5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 11-08-2010, 09:03 PM   #121
Spike300
Um wow, monster axles
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 09:10 PM   #122
MoonyJohn
Mallcrawler
MoonyJohn's Avatar
Coming along nicely man, is that a 14 bolt rear or a dana 60? Im not really familiar with axles. Either way, doesnt seem like hes going to break anything. Hes pretty lucky to have you working on it..
MoonyJohn is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 09:32 PM   #123
Bama_WJ
Looks to be a 14b. Any chance of a shave?
Looking awesome though!
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 09:44 PM   #124
mtnmarc
dang, im getting the rear 4 link kit from ruff stuff and it has that truss. i never really thought about shaving it to get it closer, but i might have to do that. looks good
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 10:38 PM   #125
ratmonkey
R.I.P.
ratmonkey's Avatar
Their truss is HUGE! Running it as is will give you terrible numbers.
Have you thought about sinking the link mounts into the truss?
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 11:12 PM   #126
AgitatedPancake
Thanks Spike!
John, it's a 14 bolt, and thanks! With the 37"s he definately shouldn't be breaking anything.
Daniel, we're looking into a massive shave on it. Turning it into an 11 bolt, but adding a few holes back in.
Marc, the truss is wayyy too big for any sort of reasonable numbers in stock form, it NEEDS to be cut down. Thanks for the compliments!
Rat, I'm going to have to take a good look at it tomorrow but i might consider it, the tnt upper link mounts seem kinda...mediocre so extra reinforcement by sinking it in could be a good thing!
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 11-09-2010, 07:05 PM   #127
AgitatedPancake
The guys at TnT seem to like to cut it tight with being able to squeeze bolts into place. I had to hammer this peice of plate away a little bit so I could get the lower control arms bolted in. I would have been PISSED to find this out with the crossmember bolted up in place under the truck.
Did some final grinding prep work on the truss to get it fitting how I want, and mocked the coil buckets into place...movin right along!
Got them all together though! Lookin sexxay. I'm actually going to build up the entire suspension in mock form like this outside of the truck, all tacked and bolted together. Easy as pie haha!
Unread 11-10-2010, 06:28 PM   #128
AgitatedPancake
Oh snap! I spent the early part of the afternoon taking the surface rust off all the things I'm working with, then I tacked all the brackets in place and set up the suspension. I'm going to burn the upper link mount into the truss, but the truss is coming back off so I can weld it in two pieces and weld the tubes to the 3rd as planned. Sitting with about 8.5" vertical seperation, and the LCA bolt holes just a little below axle centerline.
Next time I work on it everything gets finish welded! And I must say, having the TnT crossmember has been so nice, allowing me to build the suspension outside of the truck instead of under it!
Unread 11-10-2010, 06:30 PM   #129
squashman702
1994 ZJ
Is that a Millermatic 180?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 06:36 PM   #130
AgitatedPancake
175, and aaaaaallllll my buddies are red box fans hahaha!
Unread 11-10-2010, 06:52 PM   #131
squashman702
1994 ZJ
Gotcha. I've used a Millermatic 135 some and I really like that. Thinking about going for the 211 because of the 115v/230v flexibility. Is the 175 good enough for everything you want to do with it?
Think Twice Garage
Unread 11-10-2010, 06:55 PM   #132
GraKee99
Rapist Wit
GraKee99's Avatar
Look good as usual.
I have a 250 and like it a lot.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 06:56 PM   #133
AgitatedPancake
Yeah the 175 definately has the power for everything I've wanted to do. In my next couple of updates you'll see me really pushing it's abilities, and I'll do weld pics to show the results. The inner truss and lower control arm mounts are both 3/8" so I'm going to have it cranked. Also when I'm welding the tubes to the cast I'll have the heat cranked up as well.
I never have an issue with the duty cycle either, I need to cool down personally more often than the machine does hahaha!
*EDIT* Quick response Brian haha, thanks!
Unread 11-10-2010, 07:24 PM   #134
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Horrible welds on this axle bracket
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 07:45 PM   #135
AgitatedPancake
Hahaha I think I had some porosity on those truss welds too...it's almost as if I can see right through them!
