AP's 5 Speed WJ Build - Page 73 - JeepForum.com
 4Likes
post #1081 of 1162 Old 06-26-2013, 10:44 PM Thread Starter
AgitatedPancake
I've got fun stuff stirring for the jeep
Brought my Ford NP205 over to the shop
Tore it apart, sandblasted things
Took a 231, tore it apart, cut the front output off and sandblasted it
Found the drawing for a 231 doubler online and cut it out of sheetmetal to see if it was accurate, and figure out the ideal configuration for the clocking ring.
Front yoke gets close to the 231, but close is perfect . Now it's time to cut the real doubler out of a couple pieces of 3/8" plate, build it and get the correct midshaft made by Dean @ Kickass Offroad
Indestrucable doubler and bigger driveshaft u-joints here I come . Game on!
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #1082 of 1162 Old 06-26-2013, 10:48 PM
dillonjm
2013 WK
Looks good.
What happened to the tcase mounting surface on the driver side of the transmission?
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #1083 of 1162 Old 06-26-2013, 10:55 PM Thread Starter
AgitatedPancake
Thanks Dillon! That part of the trans...I broke it heh. I've been trying to source another rear case half for the transmission, but no such luck yet without buying another entire transmission. With the new doubler build I'm going to be building a full new mounting solution for the trans and the heavy NP205, so I will be able to absorb a lot of the torque before it reaches the trans-tcase mounting surface. I don't know if that will be enough in the long run, but until I find a new case half this is what I got haha.
Build Thread:
post #1084 of 1162 Old 06-26-2013, 11:04 PM
Shinobi
Thats going to be sweet, what will your expected crawl ratio be in low low ?
Shinobi is offline
post #1085 of 1162 Old 06-26-2013, 11:18 PM Thread Starter
AgitatedPancake
I'm at about 48:1 right now, this will put me around 96:1 which should be perfect for the technical times I'm currently slipping the clutch to get through. In 95% of the wheeling I do I figure I'll be using the 2.72:1, even may use the 1.96:1 of the 205 depending on how well the gears work out.
Build Thread:
post #1086 of 1162 Old 06-30-2013, 09:15 AM
sdmayhew
Greg wouldn't it be better to go to a 241or like I have? My final ratio is 80 to 1 with the rubicon transfer case. Nv3550 and 4.89 in the yota axles.
Squirrel .. Might be able to get into barret lake on one of the clean up crews!
1993 ZJ Clayton long arms with Johnny joints, custom front axle W yota center, D44 chevy outers, fabtech dirtlogic 2.25, front bilsten rear shocks, tacoma rear axle, 4.88, arb rear, 5 speed, poly motor mount inserts, NP241OR 4-1 ,receiver front for xcr 8k winch
sdmayhew is offline
post #1087 of 1162 Old 07-12-2013, 01:55 AM Thread Starter
AgitatedPancake
Shawn while the 4:1 would work well for me in the slow technical crawling sections, realistically I use my current 2.72:1 in most wheeling situations without regret. My group and I maintain a pretty good pace while were wheeling. I'm actually even excited to use the 1.96:1 low of the 205 for just cruising. I'll probably only use the double low 10-20% of the time. Though the options with the twin sticks and ability to control front and rear wheel drives individually is exciting. I really need to get my ebrake in working order to make front digs as effective as they can be.
Build Thread:
post #1088 of 1162 Old 07-12-2013, 07:35 AM
FleshEater
2014 JK Wrangler
I haven't been on here in awhile. It's great to see you're still rockin this WJ!
This has to be one of my favorite WJ's ever. Every time I see this, I imagine it crawling from the depths of Hell with South of Heaven screaming in the background.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #1089 of 1162 Old 07-12-2013, 08:21 AM
sdmayhew
Funny thing is I did half of Barrett lake jeep trail last weekend with the clean up crew. The trail is so tough that I was in first gear 75% of the time. Comment from trail boss was that trail was roughest he has ever sen it in 30 years.
However between the tough technical sections I was shifting up to 3rd or 4th gear to get moving. Which is your point
I need to stop be and have you build the belly pan. It was rough going with 33's as I scrapped quite a bit on everything underside.
sdmayhew is offline
post #1090 of 1162 Old 07-12-2013, 06:50 PM Thread Starter
AgitatedPancake
Oh I'm so entirely jealous right now! Is the trail open or was this one of the cleanups you were telling me about? I sure hope it has the potential of opening to the public soon! Especially if it's more challenging, that will be even more fun. At first I had a hard time with my lack of crawl ratio, but as I adapted to how the jeep wanted to be driven I became extremely comfortable with it. I do a log of my technical crawling in the 500-700 RPM range. This soupbowl isn't my smoothest driving ever, but pretty dang controlled all the way through
Let me know when you're ready to do the belly pan, we'll get a solid plan together and I'll make it happen for ya.
Some more has been going on with the doubler build, check it out!
Doubler ring that bolts to the 205.
Here's the doubler plate itself, the outer holes were undersized so the poor cut quality doesn't hurt things.
Fiiiinally pulled the automatic shifter out of the console, and replaced it with the new twin stick shifters for the 205.
The shifter solution is going to be pretty damn slick...just wait
Build Thread:
post #1091 of 1162 Old 07-12-2013, 06:59 PM
wj4play
Video Link: http://www.youtube.com/watch?v=hMaSqxOen4U
That shifter is slick
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #1092 of 1162 Old 07-12-2013, 11:07 PM
gcjeeping
I'm gunna have to run by your place soon to check it out since i'm in Rocklin now.
_____________
gcjeeping is offline
post #1093 of 1162 Old 07-12-2013, 11:44 PM Thread Starter
AgitatedPancake
Hell yeah! My shop is down by where Sunrise hits 50 so you've got a little drive down Sierra College/Hazel, but I'd have fun hangin out and seeing your thoughts on things
Build Thread:
post #1094 of 1162 Old 07-13-2013, 09:42 AM
sdmayhew
Greg I went in with the highlanders 4x4 club. We were cutting the trail to where the new bridge is going to go. Sounds like bridge should be built soon. The hope is by fall to have it all done. I went in three years ago and the trail was not nearly as rough. Trail boss said trail was roughest he has seen it in 30 years.
I can attest to Greg's work seeing it in person.
sdmayhew is offline
post #1095 of 1162 Old 07-13-2013, 06:55 PM
gcjeeping
Let me know a good time to come by and an address. Mabey a few others would show.
_____________
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 06:47 PM
ZJs with the AX-15 five-speed - how many? HMX ZJ Grand Cherokee Forum 5 11-19-2012 12:28 AM
05 WK single speed x-fer case to two speed? tednelson83 WK Grand Cherokee & XK Commander Forum 10 02-18-2007 08:27 PM
Top speed? Arcticcat843 WK Grand Cherokee & XK Commander Forum 33 01-08-2007 11:09 AM
93 318 5-speed?!?!?!? skier123 ZJ Grand Cherokee Forum 5 07-12-2005 02:55 PM
