5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-13-2010, 09:40 PM   #46
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Any reason the hood vents are on backwards?
forces air in, instead of sucking it out.... i did it within the 1st week i had the jeep, i also cut out the drip trays underneath, so they are straight through.
the heat POURS out of them when im parked.
greg, looks GREAT!
refresh my memory, how do the tnt cossmembers attach to the frame?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 07-13-2010, 09:55 PM   #47
AgitatedPancake
Thanks errybody! They're actually 1/4" thick haha
Andy, it's bolt on, 4 bolts per side for the front and 2 or 4 per side for the rear. In the front they actually have you weld on some extra reinforcing plates for the additional 2 bolt holes per side. In the last picture you can see the hole i had to cut in the bottom of the stiffener for the threaded nutsert in the frame rail, I figure it's the locator for the rear crossmember. I know you'd probably prefer to have them welded on, but you have to unbolt the front crossmember to do any sort of tranny/tcase work and I don't know a way around that.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 07-14-2010, 08:29 PM   #48
AgitatedPancake
Sooooo....
I got the passenger side together today
Andy, Nice front control arm mounts
Unread 07-14-2010, 10:25 PM   #49
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
do they use the factory nut serts?
looking good
Unread 07-14-2010, 10:38 PM   #50
AgitatedPancake
I haven't looked in detail at the mounting of the rear crossmember, and it seems you only have that nutsert on one side so I guess it was for a factory skid plate or something. Looks like there's going to be drilling involved with the rear installation from the looks of things though. I may hold off on installing the rear crossmember for now, as you said a while back it would be in teh way for swapping the tcase when the time comes, and I have no need for it to be installed until then.
Unread 07-15-2010, 09:54 AM   #51
ssss4
nice jeep
ssss4 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 10:12 AM   #52
squashman702
1994 ZJ
greg, looks GREAT!
Not sure how effective this is. I think the vent openings are too small to make much of a difference or create any ram air effect.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 09:45 PM   #53
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
well, deffinatly not for increaseing power.... i still think it forces in agood amount of cooler air.
i am not worred about it at this point... ill proably buy a reguler hood and sell the 5.9 hood....
Unread 07-16-2010, 12:46 AM   #54
AgitatedPancake
I'd say rock the 5.9 hood man, I've always liked the vents
Alright, I have another way to upload pics, so I got some for ya guys!
First off, I think I finally killed off the rest of the ******* wasps. Andy had told me about (and I had seen for myself) that wasps had taken a liking to his jeep where he had it parked. I *thought* they were pretty much gone when I brought it back, but I kept having a random few buzz in and out of the garage so I went on a hunt...they liked your ******* cowl man!
I killed the **** out of those things! Bigass nest/hive they had going though!
Sorry about the blurry pics, I think this old camera has just about had it. It's a nikon digital that I'd say is a solid...8-10 years old. I've dropped it off the workbench at least a dozen times
These are the inner plates that add 2 bolt holes per side to the front mounting. The bolts are probably 5/8-3/4" thick. The kit also came with bolts to run horizontally though the frame rails, we'll see aboot those. I welded the bracket on pretty damn solid.
LCA mount be gone...gatta love plasma cutters
Aaand a nice blurry longarm shot to finish it off
Unread 07-16-2010, 12:59 AM   #55
bigbluezj94
1994 ZJ
what kind of links are you going with? im redoing mine. gonna go 3 link up front and push it out 2" or so with all JJs... gonna redo the rear too... hopfully lift the tank enough into the cab to push the back out 2-3"s as well with all new links... agian JJs. know anyone that wants clayton rear links? already have the front sold.
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 01:15 AM   #56
AgitatedPancake
This is treks offroad (TNT) longarm kit. The front lowers are 2" .250, and it does the radius arm like everyone else. Props on goin with the 3-link, my WJ's going to get it eventually also. As for the rear, it's a double triangulated 4 link. It's looking like I'm going to have to do some gas tank work when the time comes for the 14 bolt also, but I already have na idea. Before Andy left we crawled around under it and chatted about things, well while we were at it I went and looked at the gas tank. It looks like it might not be all that difficult to push the tank back towards the rear of the ZJ a few inches. When I did the gas tank raise on my WJ I also pushed it back a lil, helps everything fit haha.
Unread 07-16-2010, 01:28 AM   #57
bigbluezj94
1994 ZJ
hell yea man. thats good to know about the tank. i havent had time to even look at bigblue lately. just got done moving into a new house so things have been a bit hectic. im tuned in tho man.
also do they just not have the zj kit online or is it ideally the xj kit? i dont see nothin for a zj but the unibody stiffeners.
[/color]
[/CENTER]
Unread 07-16-2010, 01:35 AM   #58
AgitatedPancake
For sure man, we have a lot of fun in store for this ZJ hehe! Also, I'm pretty sure it's a production item, it just might not be on their website. I will say I'm very impressed with then engineering of the entire kit. A lot of design time went into everything and it shows.
Unread 07-16-2010, 02:53 AM   #59
ratmonkey
R.I.P.
ratmonkey's Avatar
So there's no way to drop the crossmember for service without taking the arms with it?
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 10:28 AM   #60
AgitatedPancake
The one big downside to this kit, I really wish there was a way around that
