"Bahamut" 93zj limted 5.2l Build - Page 15 - JeepForum.com
post #211 of 218 Old 02-03-2012, 11:23 PM Thread Starter
ninjastar
Its called cleghorn.
Just finished installing my cobra 29 ltd bt with a firestik 5ft antenna and Im having an issue with the antenna light. I have low swr 1.5 ch 20 1-1.2 ch 1 and 2 ch 40 and everytime I key the mic the antenna light comes on.
ninjastar is offline
post #212 of 218 Old 06-13-2013, 10:17 PM Thread Starter
ninjastar
Just bought the ignition kit from kolak and now going to work on my differential and replace my oil pan gasket and sensor. Any one have any input on what different cover to put on the front axel which are dana 30. Looking to get the riddler. Also what are you guys though on the acos with my lift even tho I don't have long arms yet?
post #213 of 218 Old 06-13-2013, 10:30 PM
dillonjm
2013 WK
Never had a Riddler cover, but I've run Solid covers on previous rigs and they held up well.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #214 of 218 Old 06-14-2013, 09:51 PM Thread Starter
ninjastar
So far my jeep has the following
-K&N CAI
-iro 3.5 lift
-JKS qs
-iro front and rear adj track bar
-31KM2
-Custom 1.25in front bump stop
And I just bought the ignition system from kolak
Now I want to do the following but I don't know which order would be best.
-rear 8.8........any tips of suggestions here
-Front dana 30 upgrading
-Riddler cover
-Internal upgrades........anyone have a place for me to start to upgrade
-entire tie rod assembly
-Oil pan gasket and sensor(Oil Low keeps poping up and is leaking around the area)
-Control arms(where should I start or get first)
-ACOS
-Long arms when money permits
-custom rockers/rear bumper
-winch
-roof rack and light bar.
post #215 of 218 Old 06-15-2013, 12:12 PM
Erbo1Kanerbo
I would fix the oil pan issue first because that is a problem that is costing you money. Then get long arms add an inch of lift then 33s or 35s address the steering then armor up
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #216 of 218 Old 06-19-2013, 10:49 PM Thread Starter
ninjastar
Just finished the kolak ignition kit along with xp3923 iridium spark plugs gapped at .042 also replaced my egr valve which made my life easier since replace the cap and rotor helped with the egr replacement and vice versa
How does the long arms add a inch of lift? I think my next fix would be the oil leaks but both my front and rear diffs along with the oil/trans pan and transfer case all have minor leaks. So where should I start first and also the oil level keeps going off every once and a while even thought the oil level is good.
post #217 of 218 Old 06-19-2013, 11:41 PM Thread Starter
ninjastar
Also what are your guys thoughts on this
http://shop.perma-cool.com/19112-Hig...-CFM-19112.htm
post #218 of 218 Old 07-01-2013, 02:56 PM Thread Starter
ninjastar
Kolak ignition system installed with iridium plugs and now I just ordered monstaliner and hopefully I get it before the 20th this month for I leave to Ft McCoy.
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 09:18 PM
"Oscar the grouch" build thread mrtosh WK Grand Cherokee & XK Commander Forum 654 05-30-2013 12:25 PM
My "I should have bought a FJ Cruiser" build scemracing WK Grand Cherokee & XK Commander Forum 23 05-10-2012 05:23 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
build sheet in "inbox"! j.love ZJ Grand Cherokee Forum 12 10-17-2006 10:17 AM
