Bama_WJ's Build Thread - Page 11 - JeepForum.com
post #151 of 1481 Old 01-06-2010, 07:08 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #152 of 1481 Old 01-06-2010, 08:13 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Using shinobi's method right now and its still not budging. About to use a come-along on it. This is pissing off. Could it be cause its like 30 (or less) degrees out?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #153 of 1481 Old 01-06-2010, 08:17 PM
Shinobi
this is probably a stupid question but did u remove the 3 bolts behind the cover that holds the axle shaft ?
Shinobi is offline
post #154 of 1481 Old 01-06-2010, 08:27 PM
ArloGuthroJeep
Mr. Hyde!
There are 4, not 3 Perhaps that is the problem
A slide hammer should work, but I have always just hooked up a rotor backwards, threaded on some lug nuts a few turns, and used that as a slide hammer.
post #155 of 1481 Old 01-06-2010, 08:32 PM
Shinobi
hahah sorry I got mixed up with the front wheel baring
Shinobi is offline
post #156 of 1481 Old 01-06-2010, 08:40 PM
TX-WJ
TX-WJ's Avatar
Since you pulled the shafts on the 35 before, Id have to assume you did remove the retainer plate nuts, so I guess try torching it for a minute or so, then use a dead blow hammer to hit the axle tube at the axle bearing area circumferentially, then go to town with the slide hammer.....
if it doesnt come out then I'd say keep it open and sell the aussie for a profit .
Good luck, report back.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline
post #157 of 1481 Old 01-06-2010, 09:27 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
OOMMGG
I don't know how I forgot to get those 4 retainer plate nuts. MASSIVE BRAIN FART!
I feel so stupid. Thanks for the help guys, its going smoothly now.
Daniel
Bama_WJ is offline
post #158 of 1481 Old 01-06-2010, 09:46 PM
ArloGuthroJeep
Mr. Hyde!
post #159 of 1481 Old 01-06-2010, 10:54 PM
Shinobi
hahahahha im sorry but you sir deserve a FAIL
JK
Shinobi is offline
post #160 of 1481 Old 01-06-2010, 11:18 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
I agree, I failed on that part.
Putting the Aussie in right now.
Daniel
Bama_WJ is offline
post #161 of 1481 Old 01-07-2010, 01:03 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
So, after my bucket of fail I ended up pulling the axle without a problem. I finished up and cleaned up shop around 12:45am. It's been pretty productive I think.
Starting off. The 44a has been pulled...again. At least it ain't in a parking lot.
My work area.
Time for the fun stuff. Once I had the axle pulled, I figured I would takle the Aussie and install it. I found THIS site for Broncos to be really helpful. I didn't have the instructions, so it worked out great. A tip for anyone putting in the Aussie, use a 7MM 6-point to remove the reverse torx bolt that holds in the cross pin.
No spiders.
I followed the websites instructions and the install was a breeze. It took me like 30 minutes to install. All my tolerances were to spec and I was done!
I'll be back tomorrow with truss install pictures and the first test run results.
Daniel
Bama_WJ is offline
post #162 of 1481 Old 01-07-2010, 02:37 AM
Shinobi
I miss my locker
Shinobi is offline
post #163 of 1481 Old 01-07-2010, 02:05 PM
HikerX
2014 WK
Originally Posted by Bama_WJ View Post
Looks like you've convinced me of my next upgrade...
Great write-up! I've seen your WJ on campus (I work there - IT staff) and never suspected the amount of work you've put into it. Nicely done.
If you ever see a grey haired guy driving a lightly modded green XJ with a Jeep Jamboree USA sticker in the left side rear window, that'd be me.
'14 WK2 Limited
Previous Jeeps
'11 JKU - '96 XJ Country - '04 TJ - '86 CJ7
HikerX is offline
post #164 of 1481 Old 01-07-2010, 04:06 PM Thread Starter
Bama_WJ
Bama_WJ's Avatar
Thanks! I actually have seen yours driving around campus as well. Its the Jeep Jamboree sticker that makes me remember it. I think I've seen you a couple times coming down Stadium going towards Russell when I was walking out of Cary to go to class. Could be wrong though.
On a side note, just got back from my buddies place and the truss is all welded up. It's major BEEF! Pictures to come...
Daniel
Bama_WJ is offline
post #165 of 1481 Old 01-08-2010, 02:07 AM Thread Starter
Bama_WJ
Bama_WJ's Avatar
As I said earlier, I got the truss installed. It looks real good I think and should perform great.
Here's my buddy welding it up.
Shot of the final welds. If these thing break loose, I might as well do another axle swap. He ran two beads on each side.
Here are some shots of it unpainted.
Hit it with the flat black.
Axle goes back in tomorrow. Can't wait to drive this thing!
Daniel
Bama_WJ is offline
WJ Build Thread tsconver Grand Cherokee General Discussion 251 08-30-2016 10:12 AM
Help on how to do a build thread coolio365 ZJ Grand Cherokee Forum 11 12-09-2011 05:14 PM
WK build thread WSPJeep Grand Cherokee General Discussion 95 11-01-2010 09:17 AM
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 03:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 07:00 PM
