99 Laredo rear diff plug, can't access? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 99 Laredo rear diff plug, can't access?
Unread 11-16-2013, 11:16 AM   #1
mosinman
After an hour of viewing pictures of rear diffs, I find mine to be very different than others. seems like everyone else has clear unobstructed access to their rear cover and drain plug. Mine on the other hand has the gas tank 3 inches in front of it and I can not see enough of the cover to even locate my drain plug. please do not tell me I have remove my tank to change the cover seal and oil?
mosinman is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 12:15 PM   #2
seymourless
just jack the jeep up to the point before the wheels lift, and you will be good to go!
seymourless is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 01:25 PM   #3
mosinman
thanks
