AP's 5 Speed WJ Build - Page 76 - JeepForum.com
 4Likes
post #1126 of 1162 Old 10-26-2013, 11:44 AM
gcjeeping
gcjeeping's Avatar
I bought and use this. JD2.
_____________
gcjeeping is offline
post #1127 of 1162 Old 11-19-2013, 10:58 PM Thread Starter
AgitatedPancake
The harbor freight roll bender has been absolutely awesome once I added the wings to it (SWAG offroad style). The regular tube bender I've been using has been a JD2 model 3 for the most part. Now that I'm at the shop I'm lucky enough to have some awesome Mitler Bro's equipment to work with, but that's way outside the realm of everyday garage work.
Soo there have been some big updates, as in the jeep is completely mobile!
Flange for the 205
Superduty 1350 front driveshaft
retubed with 2 3/8 .188 wall, with pucks machined to adapt sizes on the ends
Zeroing using the lathe, tools are nice haha.
Then I went wheeling. ~70 miles each way. Drove up to Fordyce, wheeled all weekend, slashed a tire which had to be replaced with spare but otherwise no problems before driving back home and putting another 100+ miles on it in the last week or two. It has been AWESOME, and put a huge smile on my face.
Coming down winch hill 3 bypass
Finally bent a Claytons UCA. No disrespect to them, this is 7-8 years of HARD abuse and I know exactly when it happened this trip, I was flogging my jeep HARD that weekend.
Aaaand bent my new crossmember. 2x1" .120 is not enough for hard hits lol.
All in all things are great with the WJ. Needs TLC after the weekend but still has no problem on the road
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #1128 of 1162 Old 11-20-2013, 06:07 PM
TJSWJ
That's insane about that control arm! Are you gonna see what they say about it, or just build your own new suspension?
Good to hear about the hf roller. I plan on buying that (with swag upgrade), a jd model 32, and bendtech software here in the next few day.
How wonderful was it having all those low t case options?
TJSWJ is offline
post #1129 of 1162 Old 11-20-2013, 06:39 PM
platinum5.9
2003 WJ
I knew if someone could bend one of there arms it would be you!! I'd be curious to see a few more pictures.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #1130 of 1162 Old 11-20-2013, 07:50 PM Thread Starter
AgitatedPancake
Oops I said UCA - I meant LCA haha. I'm not even worried about having Clayton's do anything about it. I've moved the radius arm pickup points a few times so they aren't in the original positions which might void the warranty anyways, but I'm not worried. I sincerely believe I've gotten every pennies worth out of this kit, and I'm just going to make a new control arm. HF roller w/swag weld on wings, a bender like those from JD2, and bend tech is all you need to make some magic happen . The tcase options were just about all I could ask for and worked as I'd hoped. I ran around in the 1.96:1 low of the 205 for most of the wheeling, then dropped into double low to slow down when going up or going down things.
I'm surprised I was able to bend one of these arms, but it had to happen sooner or later haha. I'll snap some more pics of it, but you can see it in the bent crossmember pic as well.
Build Thread:
post #1131 of 1162 Old 11-21-2013, 09:20 PM
TJSWJ
I figured you weren't worried about it. I know you've been wanting to build a suspension like you did on Marc's. Can't wait to see what you do.
TJSWJ is offline
post #1132 of 1162 Old 11-22-2013, 06:46 AM
wj4play
Random question - how are your rear wheel bearings and seal holding up with those size tires?
Sent from busted up iPhone
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #1133 of 1162 Old 11-22-2013, 10:48 PM Thread Starter
AgitatedPancake
I haven't decided if it's time to rebuild the suspension yet or just build a new identical LCA. I will actually probably end up leaving the control arms almost as they sit if I do a 3 link, but that will probably be a ways out. I expect to get some snow wheeling in this winter and don't want to take it off the road for any projects. This is time to enjoy it all .
My wheel bearings haven't been a problem for me at all. Up front I'm running D60 outers so with my 36" tires I'm not even close to the limit compared to people running 40-42" tires and still lasting relatively well. In the rear I have the factory big bearing ford 9" bearings, and I have not replaced either one since I bought the axle years ago. I didn't even replace them then, they looked good enough to run. My front inner axle seals are just starting to weep, but my guess is I need to repack them with grease...I expect the seals to be good. In the rear my wheel seals are starting to weep, but I blame that on the fact I think I've started bending the factory 9" housing. I don't know that for sure yet and I've got to put a jig bar through it next time I have things apart to see how bad it is. If it's bad enough, another Ruffstuff 9" housing may be in the future for this jeep but I'll pull every bit of life out of this factory housing before I go that route.
Working windows is high on my to-do list, so I can snow wheel this winter without the potential of getting soaked. I've done many trips without working windows, and it's not the cold that gets ya it's the wetness. But with working seat heaters and a working heater, things are awesome either way lol!
Build Thread:
post #1134 of 1162 Old 11-23-2013, 08:31 AM
wj4play
Here in Iowa - no windows = freeze your butt off regardless of heated seats and heater
Thanks for the info on the status of your seals - not sure what direction I want to go - I like my 37"s on factory rims which would work on the 9 I have but again once I put the axles in I never want them to leak or break
wj4play is offline
post #1135 of 1162 Old 11-23-2013, 08:42 AM
CRJEeP_wj
You have any more pics of your fordyce trip? Have you tried wh3 before without taking the bypass?
02 grand cherokee, hp60 14b, 42s. Stazwork, triangulated 4-link, rear leafs, homemade bumpers and sliders. build thread
CRJEeP_wj is offline
post #1136 of 1162 Old 11-23-2013, 12:00 PM
sdmayhew
Their is a generic heat seater kit that is calling my name on ebay
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline
post #1137 of 1162 Old 12-02-2013, 10:21 AM
kaserWJ04
Nice rig! looks like it was a pain in the *** to work on!
kaserWJ04 is offline
post #1138 of 1162 Old 03-17-2014, 05:57 PM Thread Starter
AgitatedPancake
Hey everyone! The jeep is still alive and kicking . Beat the crap out of it at KOH last month, and it spurred me into building a race buggy.
If you're interested in what I'm doing for the buggy build, like my facebook (link in sig). I put pictures up pretty regularly of all the different stuff I work on.
Here are a few teasers though:
Mid engine LS
6L80E 6 speed paddle shiftable automatic
242HD tcase out of a WJ
Flipped HP60 rear axle
Flipped Sterling 10.25 front axle
Cantilever front and rear suspension, 14" coilover netting ~22" travel
So yeah...nothing too new for the WJ except for using and enjoying it. Though I'm still having fun haha
Build Thread:
post #1139 of 1162 Old 03-17-2014, 06:07 PM
MurdaJs
Front and rear canti lever, hope you have some Advil and scratch paper! Lol
MurdaJs is offline
post #1140 of 1162 Old 03-22-2014, 12:13 AM
straightsixjeep
Incredible work in here, excellent job! Sub'd.
http://www.jeepforum.com/forum/f22/98-xj-gettin-her-trail-ready-1417602/
straightsixjeep is offline
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
ZJs with the AX-15 five-speed - how many? HMX ZJ Grand Cherokee Forum 5 11-18-2012 11:28 PM
05 WK single speed x-fer case to two speed? tednelson83 WK Grand Cherokee & XK Commander Forum 10 02-18-2007 07:27 PM
Top speed? Arcticcat843 WK Grand Cherokee & XK Commander Forum 33 01-08-2007 10:09 AM
93 318 5-speed?!?!?!? skier123 ZJ Grand Cherokee Forum 5 07-12-2005 01:55 PM
