98 jeep sputters - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 98 jeep sputters
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy/Currie Aluminum Control ArmsIron Rock Offroad products - get them from Kolak!
Unread 09-20-2014, 01:41 PM   #1
98 jeep sputters
A few days ago I started to have this problem. Sometimes when I start the jeep it takes a second or 2 to turn over, sometimes it turns over right.
As well all the time, noe ill drive a few hundred yards down the road and it will start sputtering. I can sometimes drive through it and it won't do it again until car is restarted. The other times I have to pull over and restart the jeep and hope it doesnt happen again or I can drive through it.
Its 98 grand jeep Cheroke, body has 240k miles engine has 150k.
Took it to a mechanic he said fuel injector and fuel pump need to be replaced.
inthepastxx is offline   Reply With Quote Quick reply to this message
Unread 09-20-2014, 09:28 PM   #2
sounds like a good diagnosis if he used a pressure gauge. if you doubt it, go get a loaner gauge from the parts store and check it yourself.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 09:08 AM   #3
try removing and cleaning your intake parts including your IAC..
jb1331 is offline   Reply With Quote Quick reply to this message
