Akro's 2001 WJ Build.... - Page 167 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > Akro's 2001 WJ Build....
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wdHey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 07-31-2013, 01:03 PM   #2491
thgochenaur
Wheels?
I was just curious as to the exact dimensions of the Fuel rims you have on it. They are 17's but I'm not sure what width and backspacing (and to be honest, I got tired of searching through the thread at about page 45 haha). I have the same lift on it that you had when you started and I love the way your WJ looked at the beginning. And now of course
thgochenaur is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 12:30 PM   #2492
85IrocZ-28
Here are the part number possibilities... I bet it is the first one.
Part # Diam Width Bolt Pattern Bolt Pattern Bore Offset BSM (in)
D53117852652 17 8.5 5X114.3 (5x4.5) 5X127 (5x5) 78.1 14 5.25
D53117852657 17 8.5 5X114.3 (5x4.5) 5X127 (5x5) 78.1 20 5.75
D53117902650 17 9 5X114.3 (5x4.5) 5X127 (5x5) 78.1 1 5
D53117902645 17 9 5X114.3 (5x4.5) 5X127 (5x5) 78.1 -12 4.5
D53117900550 17 9 5X127 (5x5) 5X135 87.1 1 5
D53117900545 17 9 5X127 (5x5) 5X135 87.1 -12 4.5
*Project Yeti* 99 JGC Limited 4.7 w/6.5" Rockkrawler LA & IRO A-arm, Goodyear MTR 35's on MB TKO's, 4.56 Yukon's, Iceland Offroad Bumper/Flares/Sliders, Protofab Rear Carrier, SuperChips, Uniden/Firestick, Flowmaster, Smittybilt 8k Synthetic Line Winch.
My Jeep is Organic - Undercoated in 100% all natural Utah Dirt --- Utah Jeep Crew #49 ~Will
2012 JeepForum GCOTY --- [URL=http://www.jeepforum.com/forum/f197/project-yeti-abominable-wj-1125665/]Project Yeti Build Thread[/URL]
85IrocZ-28 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 12:52 PM   #2493
thgochenaur
Thats awesome, thanks a ton!
Unread 09-06-2013, 11:42 PM   #2494
veiri86
veiri86's Avatar
2003 WJ
This build thread is one of the cleanest threads here.
But this Guy is missed, any news about him?!!
R.I.P ratmonkey
Build thread: http://www.jeepforum.com/forum/f197/...x-wjs-1872002/
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline   Reply With Quote Quick reply to this message
Unread 11-17-2013, 11:27 PM   #2495
TanMan99
Bump
TanMan99 is offline   Reply With Quote Quick reply to this message
Unread 09-14-2014, 09:46 AM   #2496
platinum5.9
platinum5.9's Avatar
2003 WJ
Akro we miss the updates and pictures.... You still have the Jeep?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline   Reply With Quote Quick reply to this message
Unread 11-25-2014, 01:31 PM   #2497
redman333
I really like your jeep man. I'm wanting to run something similar and really like the 33s with the 6.5" lift. I want something that performs well off road but is still very reliable and easy to use daily. Did you need anything else once you lifted it with the Clayton lift. Also how does it perform off-road now.
redman333 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 01:04 PM   #2498
echemali
Where did you get the front and the back bullbar kit?
echemali is offline   Reply With Quote Quick reply to this message
