AP's 5 Speed WJ Build - Page 52 - JeepForum.com
 4Likes
post #766 of 1162 Old 08-06-2011, 07:51 PM
SplitNail
Looks like a **** ton of work!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #767 of 1162 Old 08-06-2011, 08:27 PM Thread Starter
AgitatedPancake
Haha definately more than I was expecting when I started, but when isn't it? It's all about how it turns out right? :P if it ever gets done...Crunch time!
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #768 of 1162 Old 08-08-2011, 05:43 PM
mtnmarc
How much did you lift your rocker panels when you cut out the rockers?
And you cut up the doors too right?
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #769 of 1162 Old 08-08-2011, 05:59 PM Thread Starter
AgitatedPancake
Yep! I don't know how much actual clearance I gained, but I ended up cutting out the entire rocker and like 1.5" out of the doors
Build Thread:
post #770 of 1162 Old 08-08-2011, 07:03 PM
mtnmarc
Dang, I really like how high your rockers are. I have so much I want to do, but not enough tools.
mtnmarc is offline
post #771 of 1162 Old 08-09-2011, 04:40 PM Thread Starter
AgitatedPancake
Raising my rockers that high has made SUCH a difference, even for overall trail comfort as I don't hit them nearly as often, not as much jarring action throughout a day.
I put in a pretty good day of work today, but wrapping up early because I'm volunteering at a race shop with some cool super experienced guys and BADASS technology I'll get to learn and possibly play with .
I welded the nuts into the new structure, and welded tabs to the headlight bar to create the hinge I was talking about. I have the whole headlight bar rotated up here, you can see the tab.
From the bottom, you can see I have it propped outward by the old support bar hah. I've still gotta add the 3rd mounting location to make accurate adjustments possible
I did most of the finish welding on the front bar and side plates, the passenger side frame rail is plated back in, the front structure is welded in and I'm doing mock up for the first bar of the real engine cage. The long square will become a nice foot dropping down to the frame rail. Where the square tube will meet the round is near a flange I put in to keep the engine easily removeable. Anyways that joint will eventually have another bar added running rearward to what will be my "dash bar" which will be located inside the cowl running from one side to the other.
Build Thread:
post #772 of 1162 Old 08-09-2011, 04:43 PM
-Shoey-
2010 KK Liberty
Holy bejesus man. Great work.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #773 of 1162 Old 08-11-2011, 11:18 AM Thread Starter
AgitatedPancake
Hahahaha thanks!
So...I'm leaving tomorrow afternoon for a Fordyce wheeling trip...I gotta get this thing all buttoned up
I have the front engine cage bar built, and landing on some 1/8" pads on the fenders. Just gotta final weld it and it'll be good!
And I've got my uprights cut out, just need to clean them up a little with a grinder and get 'em welded in!
Still on the to do list:
-Make upper rad mount
-Eliminate melted connector in fan wiring, giving WAY too much resistance.
-Make turnbuckle device for headlights
-Reassemble drivers side fender/engine bay components
-Mount hood latch
-....I know theres more
Build Thread:
post #774 of 1162 Old 08-11-2011, 03:36 PM
mtnmarc
Awesome as always man.
mtnmarc is offline
post #775 of 1162 Old 08-11-2011, 07:13 PM Thread Starter
AgitatedPancake
I think it's comin out pretty damn well!
I finish welded the engine bar in place, got the uprights in, and i've been working on the upper rad mounts for a while now. They're almost done, just about ready to have the finish welding done, and I can call all the structuring finished!
The radiator mounts also serve to tie the two structures together so they worth together in strength.
Once I finish welding these up, I can start putting my engine compartment back together. I'm not sure I'll have a real hood latch by tomorrow afternoon when I'm leaving...we'll see!
Build Thread:
post #776 of 1162 Old 08-11-2011, 10:01 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
greg. just go with the hood pins like we did on my toyota.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #777 of 1162 Old 08-11-2011, 10:08 PM Thread Starter
AgitatedPancake
Yeah....we'll see. I'm a big fan of keeping things like that OEM. It keeps everything as simple and easy as it was from the factory, the only thing I need to do is make a mount off my structure for the latch itself. Not even much more work than hood pins in the long run, for awesome versatility
Build Thread:
post #778 of 1162 Old 08-16-2011, 10:41 AM Thread Starter
AgitatedPancake
Sooooo, I got my jeep driving on friday!!!
Once again I had to scramble to get the jeep ready and driveable (but not 100% complete) for a Fordyce wheeling/camping trip this weekend hehe. I started the jeep for the first time in over a month and with all the new modifications at 7PM friday, got it up to running temp to make sure the fan was kicking in properly and all. After that I threw clothes in a bag, took a shower, bought a little food and hit the road at 9 something that night with a buddy. We hit camp around 11:30pm, and going up 80 I could NOT get my jeep to go over 210 degrees no matter what I did). I dropped into 4th gear going about 50mph up one of the steep grades on I-80 heading up the Sierras (like 7% IIRC?) and pinned the throttle. I held WOT for probably 45 seconds until I hit 75-80mph going uphill and the temp gauge didn't bump at all. I don't know if things are acting better because the radiator is 100% upright and not raked back like it used to, or if that connector on the taurus fan (which I eliminated and soldered the wires together) was so beyond melted my fan wasn't working properly. Either way, all is good! I didn't have time to permenantly mount the grill or hood latch so it's a little ghetto fabulous, but it's going back into the garage to get finished up now.
Didn't have a single issue with any of my modifications all weekend.
And uh...my notorious issue with rear driveshafts reared it's ugly head again LOL. I was near the bottom of winch hill one and put my driveshaft on a rock after bouncing it off a few rocks earlier and weakening it. Luckily I carry 1 bolt in spare, and one spare that only needs a u-joint pressed in so I had it swapped in 15 minutes, and I ran up the winch hill for the first time . I need to build another pinion guard for the rear 3rd (the pinion guard I had is now on the front 3rd member because of my moonrocks gear breakage), and get the 205 in so I can run a CV and get the pinion pointed outta the rocks. Unfortunately both my cameras were dead when I went to leave so I have no pics of the trip
Build Thread:
post #779 of 1162 Old 08-20-2011, 07:58 PM
Cnolenwj
2000 wj limited, 4" IRO, long armed front.
Build thread-
North Texas Grands-
Grand Slam Texas-
Grand Slam Texas Group-
Cnolenwj is offline
post #780 of 1162 Old 08-20-2011, 08:47 PM
mtnmarc
carnage!
mtnmarc is offline
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
ZJs with the AX-15 five-speed - how many? HMX ZJ Grand Cherokee Forum 5 11-18-2012 11:28 PM
05 WK single speed x-fer case to two speed? tednelson83 WK Grand Cherokee & XK Commander Forum 10 02-18-2007 07:27 PM
Top speed? Arcticcat843 WK Grand Cherokee & XK Commander Forum 33 01-08-2007 10:09 AM
93 318 5-speed?!?!?!? skier123 ZJ Grand Cherokee Forum 5 07-12-2005 01:55 PM
