"Bahamut" 93zj limted 5.2l Build - Page 11 - JeepForum.com
post #151 of 218 Old 11-22-2011, 03:13 PM
PolkaPower
That is a very nice place. Jeep looks good. I have always liked those old 4 runners too.
PolkaPower is offline
post #152 of 218 Old 11-22-2011, 03:37 PM Thread Starter
ninjastar
Thanks and after the run I wanted to get one too. But other than alot of close calls and going on hard parts on the trail with my somewhat stock jeep was scary and intense and to add ontop of it, it was after a rainning day so the easy trails became hard and the harder trails because very complex. It was a good run but I messed up the bottom of the front of the rear fenders due to the KM2s and since I messed up my fenders, it messed up tires cutting into the lugs of the tire.
Question
1-Is it okay if I did a complete 3.5in lift but then later just add the control arms,brake line and spacers to get 5.25in lift?
2-Along with a lift would their be anything else that has to be upgraded?
3-Does it matter what type of differential cover I get either it be aluminu or cast iorn for my jeep that is a dd and a fun toy?
ninjastar is offline
post #153 of 218 Old 11-22-2011, 03:59 PM
Freestyle713
1994 ZJ
1. yes
2. yes, a lot
3. i doubt it does. but i would probably not get an aluminum one because it is a vulnerable area and aluminum is a softer metal. and it would cost more.
Freestyle713 is offline
post #154 of 218 Old 11-22-2011, 04:04 PM Thread Starter
ninjastar
Originally Posted by Freestyle713 View Post
1. yes
2. yes, a lot
-does this apply to when i install the lift (ie 4in plus lift requires brake lines, control arms and so on) or just upgrade in general?
I heard aluminum was all just show and cast iron was much for str, but then I heard that cast iron will heat up faster.
post #155 of 218 Old 11-22-2011, 05:17 PM
PolkaPower
Why are you worried about a diff cover? Do you wheel it that hard that you need one? How about rockers and skid plates?
post #156 of 218 Old 11-22-2011, 05:38 PM Thread Starter
ninjastar
Well i was thinking if I change the diff fluid might as well change the covers aswell and its more or less for a little more protection. And as for the rockers I think my nerf bars do just fine as rockers even though their not ment for that and for the skid plates I have, for the gas, tansfer plate, and radiator.
post #157 of 218 Old 11-22-2011, 05:46 PM
Freestyle713
1994 ZJ
if you land those nerf bars on a rock, they will bend like Bill Clinton's dick
post #158 of 218 Old 11-22-2011, 06:03 PM Thread Starter
ninjastar
It didnt bend when I slid on a bolder and slid on it to drop down. And LOL
post #159 of 218 Old 11-22-2011, 06:14 PM
PolkaPower
Lmao
post #160 of 218 Old 11-22-2011, 09:23 PM Thread Starter
ninjastar
I was wondering what shocks would I have to get now with the 3.5in lift to be able to put in spacers in later in the future to go 5.25?
post #161 of 218 Old 11-22-2011, 10:21 PM
PolkaPower
I don't think you will be able to run one shock for both 3.5" and 5".
post #162 of 218 Old 11-22-2011, 10:38 PM Thread Starter
ninjastar
Dang their isnt one out their that would do that. So if not then what shocks should I go for that will best suit my zj that will perform great on the streets but as well as on the dirt?
post #163 of 218 Old 11-23-2011, 08:24 PM Thread Starter
ninjastar
Other that iro's kits is their any good but cheap way to get my jeep lifted 3.5in??
post #164 of 218 Old 11-24-2011, 10:01 AM
Freestyle713
1994 ZJ
you have no idea how much work is involved in a 5.25 inch lift. if you really want to do it, i would suggest reading up on every thing that would be needed. its not just as simple as coils and shocks
post #165 of 218 Old 11-24-2011, 10:38 AM
PolkaPower
You won't find a better deal than IRO unless you buy it used. Just go with the 3.5 and then see if you want to go higher later. With short arms and 5" it will handle and ride like a turd.
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 09:18 PM
"Oscar the grouch" build thread mrtosh WK Grand Cherokee & XK Commander Forum 654 05-30-2013 12:25 PM
My "I should have bought a FJ Cruiser" build scemracing WK Grand Cherokee & XK Commander Forum 23 05-10-2012 05:23 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
build sheet in "inbox"! j.love ZJ Grand Cherokee Forum 12 10-17-2006 10:17 AM
