AEagle's Build - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > AEagle's Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-01-2010, 01:43 PM   #136
AEagle326
Originally Posted by jumbojeep1992 View Post
Mur mur!!!!!!!!!
colby!
brah lets get to wheelin! now that you got ya new leafs
Andrew
1995 Grand Cherokee Orvis Edition
My Build Thread
You can never go wrong with an Orvis.
AEagle326 is offline   Reply With Quote Quick reply to this message
Unread 07-01-2010, 02:19 PM   #137
AEagle326
the subwoofer
tweeter
yellow H3 bulbs
Andrew
My Build Thread
Unread 07-01-2010, 02:38 PM   #138
AEagle326
YouTube - 10" Fusion in my jeep
Andrew
My Build Thread
Unread 07-01-2010, 02:47 PM   #139
Erbo1Kanerbo
weak sauce
ZJ Build thread:
[URL="http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/"]http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/[/URL]
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline   Reply With Quote Quick reply to this message
Unread 07-01-2010, 02:48 PM   #140
Erbo1Kanerbo
in my car if i have a water cup in the cup holder the water will bounce out the cup those sound good for tens tho did you get that at frys? and what song is that i like the way that bumps haha
ZJ Build thread:
Unread 07-01-2010, 09:22 PM   #141
97DCZJ
Weaaaaak. Stick to the performance
I'll get a video tomorrow of my 2 12" Kicker CVRs with a Kicker 750 watt amp, 9XX certified watts
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo: Build Thread; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo: Build Thread; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 09:44 AM   #142
Erbo1Kanerbo
yeah ive got the cvr 15" i took a video and you cant even hear the words the bass sounds like its about to break the speaker on my camera
ZJ Build thread:
Unread 07-02-2010, 11:36 AM   #143
cirame1
i also have 2 kicker comp vr 12's brand new. i have 2 pioneer 760 amps, 1 for each sub. also running a capacitor which i dont even like but it works. For u audio guys... i have a question. First i just changed out my 2 pioneer subs for the 2 cvr's and its not loud i think i wired sumthin wrong. They r on but they dont hit to hard and they cut out wen i turn it up. Im gonna bring it to a local system guy to check it out but anyway, i have 2 2 channel amps... the subs r dual 2 ohms so they have 2 ports on them each... 2 positives and 2 negatives. i am running a channel on an amp to a port on the sub. So 1 amp is wired to each sub and 1 channel to each port. If that makes sense? Is this wired right?? my pioneer 12's hit kinda hard but not that impressive.
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 11:40 AM   #144
Erbo1Kanerbo
im not exactly sure a guy tried to explain it to me and i actaully have this problem somone can chime in to help but you have to the match the ohm rating of your subs with your amp my sub doesnt match with my amp so it cant put out as much power as it should but it is still plenty loud
ZJ Build thread:
Unread 07-06-2010, 10:10 AM   #145
AEagle326
yep, i got it from frys for $100
it hits plenty hard for what it is, and i love it. the song was welcome to the trap house by jelly roll
and for you erbo...
ohms = resistance. lets say you have a 500W amp at 4 ohms. at 2 ohms it produces 750W. less resistance = more power. all you need to do is wire the subs and amp correctly to the same ohm-age (is that a word?) and the amp will evenly split the power.
such as 4 ohm = 250W per sub while 2 ohm = 375W per sub. you might need a thicker gauge wiring depending on the subs, like, 2 12's at 2 ohms i would use no smaller than 4 gauge. if you have 2 15's depending on the power, you might even wanna consider 1/0 gauge wire.
Andrew
My Build Thread
Unread 07-06-2010, 02:51 PM   #146
ratmonkey
R.I.P.
ratmonkey's Avatar
that is the wrong way to do it. you're on your way to a fried sub.
if you want to use one amp per sub. bridge the 2ch outputs properly. if wiring for 1ohm operation your sub should be wired amp pos to pos on one coil, amp neg to neg on other coil, bridge pos to pos and neg to neg on coils. paralell.
if going for 4ohm(not sure why you would unless you've got a cheap amp) bridge the amp, run the amp pos and neg to pos and neg on one voice coil, then jump pos and neg to pos and neg on the sub. series.
btw, incorrect install will void any warranty on the product. don't take it to someone affiliated with kicker.
your instructions for the amp or subs should have very nice drawings explaining this. as it is you're most likely sending signals to each voice coil that are a little bit off, or even in stereo, and it's trying to tear your sub up.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 03:41 PM   #147
Erbo1Kanerbo
thats alot of beat for $100! the guy was telling my that my amp is either a 2 or 4 ohm amp and that my sub is a 4 ohm he said i needed to get a different amp to get all the power out of the sub i wish i knew what i was talking about lol but it beats hard enough to hurt peoples ears in my car so its fine for now that songs sick too btw ive never heard of that guy
ZJ Build thread:
Unread 07-06-2010, 04:49 PM   #148
AEagle326
i know! it was a hell of a deal.
most days everything will accept almost any ohm if you know what youre doing. i've seen crazy systems where its wired down to a 1/4 ohm!
and yeah jelly roll is fresh lol, he's part of lil wytes production stuff.
Andrew
My Build Thread
Unread 07-06-2010, 05:08 PM   #149
lateralus3
1994 ZJ
how are those yellow bulbs in the hellas?
lateralus3 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2010, 05:10 PM   #150
AEagle326
sooo much better. theyre 100W which replaces the stock 55w. theyre so much brighter and they look alot better. and i only spent about $12 on them on ebay
Andrew
My Build Thread
