Bama_WJ's Build Thread - JeepForum.com
post #1 of 1481 Old 04-05-2009, 11:06 PM Thread Starter
Bama_WJ
What my WJ looks like as of today:
Table of Contents:
__________________________________________________ _________________________________________
I figured I would go ahead and jump on the bandwagon and start my own build thead.
It doesn't consist of my much right now, but I hope to change that by summers end. I'll try to put everything in the order that I got stuff installed. So here it goes...
First off, a little bit of stats:
  • 2001 Jeep Grand Cherokee
  • UpCountry Package
  • 4.0L I6
  • 242 Transfer case
  • 98K miles when bought in April of 2007
When I first got my WJ:
I then started to get the itch to start modding things. First in the line up was get some exhaust put on there. I ended up going with a Flowmaster 50 Series and a Magnaflow/Carsound Hi-Flow cat. Sounds pretty nice.
I love coming home from work and seeing a Summit box on the ground!
Video of my exhaust.
Next, I ended up installing a K&N FIPK kit. I found it on eBay for a decent price.
Then I finally purchased a lift. Only had the funds to buy Kevins 2.5" Budget Boost at the time. I really wanted the IRO 3", but I have been real satisfied with this BB paired with the MX-6 shocks. Once you learn how to drive the Jeep decent offroad, only a little bit of lift can get you quite a few places.
A couple pictures of the installation. Nothing to extreme.
Here is the end result. Stock vs. 2.5" BB and 31" Goodyear Silent Armors:
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #2 of 1481 Old 04-05-2009, 11:51 PM Thread Starter
Bama_WJ
Moving on. It was time for more lighting. I ended up going with 3 Hella 500 lights. I also bought 100W H3 Streetglow bulbs to replace the 55W bulbs that came in the Hella 500's originally.
Disregard the Kelly Brook background.
Here they are mounted to my bumper. What you don't see is a thin sheet of aluminum under the bumper to give it some strength. It works great and keeps the lights from bouncing around all the time.
Improving traction was the next order of business. Since it is a DD 90% of the time, I went with the Detroit TrueTrac. Sometimes I wish I had went with a locker, but I have been happy with my Detroit. It locks up nicely and is completely invisible on and off road.
TrueTrac in and ready to go!
I went a little while without any mods. I did quite a bit of wheeling during that time. Well, during that time, I had somehow bent my stock tie rod. Don't know how or when, but it gave me a good excuse to upgrade. I ended up going with Kevin's heavy duty tie rod. I must say, its straight beef compared to the stock one.
What the stock one looked like before I pulled it off:
In the above picture, I'm sure you can see the new looking track bar and relocated SS. It is an adjustable IRO track bar and their SS relocating kit. I got terrible death wobble once I installed their track bar. Even with the adjustable end threaded all the way in the axle was still pushed 2" out on the passenger side. I decided to put the stock track bar on and keep the IRO adjustable in a safe place since I know I would go higher one day. The SS relocation kit works great though. Its a tight squeeze in between the stock track bar and stock drag link, but it works!
New tie rod with jamb nuts.
To the right of the jamb nuts are axle seals for my then leaky D30. I figured it was a good time to change them since the tie rod had to be removed anyways to get the carrier out. I was in for a suprise when I pulled the old seals out.
What axle seals are NOT suppose to look like. Apparently Badlands had taken its toll...
Daniel
Bama_WJ is offline
post #3 of 1481 Old 04-06-2009, 12:12 AM Thread Starter
Bama_WJ
Then it came time for some music mods. I went with a new Kenwood headunit, Kicker ZX750.1 amp and Kicker 10" L7 sub.
Kenwood headunit:
I placed the amp under the rear driver seat. Modification under the seat to fit the amp was pretty easy. All it takes is a good knife to cut the carpet and a dremel to cut away the metal in order to make the amp fit.
Next came probably one of my best mods to date. JCR Stage 2 sliders. I really don't have any pictures of them before they got installed, but I do have a few "in action" shots. I love these things. Highly recommend them.
I guess thats it for now. I hope to update soon with more goodies. Enjoy!
Daniel
Bama_WJ is offline
post #4 of 1481 Old 04-06-2009, 06:18 AM
fivespeedsteed
very nice dub. always dig the lights on the bumper. considering doing that now, do you like them mounted more in the center? id probably only do 2, but put them further apart from one another, do you think thats the best bet? im guessing you have all areas covered casue you have 3.
2007 Ford F150
1990 Mustang GT
fivespeedsteed is offline
post #5 of 1481 Old 04-06-2009, 07:37 AM Thread Starter
Bama_WJ
Yea, the center setup works pretty well for me. The two outside lights are spot style beam while the center is a wider fog style beam. Works great with the two outsides pointed right on either side of the high-beam area.
Daniel
Bama_WJ is offline
post #6 of 1481 Old 04-06-2009, 07:44 AM
spife7980
i like this build. not so indepth its boring and not so skimpy it leaves you wanning for more. very nice jeep. make me want some additional lights though...
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #7 of 1481 Old 04-06-2009, 09:48 AM Thread Starter
Bama_WJ
Thanks. Yea, up until now I had no intension or plan to make a build thread. So that is why I am lacking so many pictures. Now that I have a place to post whore all my pictures, I'll take some more when I need to!
Daniel
Bama_WJ is offline
post #8 of 1481 Old 04-06-2009, 11:03 AM
tennesseewj
Good thread. For some reason I thought you had more than 2.5" of lift.
Good to see you've had no issues with the D35 breaking with the TrueTrac
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #9 of 1481 Old 04-06-2009, 11:59 AM
GraKee99
Rapist Wit
GraKee99's Avatar
He does have more than 2.5", he has up country springs so he is probably around 3".
Brian
WJ, WK, CJ5
GraKee99 is offline
post #10 of 1481 Old 04-06-2009, 12:05 PM Thread Starter
Bama_WJ
Yeeaaahhh, about that...
I broke the driver side shaft trying to climb a hill in the Quarry at Badlands back in December '08. I lost traction a little ways up the hill and slid down with the tires still spinning a little bit. I must have caught something at the bottom that caused the driver side to grab instantly...and boom, thats all she wrote.
The hill I'm referring to:
And here is what I pulled out of the axle tube:
Daniel
Bama_WJ is offline
post #11 of 1481 Old 04-06-2009, 12:19 PM
Merc1973
Nice build, pretty similar to mine. I need armor though.... Are you going to Badlands with other Forum members?
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #12 of 1481 Old 04-06-2009, 12:23 PM Thread Starter
Bama_WJ
I have ran a time or two with some of the folks from Jeeps Gone Wild. Other than that, I usually wheel with a few friends here from school.
Daniel
Bama_WJ is offline
post #13 of 1481 Old 04-06-2009, 08:36 PM
tennesseewj
Good call.
I figured. Bouncing is never good though, even without a limited slip. It will pop shafts fast.
2004 4.0 Selec-Trac
post #14 of 1481 Old 04-16-2009, 10:25 PM
DothanJeep
Sweet Build!
how does that Flowmaster sound with the I6?
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #15 of 1481 Old 04-16-2009, 11:01 PM
MoonyJohn
I guess its a red laredo thing where we have 3 hellas. It looks so much better than 2.
Nice build
MoonyJohn is offline
RMFK13 Build Thread. RMFK13 Grand Cherokee General Discussion 89 01-20-2010 02:33 PM
? about starting a build thread zjzach Grand Cherokee General Discussion 5 04-17-2009 06:00 PM
