"Bahamut" 93zj limted 5.2l Build - Page 10 - JeepForum.com
post #136 of 218 Old 10-29-2011, 09:46 PM
Freestyle713
1994 ZJ
do you have lsd? i used pennzoil 80w-90 with no limited slips and it works fine.
Freestyle713 is offline
post #137 of 218 Old 10-30-2011, 01:56 AM Thread Starter
ninjastar
Well I read the manual and it says I need to and lsd to the rear. If I just get 4qts of 85w-140 of royal purple or lucas would I bee good to put that in the front and rear even if the front doesnt need lsd which is already added in these synthetic oil??
ninjastar is offline
post #138 of 218 Old 10-30-2011, 08:54 AM
PolkaPower
You could use it in the front but it would be a total waste. The front just needs regular gear oil. I have 75-90 in the front and Royal Purple 75-140 in the rear. Save the expensive stuff for the rear.
PolkaPower is online now
post #139 of 218 Old 10-30-2011, 08:20 PM
Freestyle713
1994 ZJ
find your build sheet and find out if you have ls. if you dont have it, then you dont need any fm
post #140 of 218 Old 10-30-2011, 08:43 PM
PolkaPower
They didn't put to many LS in the eary ZJ's did they?
post #141 of 218 Old 10-30-2011, 09:21 PM
Freestyle713
1994 ZJ
they did in some of them, idk how many though
post #142 of 218 Old 10-30-2011, 11:37 PM Thread Starter
ninjastar
Well thats what the 93 zj repair book says so idk.
So this in the front.
http://www.4wheelparts.com/Performan...&t_pn=LUC10047
And this for the rear??
http://www.4wheelparts.com/Performan...&t_pn=LUC10121
Also if im changing my diff fulid should I change the covers or are the oems good enough for basical off roading?
post #143 of 218 Old 10-31-2011, 08:31 AM
PolkaPower
If you have a LS in the rear you need friction modified fluid or the additive. As for the diff cover, I don't think it will be an issue unless you start trying to drive over large rocks.
post #144 of 218 Old 10-31-2011, 09:09 AM
Freestyle713
1994 ZJ
the only 2 recommended for use in zjs is 80w-90 and 75w-140, the 75w-140 being used if you do a lot of towing. so if you dont do a lot of towing, the 80w-90 is best.
http://www.amazon.com/Penzoil-Gear-Oil-80W-90-1Qt/dp/B0002KL09S/ref=sr_1_28?ie=UTF8&qid=1320073722&sr=8-28i got three of these
post #145 of 218 Old 10-31-2011, 11:18 PM Thread Starter
ninjastar
Can I possibly run 75w-140 just for the use of towing people if I have to but it barly sees dirt maybe once every 2 months or should I just stick with the 80w-90?
post #146 of 218 Old 11-01-2011, 08:09 AM
PolkaPower
Towing means towing a trailer or some other large heavy object for lots of miles. Not pulling someone out of a hole.
post #147 of 218 Old 11-01-2011, 08:33 PM Thread Starter
ninjastar
I knew that xP.Is penzoil the best or is their a better brand?Like is lucas or royal purple on par, bellow or better?
post #148 of 218 Old 11-01-2011, 09:48 PM
Freestyle713
1994 ZJ
pennzoil is a pretty trusted brand, idk if theyre the best, but its pennzoil. who hasnt heard of them? and its just gear oil. not engine oil. and plus, you cant beat the price
post #149 of 218 Old 11-22-2011, 03:04 PM Thread Starter
ninjastar
post #150 of 218 Old 11-22-2011, 03:05 PM Thread Starter
ninjastar
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 09:18 PM
"Oscar the grouch" build thread mrtosh WK Grand Cherokee & XK Commander Forum 654 05-30-2013 12:25 PM
My "I should have bought a FJ Cruiser" build scemracing WK Grand Cherokee & XK Commander Forum 23 05-10-2012 05:23 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
build sheet in "inbox"! j.love ZJ Grand Cherokee Forum 12 10-17-2006 10:17 AM
