95 Grand Cherokee Laredo Neutral Safety Switch - JeepForum.com
post #1 of 2 Old 05-23-2013, 11:15 AM Thread Starter
Megalor84
1995 XJ Cherokee
Recently my 1995 Jeep Grand Cherokee Laredo has been having difficulty going into park. I can still start it in neutral and my reverse lights still come on, so after researching I found the problem could be my Neutral Safety Switch. While also researching i have seen many locations to where it is but none are shown for around my year of jeep or model (most i have found are for the 4.0). So if someone could tell where to find my NSS on my jeep, or if you have pictures that would be great! I am a do-it yourself-er and I would like to save some money and try to clean, or replace it myself so any information pertaining to my Jeep would be greatly appreciated.
Megalor84 is offline
post #2 of 2 Old 05-23-2013, 02:03 PM
NapsterZJ
Someone correct me if I'm wrong, but last time I did my swap, the NSS is located on driver side of the transmission and is a three prong connector. It's close to the shift linkage if you have 4x4. You're going to lose some fluid, I believe, when you swap it out. Jack up the car on the driver side so you won't lose as much fluid, then top it off when you're done.
http://api.viglink.com/api/click?for...36933585075310
http://api.viglink.com/api/click?<br...13693357159079
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
