AP's 5 Speed WJ Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > AP's 5 Speed WJ Build
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 04-15-2009, 10:23 PM   #1
AgitatedPancake
Alright I guess it's time for me to get some of my truck up here...though this is definately gunna be a shortened version!
Got the jeep as my first car at 17, less than a year later had it lifted 4" on 33" MTR's.
Had some fun on the rubicon my first time ever in the spring when its slick and WET
REALLY wet. I circled the waterline.
Then came the claytons
Then I started building it a bumper
Cut my fenders some later on
And widened my sliders
Pulled a front 44 from a full sized cherokee
and got the gears set right on the THIRD attempt...took a long time.
D30 coming out
and the D44 goes in:
Spliced the waggy's steering sleeve onto the WJ's for my draglink
***DONT DO THIS, SHOWN WHY FURTHER DOWN***
*Continued*
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote
Unread 04-15-2009, 10:26 PM   #2
AgitatedPancake
Also my single UCA on the passenger side
***/FAIL***
So here I am with it "done"
Flexin it out the first time, nice
Now a while down the road, my single UCA mount failed
*****UCA MOUNT FAILURE*****
Tore through 2 peices of 1/4" plate, but it was a bad design on my part.
Hit the brakes too hard, UCA mount tore off and the whole axle rotated forwards ALOT. Springs removed themselves from the upper perches, it snapped both my shocks and broke the straps out of the front DS yoke.
Oops.
SO It was time to rebuild the upper mounts, and do it the right way.
Left side in the pic is a 1/2" plate with a hole bored in it with tube for the bushing, 3/16" support. The truss is 2x2x.250 tube with the tube welded on, it's been years like this now with no issues.
Then I swapped the engines, after this incident it never ran right after...
Out with the old,
Reman goes in-
Then the new engine had to come BACK out because the guys who built it didnt tighten down the cam gear bolts so one of them spun. No internal damage. Got it fixed and back together, have over 2k miles on it now, the swap was completed about 2.5 weeks ago I'd guess?
After that hassle, built some upper coil retainers.
Unread 04-15-2009, 10:31 PM   #3
iananderson17
You officially have my vote for greatest build thread name yet.
Originally Posted by 2jhanna View Post
This has got to be the first thread where a free gear upgrade was done. At the start, the OP had 3.07 gears, now he has 4.10 gears. And it didn't cost him a dime.
Show that to your dad !!
iananderson17 is offline   Reply With Quote
Unread 04-15-2009, 10:32 PM   #4
CaribouLouWJ
2007 WK
thanks for all the ideas on what not to do
2007 WK Overland
5.7 Hemi, 18% tint, baby seats
2000 F350 PSD CC LB
2001.5 B5S4 500awhp gutted track car
2002 WJ Limited
4.7 HO, 6.5" LA, 37's, JK 44's SOLD
CaribouLouWJ is offline   Reply With Quote
Unread 04-15-2009, 10:41 PM   #5
AgitatedPancake
Now the reason for saying DON'T DO YOUR DRAGLINK LIKE I DID!!!
Yeah...I cranked to hard and snapped the draglink near one of my welds...so we made a new one on the trail. This happened after having a BAD time with the stock waggy tie rod. I bent it early on and kept pushing it. It kept bending back so far the draglink TRE nut was hitting the lower track bar bolt and not allowing me to turn, so we stopped there for the night and did some custom work on the tie rod...
Over on the drivers side you see my hi-lift handle over the factory BEND in the waggy tie rod...I pounded it over the bend by hand by slamming it on a rock. I woke up with blisters in the morning. On the drivers side we welded a little angle iron to the back using our batteries, it also acted as a skid across the head of the track bar bolt. Got me further into the trail, then back out, then 100 miles home.
But it was enough - Flat top knuckles, high steer arms, new balljoints and 1 ton steering. YUP.
This is how I roll now:
I was also dog tracking BAD after that trip. I wonder why...
Normal:
Hmm.
Later on, got my 35" swampers I'm running now...
Snow wheelin/camping trip with swampers =D
Gas tank raise
Before:
AFTER
Built a tunnel for the fuel hoses to run through inside.
And another wheelin trip:
Unread 04-15-2009, 10:43 PM   #6
DothanJeep
PISSED OFF PANCAKES!!!!!
Nice build man!!! love the Jeep!
and I love Pancakes... ( 22 to be exact )
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline   Reply With Quote
Unread 04-15-2009, 10:46 PM   #7
CaribouLouWJ
2007 WK
Nice steering.....I'm going assist with the 44 up front, I was having a bad enough time with the 35's, the 37" Creeps are going to murder my PS pump
2007 WK Overland
2000 F350 PSD CC LB
2002 WJ Limited
Unread 04-15-2009, 10:48 PM   #8
AgitatedPancake
Fast forward to what i've been working on recently...
and rolled over
Bumpstop extensions
New lower shock mounts for the axles
And new upper shock mounts, in the form of a new crossmember kinda.
SNAP
Then I got into building my bumper, which is where I am currently =D
Step one: Clearancing all the way up to the floorboards, lots of cutting and some sheetmetal welding.
1/4" plate
Transforming...
Shape tacked in, transforming more...
Storage =D
Shaping...
And shaping...
Yup...
Hitch going in and getting supported...
Mounts
Unread 04-15-2009, 10:52 PM   #9
AgitatedPancake
The other side gets trimmed to match, came out cleaner
Yay kinda hidden hitch!
Dunno if i'm going to be fully welding those supports yet, probably.
Underside, protected.
AND THATS WHERE I AM! Crap....that was a LOT of pictures...
Cairbou - yeah I wouldn't mind the assist, when I go bigger I'm gettin it for sure, I even had problems with my 33's at one point.
Thanks for the comments guys! =D
Unread 04-16-2009, 12:04 AM   #10
rustynail
Location: Vancouver, British Columbia, British Columbia
Everything's just awesome. The bumpers are so original and aggressive. Nice work
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline   Reply With Quote
Unread 04-16-2009, 04:59 AM   #11
retroron
i have to say i really like the fab work!
Jesus saves
christian jeepclub#170
retroron is offline   Reply With Quote
Unread 04-16-2009, 06:08 AM   #12
2007GC Overland
2007 WK
Hi Great build and great job! somebody is a very good welder.
thanks
bill
2007GC Overland is offline   Reply With Quote
Unread 04-16-2009, 07:37 AM   #13
spidermonkey
It makes me want to build a dubya. Awsome job man.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 4" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote
Unread 04-16-2009, 07:53 AM   #14
fivespeedsteed
hell yeah dude id say you know a thing or 2 about welding. this is about one of the couple dub builds that are all balls to the wall. everything in this build is just fabbed beef. great build bud.
2007 Ford F150
1990 Mustang GT
2001 Jeep Grand Cherokee Laredo - sold
2001 Yamaha Waverunner gp1200r
fivespeedsteed is offline   Reply With Quote
Unread 04-16-2009, 07:57 AM   #15
Ridin' Around
This is a WJ that I have lusted after for quite a while on here. Thanks for all of the do & the DONT'S. Those are very helpful. Great photos & thread.
Ridin' Around is offline   Reply With Quote
