AP's 5 Speed WJ Build - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > AP's 5 Speed WJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 10-27-2009, 09:40 PM   #91
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by AgitatedPancake View Post
Haha your aussie ships out when I win the lottery .
Well you're no fun.
I can pay shipping if that is the problem.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 10-27-2009, 10:22 PM   #92
TX-WJ
TX-WJ's Avatar
Gear pattern looks nice . Just curious, why not 4.88s or 5.13s, I mean, you'll be good for 37s soon anyways....
David.
2004 WJ Ltd. (steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd JK Rubi D44s
TX-WJ is offline   Reply With Quote Quick reply to this message
Unread 10-27-2009, 10:30 PM   #93
AgitatedPancake
I wasn't in the mood for having to mess with regearing the D44 again, its a PITA in comparison to the 9". Besides, I now have a used 5.43 gearset waiting for the 9" for whenever I do go up in tire size
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 10-27-2009, 10:33 PM   #94
AgitatedPancake
Oh and something badass, the new 4.56's used the same pinion shim stack that the 5.43's did, how nice is that.
Unread 10-27-2009, 10:38 PM   #95
TX-WJ
TX-WJ's Avatar
Yeah, I hear you, I'm not looking forward to gearing my 44s...... I need to fab a case spreader; you and your 3rd member suck
David.
Unread 10-27-2009, 10:42 PM   #96
GraKee99
Rapist Wit
GraKee99's Avatar
Go to 40s FTW!
Brian
WJ, WK, CJ5
Unread 10-27-2009, 10:45 PM   #97
AgitatedPancake
Everyone said you don't need a case spreader, you can pull the carrier with prybars and get the job done. I personally built a case spreader out of an old craftsman jack haha.
Originally Posted by GraKee99 View Post
Go to 40s FTW!
Don't tempt me
Unread 10-27-2009, 10:48 PM   #98
GraKee99
Rapist Wit
GraKee99's Avatar
Don't tempt me
I have always heard doing it with prybars is a bad idea. This is why I haven't installed my ARB yes in the 30. I guess if you are careful.
And you know you want to.
Is thing going to make it to GSW this year?
Brian
WJ, WK, CJ5
Unread 10-27-2009, 10:51 PM   #99
TX-WJ
TX-WJ's Avatar
^^^ I'm thinking some angle iron and all-thread ought to do it, I hope. Tried to pull the carrier out of the 44a the other day, and even with my super-duper-strenght and prybars, it wouldn't budge.....guess it's wedged in there pretty good after my carnage .
David.
Unread 10-27-2009, 11:59 PM   #100
phant0omx
2012 WK
Originally Posted by bigbluezj94 View Post
dude you need to go read a book or something. backlash is the play between the pinion and the ring gear. there are certain specs that differ between axles and are measured usually with a dial indicator in .000" thats the jist of it. there is alot more to setting up gears. which is prob why you are paying someone a few hundred bucks to do it . i read randys book like 2987 times then took my time and did mine myself as a local shop wanted like 350 per axle...
cool beans. yes, you are correct in assuming why i'm having a shop set the gears and not me. i will be reading up. thanks for the initial help though.
Agitated, sorry to semi hijack for a few posts.
phant0omx is offline   Reply With Quote Quick reply to this message
Unread 10-28-2009, 12:01 AM   #101
Bama_WJ
I took my 30 apart without a case spreader and it was a huge PITA. Getting the carrier out wasn't so bad, but you basically had to be the hulk to put that carrier back in there.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 10-28-2009, 02:21 AM   #102
AgitatedPancake
Yeah the case spreader made doing everything bearable, but MAN it was under some serious load heh. Kinda scared it would spring out.
I don't know if I'm gettin out to GSW or not yet, I'd love to though!
Tomorrow I'm planning on doing some housing work, adjusting the shock mounts to work for me and do the mounts for the chain limit straps
Unread 10-29-2009, 06:26 PM   #103
AgitatedPancake
Doin some more work! And chose a color combo for the axle, should be good.
Started by tearing apart the 44a, she served me well.
Something looks wierd...
Ouch. This puts all potential sales on hold until I can verify the carrier is still good to go.
Banged up, shim still in place
Shim off
Now kids, let this be a lesson not to drive 5 miles on a broken axleshaft, unless you WANT it to make you upgrade
And here are the axle colors together; flat black and a hammered bronzy coppery color. I like it. The centersection, brake brackets and claytons links are going to be that color and the rest will be black.
Parts yum. You can see the colors better here
Had to chop off part of the old shock mounts to orient them differently, how convenient. I found a place to use the part I cut off, as new limiting strap mounts!
Aaand link color vs jeep...not too bad but I don't expect the jeep to stay this color for too much longer.
Unread 10-29-2009, 06:35 PM   #104
Shinobi
nice will you be selling your D44a Aussie locker ? If so PM me please
I like the color scheme
Shinobi is offline   Reply With Quote Quick reply to this message
Unread 10-29-2009, 09:24 PM   #105
bigbluezj94
1994 ZJ
i was going to paint my links some other color but then i figured it they are just going to get thrashed so i just sprayed them black lol. looks sweet though. get that axle under there.
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
