Bama_WJ's Build Thread - Page 12 - JeepForum.com
post #166 of 1481 Old 01-08-2010, 02:43 AM
Shinobi
looking good man !! I want one now
Shinobi is offline
post #167 of 1481 Old 01-08-2010, 08:51 AM
tennesseewj
That is sweet
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #168 of 1481 Old 01-08-2010, 05:32 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
The axle is back in! Finally. Me and some buddies put it in with it about 20 degrees out and snowing. We didn't really have any problems at all, so that was nice. Locker works awesome and the truss looks great!
I really need to do the gas tank lift...
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #169 of 1481 Old 01-08-2010, 11:28 PM
TX-WJ
TX-WJ's Avatar
Good stuff man! Keep it up.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline
post #170 of 1481 Old 01-08-2010, 11:31 PM
GraKee99
Rapist Wit
GraKee99's Avatar
*cough cough* I need mine. *cough*
Brian
WJ, WK, CJ5
GraKee99 is offline
post #171 of 1481 Old 01-09-2010, 01:05 PM
XJ_Renegade
Your gas tank looks all beat up like mine does. Is that a factory skid plate, or the "brush guard"? I'm still trying to figure out what mine has.
Truss looks sweet, btw.
1999 XJ - Finally on respectable tires.
1998 ZJ - I'll show you my Niner if you show me yours.
XJ_Renegade is offline
post #172 of 1481 Old 01-28-2010, 11:39 AM
BoostinNRS
What did you finish your rock sliders with? I think I'm going to order some soon.
98 xj
04 SRT-4 (sold)
BoostinNRS is offline
post #173 of 1481 Old 01-28-2010, 12:30 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Just some semi-gloss rustoleum from a rattle can. I respray them like once a year.
Daniel
Bama_WJ is offline
post #174 of 1481 Old 03-05-2010, 10:22 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Just wanted to post in here real quick to see if I could gauge interest on selling my IRO adjustable track bar. I kind of decided I didn't need it anymore a while ago since I'll be buying the claytons 6" kit which already has the JKS adjustable track bar in it.
So any initial interest at all? $100 plus shipping maybe? Trade for a Herculiner UV kit?
Daniel
Bama_WJ is offline
post #175 of 1481 Old 03-06-2010, 06:01 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Looks like I'm going to be buying some Monstaliner early next week. That means I'll be doing some big fender cutting in a couple weeks. And while I'm at it, I might as well raise the gas tank.
Daniel
Bama_WJ is offline
post #176 of 1481 Old 03-18-2010, 02:11 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Hmm...
Daniel
Bama_WJ is offline
post #177 of 1481 Old 03-18-2010, 02:23 AM
lateralus3
1994 ZJ
no more dirty diaper lol
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #178 of 1481 Old 03-18-2010, 07:19 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Sweet.... harbor freight angle grinder.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #179 of 1481 Old 03-21-2010, 01:39 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Well, my spring break has come to a close. I kept myself pretty busy with the Jeep over the past week.
Pulled my sliders off and repainted them. Gloss black this time instead of the satin that I've had on there. There was so much rust on them...
Next, as the picture in the above post implies, I did the gas tank lift. This marked the first metal to ever be cut on my Jeep. I basically followed Lakai's gas tank lift procedure. First, I took the bumper off. Found a nice little suprise there. Guess the PO got rear ended and never reported it, so it didn't show up on the carfax.
Looks like it tweaked my skid pretty good as well.
From there, I dropped the tank. You just unbolt the skid from the "frame" and it falls right down.
Undo the straps from the top of the tank and just pull the tank out. It helped me alot since I had like no gas in it.
I had about 1/4" of mud/sand in between the gas tank and the skid plate itself. There was alot of it...
Taped off the tub so I could make a decent straight cut with the grinder.
That first cut into the Jeep was the hardest. After that, its cake.
Tub completely out.
Next, I cut the top of the skid in order to keep the finished product "bolt-on". Made sure to keep enough to weld to as well. Then I cut maybe 3" off the sides to make the skid shorter.
Moved to the tub next. Did the same thing as SaturnICL did on this part. Cut off about 4" off the top of the tub. I didn't have duck bills, so I just used two channel locks to bend the outsides of the tub outward.
Mounts welded back up.
Daniel
Bama_WJ is offline
post #180 of 1481 Old 03-21-2010, 01:42 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
When it came time to put things together and cover the hole with the bottom of the original tub, it did not want to cooperate at all. Guess I didn't bend the metal out far enough. So, I ended up abondoning the whole tub covering the hole idea. My girlfriends stepdad has a HVAC business and he let me buy an almost 5'x5' sheet of 24G stainless from him for $20 so I could cover the hole in the back of my Jeep.
Did some cutting and measuring and came up with this...
Laid it down under the carpet and used zip screws to secure it. Sealed it up with clear gutter silicon.
Cover back on. Don't even know anything is out of place.
All done. Where'd it go!?
Decided to clean the axle up and paint it since it can be seen by everyone else now.
I was planning on cutting the fenders up this week as well, but didn't have enough time. I got the bedliner in, so I can do that when I get back home from school. Well, that's about it for now.
Daniel
Bama_WJ is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 03:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
