Bama_WJ's Build Thread - Page 17 - JeepForum.com
post #241 of 1481 Old 05-14-2010, 07:16 AM
RedZJ
Originally Posted by GraKee99 View Post
I would go winch and not look back. Even if you never wheel alone, a winch is a great investment to have because there are times on the trail when a pull isn't enough or possible from where you are stuck. And you have a rear locker now so that will take you farther but that also means when you get stuck, you get stuck.
I know there were times in Arkansas where I was glad my buddies had winches because a pull out would not do the trick.
Just my 2 cents.
Well said. There have been times were it would have been smarter for me to have a winch. I plan on getting one once I get a bumper.
RedZJ is offline
post #242 of 1481 Old 05-14-2010, 09:17 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Just my 2 cents.
I see where you're coming from. Never really thought about if I got stuck somewhere and trees/rocks were blocking the paths for a person to pull me out. Could probably make a few bucks on pulling other folks out, too. Maybe I might just get one. Don't know that much about the winch market.
I've seen a lot of people talk about that XRC8 winch. The price looks good, but what about quality? Anyone got comments. Any other winch brands/models to look out for. Also heard a lot about synthetic winch line. Switching lines seems like a good upgrade by reducing weight and probably easier to work with compared to the steel line.
Dang, now I want to start looking into dual batteries...
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #243 of 1481 Old 05-14-2010, 10:23 AM
BLACKzj52
hey man, glad to hear you got a job! now start spendin!
BLACKzj52 is offline
post #244 of 1481 Old 05-14-2010, 12:17 PM
GraKee99
Rapist Wit
GraKee99's Avatar
I have been looking at the smittybuilt as well and think I will go with it. Kanin has it on his rig and says it has plenty of power. Can always use a snatch block if you need more since it doubles the pulling power. It will be slower than a warn but I don't mind as long as gets the job done.
And a single battery is fine for a winch. Just run your vehicle while you are winching and might have to rev your engine from time to time but it will be fine. My buddies' ZJ has a warn 8K and single battery and he doesn't have a problem. If you plan on running multiple lights and a winch at the same time, then you might look into dual batteries.
You will find that a winch will be one of your more favorite mods. I know in Arkansas it was a life saver when clearing down trees off the trail. I'm sure Alabama is similar where a chain saw is pretty much necessary on any trail ride.
On a side note, did you add friction modifier when you installed your aussie?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #245 of 1481 Old 05-14-2010, 04:08 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Yea, I can't to start spending.
I will still have my 3 Hellas. I don't wheel at night (on purpose at least), so I don't really see when I'd be running my lights and winch at the same time. If it came down to it, I'd turn the lights off and run the winch. I'll run my yellow top as is for right now and see how it does. Maybe an upgraded alternator?
I'm looking at this one right now:
Smittybilt 98281 - Smittybilt XRC 8 Winches - Overview - SummitRacing.com
with this to protect it:
Smittybilt 97281-99 - Smittybilt Winches - Overview - SummitRacing.com
About the Aussie. I didn't put FM in the diff with it. I just put some 80-90 in there and was done with it. I got some 85-140 I'm going to put in there once I put the BTF cover on. Maybe the 85-140 will quiet it down some.
Daniel
Bama_WJ is offline
post #246 of 1481 Old 05-14-2010, 04:43 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Could order it from here and get a free cover and shipping. And that is better than the one I am looking at, I was just going to get the base model.
XRC 8 Winch W/Synthetic Rope & Aluminum Fairlead-RH2
And I'm not sure about an alternator upgrade, never looked into on. Maybe someone knows more than me.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #247 of 1481 Old 05-14-2010, 06:09 PM
lakailimited06
bama how do you like daily driving with the rear auto locker? i could search through tons of threads but i know you just recently did it im debating throwing one in my rear axle or saving for a selectable...
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #248 of 1481 Old 05-14-2010, 08:43 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Thanks for finding that cheaper one. I'll figure out more when the time comes closer. I'm starting to look into 55W HID lights to help out the battery situation. I think my new lighting plan is going to be awesome.
I have zero problems with it and don't mind it one bit. To be honest, I think some people over exaggerate the auto locker in a DD business. I mean you can definitely tell it's back there, but it's nothing troublesome. I took me less than a week to get used to it. I say go for it. Use that money you'll save buying the auto locker for something else.
Daniel
Bama_WJ is offline
post #249 of 1481 Old 05-14-2010, 09:38 PM
lakailimited06
yea thats waht ive heard from a couple of friends...people on here tend to complain and steer you away from things for no real reason just because something isnt "ideal"...
my main concern was how it would be on pavement in the snow...i no longer use full time cause of the front locker now so im pretty much stuck with 2wd in the crappy weather but i didnt know how the jeep would behave in snow with the rear auto in 2wd...
99WJ 4.0
post #250 of 1481 Old 05-14-2010, 09:44 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
I made sure to test it out in the snow while I was at Purdue. Its definitely something to get used to in the snow. If you're smart about it, its not a problem. Practicing in an empty snow covered parking lot is about the only advice I can give you. It's WAY fun though.
Daniel
Bama_WJ is offline
post #251 of 1481 Old 05-14-2010, 09:53 PM
lakailimited06
what does it do jsut kick the tail out all over the place? wouldnt it still be better than regular 2wd in the snow?
99WJ 4.0
post #252 of 1481 Old 05-15-2010, 01:50 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
The tail end will want to walk out on you if you give the gas a good quick tap. But if you just take it easy and be smooth with the gas, it shouldn't be a problem. I had mine in 2WD all winter and never had anything sudden happen. Wasn't bad at all.
Daniel
Bama_WJ is offline
post #253 of 1481 Old 05-20-2010, 04:24 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Since I've basically figured out what bumper and winch I want, I'm starting to look at a new light setup. I'll probably sell my 3 Hella lights with 100W bulbs if anyone wants them. I want to redo the wiring setup as well. I've been looking A LOT at the Lightforce 170 and 240. Some might not like the big light look, but I think it looks pretty cool. I'm really going back and forth between halogen and HID. These will probably be the last set of light I'll buy for the front, so dropping some coin on really good ones doesn't really bother me. I've kind of grown out of the Hellas, too. I want more light.
If any of you have seen the light output on these Lightforce lights, its insane. The HIDs measure 1 lux at three quarters of a MILE. They're construction looks second to none as well as seen in the video.
YouTube - LIGHTFORCE "LIGHT LOGIC" V-1.0
We'll see what happens. Was thinking about 2 700FFs and 2 500FF, but I'm want to cut down on watts since I'm getting the winch.
Daniel
Bama_WJ is offline
post #254 of 1481 Old 05-20-2010, 04:45 PM
BLACKzj52
I can hardly tell mine was back there. The only time I noticed it back there (on the streets that is), is when you take a turn and accidentally give it a little too much gas. And when youre making a sharp turn while stopped (mainly parking lots). I got to drive my jeep for maybe 3 days with it installed (before it went into hibernation) and can definitely say i got used to it on the first day really.
Then I could definitely tell it was back there when offroad. OMG!
Havnt gotten to try it in the rain or snow yet though. Although I already know what its going to be like.
I keep telling people its no big deal. Some people have issues with theirs. Maybe they're just not good drivers?
Im glad to hear im not the only one who thinks its easy to drive with, I was starting to think I was going insane lol
post #255 of 1481 Old 05-22-2010, 11:34 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Yea, I don't know what the deal is with other people. It's not bad at all IMO.
As a side note, I'm pretty set on some other parts I want. BTF covers for the 30 and 44a and I decided on the LF 240 HIDs. It's going to be a while, but the parts are going to be worth it.
Anyone got a schematic on setting up a reverse light? Thinking I can just tap off the hot wire for the reverse lights into a relay and take the main power from the 12V power jack in the rear cargo area. Comments?
Daniel
Bama_WJ is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
