"Bahamut" 93zj limted 5.2l Build - Page 13 - JeepForum.com
post #181 of 218 Old 01-05-2012, 02:04 PM Thread Starter
ninjastar
Okay just ordered my shocks from kolak and hew recommend 5100s for the front and 5125 for the rear. So Im waiting for my iro 3.5in benchmark kit with jks disconnects and new rear coils. Now the question is would I need extended brake lines because of the lift and my using the jks disconnects?
ninjastar is offline
post #182 of 218 Old 01-05-2012, 03:43 PM
nickwygant
i would say yes on the brake lines get some from iro when i bought them they were 99$
when you flex and turn with out a sway bar you will need them!!!!
this pic is with 3.5 iro coils LOVE THEM
keep up the good work !!!! lets see some more pictures
nickwygant is offline
post #183 of 218 Old 01-05-2012, 04:21 PM Thread Starter
ninjastar
So lets say I didnt disconnect my sway bars, would I be safe then?
post #184 of 218 Old 01-05-2012, 04:24 PM
PolkaPower
I had 4.5" for a while without new brake lines. I never tore one. Came close though.
PolkaPower is online now
post #185 of 218 Old 01-05-2012, 04:42 PM Thread Starter
ninjastar
Is that with you flexing or off roading?
post #186 of 218 Old 01-05-2012, 07:24 PM
nickwygant
you might be fine with not taking your sway bars off but you got disconnects for a reason!!! right?? . since your doing all this might as well buy some brake lines at least the fronts!
post #187 of 218 Old 01-06-2012, 09:17 PM Thread Starter
ninjastar
Thats true. But is it easy to change the brake lines and I dont need them after my lift If I dont go off roading for a while right?
Also does anyone know a tut that has pictures installing a IRO 3.5in lift?
post #188 of 218 Old 01-08-2012, 12:54 AM Thread Starter
ninjastar
Was very disappointed today. I received 2 of the 3 shippments from kolak and iro yesterday and the last shippment today. I was hopeing to come home from work to fully install my lift, but when I opened the box it was just the front coils and no rear coils. So I emailed iro and still waiting on their response. After that I just said f it and install everything till they ship me my rear coils.
So its now 7pm and its dark outside so I get my 2 flood lights and tools and got to working on it. Everything was easy to take out but the track bar bracket, took me 1hr to take it out. And while I was installing it, I let the axles drop as low as the can and even pushed it down with my feet and it looks like my brake lines still have enough play in them. Now the only question is do I need extened bump stops and or how did everyone install their bilstein shocks because I cant seem to tighten it down unless I use an allen wrench and a regular wrench to tighten it down(Fronts that is).
post #189 of 218 Old 01-08-2012, 01:39 AM
PolkaPower
This is the 3rd freaking time you have posting this garbage. You are officially a write off in my book. A lost cause. And the worst of all a whiner.
post #190 of 218 Old 01-08-2012, 02:03 AM Thread Starter
ninjastar
You know what. I DONT CARE.............three times
post #191 of 218 Old 01-09-2012, 11:53 PM Thread Starter
ninjastar
Jeep fully lifted, waiting on the rear adjustable track bar from iro. and then get my alignment and go for a test drive.
post #192 of 218 Old 01-10-2012, 09:31 PM Thread Starter
ninjastar
I was lookig at iros upper and lower control arms and I did some research from bent vs stright control arms. I know one is ment for strength and the other for clearence but which one is more perferable?
post #193 of 218 Old 01-10-2012, 10:11 PM
Freestyle713
1994 ZJ
You will have a hard time tweaking one of their bent control arms. Even though they are already bent, they are strong
Freestyle713 is offline
post #194 of 218 Old 01-11-2012, 09:42 AM Thread Starter
ninjastar
So whats the best way to go and what do you mean tweaking it?
post #195 of 218 Old 01-11-2012, 01:43 PM
Erbo1Kanerbo
get the ones with the bend you will be fine. By tweaking he means messing them up or bending them from their original state.
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 09:18 PM
"Oscar the grouch" build thread mrtosh WK Grand Cherokee & XK Commander Forum 654 05-30-2013 12:25 PM
My "I should have bought a FJ Cruiser" build scemracing WK Grand Cherokee & XK Commander Forum 23 05-10-2012 05:23 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
build sheet in "inbox"! j.love ZJ Grand Cherokee Forum 12 10-17-2006 10:17 AM
