I paired the mounting kit with a FireStik SS3M spring and a red FireStik FL3-R 3' antenna.
I started off by removing the plastic interior peice that is below the very back window. Then I took the tail light off and drilled a 3/8" hole right beside the electrical grommet. I cleaned up the hole and put the rubber grommet supplied in the kit into the hole. Then I fed the cable through and ran it behind the plastic interior peice and up to the front.
Next, I mocked up the mount so I could eyeball how much I had to bend the mount to get it horizontal. Then I had a friend hold the mount in place while I drilled 4 3/32" pilot holes for the mounting screws. It turned out to be pretty straight.
The tail light had to be trimmed a little bit in order to fit with the mounting screws that were in place. Nothing that a 5 minute Dremel job couldn't handle. It's kind of hard to tell in the picture where its trimmed. You get the idea though...
The connector part was then soldered up, tucked away, and plugged into my CB. I did a little bit of SWR tuning and that was all she wrote. I'm pretty pleased with the end result.
Here are a couple pictures of how it turned out.
Finally got my JF sticker too. Now I can represent.
Daniel
Bama_WJ is offline
post #21 of 1481 Old 05-03-2009, 08:53 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Bad news tonight. The jeep is front wheel drive right now. I'm pretty sure the rear end blew up. I was just taking a cruise and enjoying the nice day. Then I started hearing some odd and loud noises that were obviously coming from the drivetrain. I decided to pull over into a empty parking lot to maybe check some stuff out. Shifted into 4FT to make sure the transfer case was still working fine. I started backing up in 4FT but the Jeep started binding up like it was in 4PT. Then something popped really load and the Jeep just rocked from not binding up anymore. I figured the transfer case finally went into the right gear. Not so.
Got underneath the Jeep with the transmission in park and the transfer case in neutral. I could literally spin the rear driveshaft with my hand. I took the bottle jack that came with the Jeep and lifted each rear wheel seperatly and turns out both spin freely with pretty much no resistance.
We'll see what happens when I pull the diff cover off. Pictures of the carnage to come sometime this week...
Daniel
Bama_WJ is offline
post #22 of 1481 Old 05-03-2009, 09:41 PM
flyboy14295
You still had the D35 in there, even after blowing up the axle shaft? Sorry to hear!
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #23 of 1481 Old 05-04-2009, 06:01 AM
tennesseewj
Sucks man
Might as well post some carnage pictures for us
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #24 of 1481 Old 05-04-2009, 05:42 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well, took the diff cover off just a little bit ago. Turns out the bearing just ate themselves and the entire carrier shifted away from the pinion gear. I haven't done a complete tear down quite yet, so those were just my first impressions.
Here are a few carnage teaser pics for the time being. I'll get more once I do the complete tear down.
Daniel
Bama_WJ is offline
post #25 of 1481 Old 05-04-2009, 06:03 PM
Jones
Consider the following...
Jones's Avatar
Where did you order your CB antenna stuff from?
Jones is offline
post #26 of 1481 Old 05-04-2009, 06:17 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
www.westcoastmall.net
Had pretty good prices and shipped stuff out fast. I'd recommend.
Daniel
Bama_WJ is offline
post #27 of 1481 Old 05-04-2009, 06:30 PM
Jones
Jones's Avatar
So you got this http://www.westcoastmall.net/firesti...kit-p-270.html and this http://www.westcoastmall.net/firesti...ack-p-195.html but in red?
I'll have to order these as soon as I get some cash.
Jones is offline
post #28 of 1481 Old 05-04-2009, 06:59 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Correct on the mount. This is the antenna I got. Its the FL3.
http://www.westcoastmall.net/firesti...ack-p-216.html
Daniel
Bama_WJ is offline
post #29 of 1481 Old 05-04-2009, 09:51 PM
Jones
Jones's Avatar
Thanks man, I'll be ordering asap.
What did you use for screws? Self tapping?
It looks great by the way,
Jones is offline
post #30 of 1481 Old 05-04-2009, 10:39 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Ya, use self tapping and make sure you don't put it sticking out the side of your vehicle. You don't want to rub against something and it rip off. Just right out the tail light.
Brian
WJ, WK, CJ5
GraKee99 is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
