alwaysHI build thread - Page 7 - JeepForum.com
post #91 of 1528 Old 10-09-2011, 03:48 PM Thread Starter
alwaysHI
2003 WJ
Haha thanks man, I wanna cut the front some, reduce the front bumpstops a tad, for MORE flex
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread -
SOLD
alwaysHI is offline
post #92 of 1528 Old 10-09-2011, 03:50 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I like the way the bumpers are on the WJ... I am not really planning on trimming... hahaha
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #93 of 1528 Old 10-09-2011, 03:53 PM Thread Starter
alwaysHI
2003 WJ
Oh no my bumper is staying like that, the fenders are a different question though, lol.
Build Thread -
SOLD
alwaysHI is offline
post #94 of 1528 Old 10-09-2011, 03:55 PM
snobrdrkid07
WJ for Life
AHHH haha! How could you! LOL! J/K. How much spacer is there from the lip of the fender to the inside of the wheel well?
-Michael-
post #95 of 1528 Old 10-09-2011, 03:57 PM Thread Starter
alwaysHI
2003 WJ
Hahaha. Actually I have no clue. The fender is prolly gonna get 1/2 to 1" trim. Not much, but enough to really FLEX OUT my 32"s.
Build Thread -
SOLD
alwaysHI is offline
post #96 of 1528 Old 10-09-2011, 03:59 PM
Liberator18
1988 XJ Cherokee
Nice jeep!!
Liberator18 is offline
post #97 of 1528 Old 10-09-2011, 04:01 PM
snobrdrkid07
WJ for Life
How is the 3 inch lift working out with 32 inch tires? are they true 32's
I was only planning on running 31... but idk
-Michael-
post #98 of 1528 Old 10-09-2011, 04:06 PM Thread Starter
alwaysHI
2003 WJ
Originally Posted by Liberator18 View Post
Nice jeep!!
Thanks man!
Well its 265/75, 31.8, so I consider it a 32". I had to put a small wheel spacer up front, prolly like 1/8", lol. I needed to do this to clear my front disco pins, NO ONE ever had this problem before for some reason
Other than that, I trimmed my front bumper (pg 3 or 4) to flow better with the fender line, and get the full stuff clearance. At full flex, the front and rear tuck in very nicely, I only extended my front bumpstops because when I wheel, having the option to turn fully lock to lock without hitting the fenders, would be nice without worry.
Build Thread -
SOLD
alwaysHI is offline
post #99 of 1528 Old 10-09-2011, 07:05 PM Thread Starter
alwaysHI
2003 WJ
its amazing what you can find on google or youtube:
looks simple enough to me...unfortunately, i'll have to re-do my bumpstops again, lol.
Build Thread -
SOLD
alwaysHI is offline
post #100 of 1528 Old 10-09-2011, 10:13 PM
85IrocZ-28
I would just slow it down a LOT to make sure your blade doesn't catch and go somewhere you don't want it to. My advice: CUT SLOW. Never force the grinder to cut, let is slowly cut without forcing it.
The fronts are easy, the rear is where it gets a bit sketchy on the WJ. When you cut, you are separating the inner and outer body panels. I recommend welding them back together, or using a factory quality seam sealer to seam the panels back together. I have some ideas for both methods listed in my Iceland Install thread. Of course, you aren't installing flares, but much of the info would be good to look at.
Look at the pics that show how you can create tabs to keep your front inner fender liners up front, and the pics I posted of WJ2000's rear cut/fold/weld. it shows how wide of a gap you end up with when you trim the rears (behind the tires, just above/in front of the rear bumper.
http://www.jeepforum.com/forum/f310/...ll-wj-1072703/
I didn't try to keep my lines very straight because I was covering them with flares, so I just used an air saw. I have helped others cut their though, and they were not installing flares. So we used tape to form the line, and used air grinders to slowly slice a smooth line.
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY ---
85IrocZ-28 is offline
post #101 of 1528 Old 10-09-2011, 10:16 PM Thread Starter
alwaysHI
2003 WJ
I appreciate it man!
Although I'm only planning on trimming the front, since the rear and 32's tuck in very nicely.
You think even one of those 120V air cut off wheels from Harbor freight could do the job?
Build Thread -
SOLD
alwaysHI is offline
post #102 of 1528 Old 10-09-2011, 10:39 PM
85IrocZ-28
yes, easily. Just go slow. I like to have a surface to stabilize my movements. I like to hold it with both hands, and rests my left arm against the fender as I move. That way if the blade does grab, I am braced to not let the cutoff wheel pull me everywhere.
post #103 of 1528 Old 10-09-2011, 11:02 PM Thread Starter
alwaysHI
2003 WJ
Thanks a lot bro! I guess after my mid-terms this weekend, this weekend will be cutting time
Build Thread -
SOLD
alwaysHI is offline
post #104 of 1528 Old 10-11-2011, 12:02 AM
Frank3
Very cool project. I can tell you are having some serious fun with that wj.
Your DIY mode is admirable and inspirational for a newb like me. I want to run out and buy a welding rig.
Frank3 is offline
post #105 of 1528 Old 10-11-2011, 12:45 AM Thread Starter
alwaysHI
2003 WJ
Thanks man, glad I could inspire someone! Haha.
Sucks to have school right now, I would really like to go fishing, and mid-terms are this week..
Build Thread -
SOLD
alwaysHI is offline
I guess its time for my build thread, "Build thread." Escout03 Grand Cherokee General Discussion 81 11-13-2011 12:45 PM
