AP's 5 Speed WJ Build - Page 17 - JeepForum.com
 4Likes
post #241 of 1162 Old 04-11-2010, 04:10 PM
Shinobi
let me know when u go to little sluice I would love to see that !!!
Shinobi is offline
post #242 of 1162 Old 04-11-2010, 04:18 PM Thread Starter
AgitatedPancake
Oh for sure man! We gatta get Grand Slam Rubicon together forealz this year too!
I threw on the Dakota manifold and dropped the engine in place just to see how bad it would be if I went that route...yeah no thanks lol.
How the engine has been sitting for the exhaust work:
This is sweet. I was able to use all the factory tubing to make the new exhaust around the starter
I also pulled out the plasma and started cutting the framerail as necessary hehehe
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #243 of 1162 Old 04-13-2010, 07:16 PM Thread Starter
AgitatedPancake
Well, had to take a step backwards yesterday. I noticed the DS wasn't going to clear the new exhaust, so I had to cut the exhaust again and reshape part of it. I got it finished, now it clears the driveshaft at full bump also. the Y-pipe is finally 1 peice again, and I welded it up with the engine in the truck, to make sure I could pull it out as one peice. It's a tight fit, but I was able to even with the front axle at full bump! Then I finish welded it and called it a day. So, here are some pics of whats up. First off, the exhaust vs driveshaft from the perspective of the tcase yoke:
Manifold, starter, and frame rail
Newest version of the exhaust:
Today I went back and plated the frame rail. It was divided into two peices with that horizontal line because there is another peice of the unibody running there. I was able to weld to it as well so all factory structure is connected. I'm not sure if I'm done with it yet, I might add a larger top plate to disperse the loads. And sorry for the ****ty looking welds lol, I suck at vertical and had to fill a few gaps.
Build Thread:
post #244 of 1162 Old 04-13-2010, 10:10 PM
spife7980
awesome. i dream of being able to do a project like this one day.
and people actually o over those rocks in the "sluice"?! because thats ridiculous. might as well climb the sears tower.i would **** my pants just looking at it.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #245 of 1162 Old 04-13-2010, 10:32 PM
cj7guy
So which 5spd tranny are you running?
07 JKU - 6spd - LSD rear
cj7guy is offline
post #246 of 1162 Old 04-13-2010, 11:10 PM
GhostKnife
nice build
GhostKnife is offline
post #247 of 1162 Old 04-13-2010, 11:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
That's what I didn't want to do with my frame for my exhaust. But I probably will to put the long tubes in with the 408.
Can't wait to see your reaction to banging gears in the dub. Its fun as all get out in the zj.
ratmonkey is offline
post #248 of 1162 Old 04-14-2010, 07:53 AM Thread Starter
AgitatedPancake
Haha yes, yes they do. It's pretty much the hardest obstacle I can think of around here.
CJ7guy, it's an NV3500 from a Dakota
Thanks Ghost
Rat, if I were to build custom headers (I've thought about it), I could get the exhaust to dump in front of the starter instead of next to it, then you could squeeze it between the stock frame rails. I'll make sure to get a video of my...reaction...to bangin through gears lol!
Build Thread:
post #249 of 1162 Old 04-14-2010, 04:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
that's where the shorties i have now drop at. i'd love to throw a full dual exhaust under it.
post #250 of 1162 Old 04-15-2010, 04:46 PM Thread Starter
AgitatedPancake
I've looked into the dual exhaust also...looks very possible because of how small the NV3500 is lol.
So you guys wanna see somethin badass!? Found my shifter in a picknpull today! I'm definately rockin the ape hanger style shifter atleast for now!
1st gear:
5th gear:
Build Thread:
post #251 of 1162 Old 04-15-2010, 05:09 PM
spife7980
thats just a monkey bar now, you need at least another 6" (twss) to be a true ape hanger
-James
post #252 of 1162 Old 04-15-2010, 07:58 PM
TX-WJ
TX-WJ's Avatar
Should go with a short throw instead, so you can power-shift that beast! . Looking good meng.
David.
(steel blue pearlcoat)
4.7, 242 HD swap, 6" Clayton's, 35" BFG KM2s, F/R chromo'd and locked JK Rubi D44s
TX-WJ is offline
post #253 of 1162 Old 04-15-2010, 08:28 PM Thread Starter
AgitatedPancake
I must say, the NV3500's shift location lends itself well to the WJ's dash. The factory shifter bracket is an issue (mine is removed), but look at where it comes out. 10 minutes with a dremel is all it took to get this far
Fully functioning:
And you guys wanna see long throw? Bahaha
Build Thread:
post #254 of 1162 Old 04-16-2010, 07:58 PM Thread Starter
AgitatedPancake
Painted the valve covers, exhaust manifold, and Y-pipe with a high temp satin black paint, It should look pretty good in the engine bay
Build Thread:
post #255 of 1162 Old 04-19-2010, 05:50 PM Thread Starter
AgitatedPancake
Oh snap I need to update this!
Engine in for *HOPEFULLY* the last time
Angle grinder with a cutoff wheel to the input shaft, I was spinning the output by hand as I went. Came out pretty well, wasn't sure exactly what to expect
Drivetrain clearance, notice I was able to flip Clayton's crossmember upside-down. I'm going to have KILLER underbody clearance with this new setup!
Mmmm lookin sweet
Here's what I had for the mount
I didn't have much height to work with for the bushing, so I lopped off part of the stock bushing (AKA Motor mount...same part). The idea came from Jeeptech over on MC
Then I built a little tray to extend off the front of the crossmember out of 1/4" plate
and voila! It looks like I'm going to have to protect those bolt heads...
Build Thread:
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
QuadraTokn
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
ZJs with the AX-15 five-speed - how many? HMX ZJ Grand Cherokee Forum 5 11-18-2012 11:28 PM
05 WK single speed x-fer case to two speed? tednelson83 WK Grand Cherokee & XK Commander Forum 10 02-18-2007 07:27 PM
Top speed? Arcticcat843 WK Grand Cherokee & XK Commander Forum 33 01-08-2007 10:09 AM
93 318 5-speed?!?!?!? skier123 ZJ Grand Cherokee Forum 5 07-12-2005 01:55 PM
