6 beep tone - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 6 beep tone
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 07-02-2010, 02:28 AM   #1
rtlaguna
6 beep tone
Does anyone know how to turn this off. I have a 2000 jeep grand cherokee and it randomly sounds off this tone its 2 sets of 3 beeps each. I heard it a scheduled maintanence tone and does anyone know how to turn this off. Thanks...
rtlaguna is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 11:46 AM   #2
JesseOR
Are there any lights flashing? Do you have a VIC? Is there anything flasing on the VIC?
If there is fix it. If its the oil change reminder, reset it.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 01:41 PM   #3
comptiger5000
He's got a WJ, so he definitely has the EVIC (overhead display), which combines the ZJ overhead display and VIC into one unit.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 02:38 PM   #4
rtlaguna
I reset the oil change indicator on the EVIC and after driving for a bit i hear that 6 beep tone again (3 beeps then pause then 3 beeps again) it goes off every so often when driving...
Unread 07-02-2010, 04:40 PM   #5
ras2001wj
Does it flash a low coolant or washer fluid warning?
[B]Rick[/B]
[SIZE="3"][B]2001 WJ Laredo 4.0[/B][/SIZE]
[SIZE="2"][B]2" BB
245/75R16 [/B][/SIZE]
[B]
[COLOR="Red"]Ron [/COLOR][COLOR="White"]Paul[/COLOR][COLOR="White"][/COLOR][/B][COLOR="Blue"] 2012[/COLOR]
"Freedoms Popular"
ras2001wj is offline   Reply With Quote Quick reply to this message
Unread 07-02-2010, 04:45 PM   #6
JesseOR
If its beeping, it should be telling you something it "thinks" is wrong.
-Jesse-
GO DUCKS!
Unread 07-02-2010, 09:58 PM   #7
rtlaguna
No warning lights are present..coolant full and windshield washer full too....my mechanic couldnt figure out what it is either. Thanks for the replys
Unread 07-16-2010, 11:35 AM   #8
rgbeard
I'm having the warning tone problem with our '95 cherokee. Warning tone will sound constantly with no warning displaying. Usually will go for about 3-4 minutes and then just quit.
Then I'll get the random "coolant low" or "turn signal" tones. Coolant level is good. All bulbs checked to make sure correct part and proper voltage.
It's getting to where I can almost here the tone in my sleep.
Any help here would be greatly appreciated.
rgbeard is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 01:18 PM   #9
PurpleZJ
lol i dont know whats causing that but man i know how annoying that thing can get. my washer fluid was low for like a week or two when i finally was like FINE B***** i'll put more fluid in you if you just shut up haha. good luck gettin it fixed
1996 ZJ- 4.0, [COLOR="Purple"]AX-15 5SPD/NP242[/COLOR], RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
[CENTER][COLOR="Blue"]RIP Troy (bigbluezj94) you wont be forgotten[/COLOR]
[COLOR="Purple"]December 2010 GCOTM[/COLOR]
5spd ZJ Club Member 001
[/CENTER]
[QUOTE=bddisi;6376248]Glad you are ok. If you were a cat, you would be down to 8.:D[/QUOTE]
[QUOTE=Greengc4x4;10782815]Everything looks great, Hellen Keller! :D[/QUOTE]
[QUOTE=rritch;10960201]plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:[/QUOTE]
[CENTER][COLOR="Purple"]RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11[/COLOR][/CENTER]
PurpleZJ is offline   Reply With Quote Quick reply to this message
Unread 07-17-2010, 12:12 AM   #10
ras2001wj
Also, a loosely shut lift gate or door (or any switches involved) can cause the beep.
[B]Rick[/B]
[SIZE="2"][B]2" BB
[B]
"Freedoms Popular"
Unread 07-17-2010, 01:31 AM   #11
rtlaguna
I finally got rid of that 6 beep tone...I noticed on the VIC when the beeps first went on a quick flash of the low coolant went on and off instead of it just staying put at low coolant. I checked my coolant reserves and it was just a tad bit under the full. So I filled it about an inch above the full line and what da ya know it stops beeping.....
Unread 03-18-2011, 10:41 PM   #12
mnesta
my wj's doin the same thing excpet about every five minutes it will just randomly beep, any help?and also i just put new leds in the gauges could that hav anything to do with it?
mnesta is offline   Reply With Quote Quick reply to this message
Unread 03-20-2011, 05:03 PM   #13
mnesta
nevermind figured out it was the washer fluid it just goes away really fast
Unread 06-18-2011, 10:57 PM   #14
Davedee
2005 KJ Liberty
2005 liberty/cherokee in UK 6 beep tone
Hi I am also getting a 6 beep tone on my KJ. When driving the 6 beep tone rasndomly activates on the evic it quickly flashes "Hood Open" I haver checked and the hood is tight shut. Does anyone know where the sensor is for the hood or how to disable the tone. i have read elsewhere that there is not a hood open warning on the evic but thats what the dispaly shows. Please help!
Davedee is offline   Reply With Quote Quick reply to this message
Unread 07-17-2012, 02:42 PM   #15
dwayne1983
I'm having this same issue with my 2000 grand Cherokee. It's quiet annoying and I have to get this looked at. I think it has something with the jeep needing service. I will update this thread if I come up with anything in the next few days.
dwayne1983 is offline   Reply With Quote Quick reply to this message
