5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 23 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
Unread 03-18-2011, 08:08 PM   #331
dlvsdh
looking sexy . quick q do you know if the hp d60s are wider then th hp d44s that come in the same ford
95, zj, ORVIS, Iro critical path, 1 tons, 35's etc.
dlvsdh is offline   Reply With Quote Quick reply to this message
Unread 03-18-2011, 08:36 PM   #332
AgitatedPancake
Thanks! I feel like the ford HP44's were 65-67" wide, this is 69.5" I believe
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 03-18-2011, 09:01 PM   #333
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Originally Posted by dlvsdh View Post
if he breaks that i would hate to see the rest of the steering after whatever he does to break that.
based on what we have planned for the rest of the steering, id would much rather see the rest of the truck... all i do know is, i would not be good.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 03-19-2011, 01:12 AM   #334
mtnmarc
My 79 hp44 is 69 inches wide I believe. Either 68 or 69.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline   Reply With Quote Quick reply to this message
Unread 03-19-2011, 01:26 AM   #335
dlvsdh
true cant wait to see her done well jeeps are never done
Unread 03-22-2011, 12:55 PM   #336
FleshEater
2014 JK Wrangler
This thing is going to be SIC when it's done!
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline   Reply With Quote Quick reply to this message
Unread 04-06-2011, 11:40 PM   #337
freakinheep89
absolutely amazing work so far greg. I think i would **** a chicken if anything you have made ever actually broke.
TJ-
[SIZE="1"][B]95 ZJ 5.2[/B]- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.[/SIZE]
[QUOTE=slayercr23;12630497]How would i go about Stroking it?[/QUOTE]
freakinheep89 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2011, 03:55 PM   #338
AgitatedPancake
Woooow! Somehow I missed these responses! Thanks a lot guys, I appreciate the compliments! I've had this project on the back burner as I built my 9", but I'm now waiting for a few parts so I'm back to hammering out this thing. Schools almost over, and I'm fully motivated...it's go time
A little rewind from the work before I put it on hold: The gears came back from cryo and I installed them...to find out the pattern wasn't acceptable. Apparently on the final assembly I accidentally seated the inner pinion race an extra couple thousandths, which is what changed the pattern. It really frustrated me, and happen as things started to come together for the 9", so I decided to stop workin on this for a little and focus on that.
Fast forward to yesterday, I blew the front axle back apart. Carrier came back out, pinion, pinion seal, and the inner bearing race all had to be removed so I could adjust the shims.
Today I measured out all my pinion shim choices and chose a combo that added...like 3 thousandths IIRC? Bingo
Now it's time to get the final assembly going hehehe!
Unread 05-10-2011, 06:39 PM   #339
mtnmarc
Final assembly on the while jeep?!
Unread 05-10-2011, 10:54 PM   #340
AgitatedPancake
Hell to the yeah man! Seeing that good pattern really motivated me today, I installed the axleshafts, spindles, packed the wheel bearings with grease, put them and the hub seal together, installed the hub/rotor combos, and then installed the calipers and new pads. That's badass, quite a few items off the checklist!
Unread 05-11-2011, 10:34 AM   #341
AgitatedPancake
Oops, looks like I forgot the pic of doing said tasks yesterday :P.
Heres my checklist to call the front end 100% done:
Brake lines
Lengthen tie rod
Lengthen drag link
Final weld track bar bracket to frame
Finish diff cover protection
Install driveshaft
Install springs
Install shocks
Double check all suspension bolts.
I'm thinkin 2 days of hardcore work and I might be at that stage, which means I can assemble his wheel/tire combos and let the front end off the jack stands for the first time
Unfortunately, today won't be one of those days, as I have one of my final presentations in school this afternoon
Unread 05-11-2011, 11:01 AM   #342
1stblack97ZJ
damn that thing is sexy...
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline   Reply With Quote Quick reply to this message
Unread 05-11-2011, 01:34 PM   #343
mtnmarc
beast!
i cant wait to see this thing done.
red, yellow and white. any significance to those colors?
Unread 05-11-2011, 02:11 PM   #344
GraKee99
Rapist Wit
GraKee99's Avatar
Originally Posted by mtnmarc View Post
beast!
I'm guessing because he is in the US Marine Corps and there flag has gold, red and white in it. Yellow is close to gold.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2011, 07:28 PM   #345
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i never thought of that, GREG!! REPAINT THE JEEP! I DONT CARE WHAT COLOR, FOR ALL I CARE, MAKE IT PINK!!!
j/k
