5.9 Andy's 1 Ton ZJ Build "American Standard" - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > Grand Cherokee General Discussion > 5.9 Andy's 1 Ton ZJ Build "American Standard"
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 06-24-2010, 08:30 PM   #16
AgitatedPancake
Nah I'm not ready for the jeep quite yet man, the blue submarine needs some lovin now. And when I'm workin on your jeep, it's going to be in the blue sub's spot hehe. I gotta get mine ready for my next trip! Gotta pull the tcase and cut the input shaft, with a few other things. There wasn't enough gear oil coming out to tell the color, I'll find out when I dive into it. I figured better to leave it sealed for now.
To contact me, email Greg@Frobotfab.com
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake's Youtube Channel
AgitatedPancake is offline   Reply With Quote Quick reply to this message
Unread 06-24-2010, 08:34 PM   #17
Spike300
WOW cant wait to see this build. I bet it going to be killer!
[url]http://www.jeepforum.com/forum/f197/camo-beast-975063/[/url]
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -[COLOR="Red"]Optima[/COLOR] -E3 plugs-[COLOR="DarkGreen"]Cu[/COLOR]st[COLOR="DarkGreen"]om[/COLOR] Pa[COLOR="DarkGreen"]in[/COLOR]t-Amsoil-Addco Front and Rear-polyurethane bushings
[B]To be installed[/B]: RE gen2 discos, military battery terminals
[B]To be rebuilt:[/B] HP30
[B]To be received:[/B]
[B]To be paid for:[/B]
[B]Next on the list:[/B] complete redo of brakes and
lines
[B]Needed:[/B] fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2010, 09:36 PM   #18
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
the best is yet to come.... but it is a supprise... so be patient.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 06-28-2010, 06:20 PM   #19
Spike300
I will good luck, And thank you for serving
lines
Unread 06-28-2010, 07:59 PM   #20
Bama_WJ
Can you really shave a 14b that much?
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Trifecta tuned and 37+ MPG
Wife's Jeep: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers, 3" Gibson Cat-Back
North Alabama Jeep
42RE Vent Mod - Seal your transmission!
YouTube. - My Video Channel
Facebook - Wheeling Pictures/Videos
The Jeep Wave. Bringing it back.
Bama_WJ is offline   Reply With Quote Quick reply to this message
Unread 06-28-2010, 09:03 PM   #21
AgitatedPancake
Well you can take about 2" off to the bottom of the ring gear, but we're planning a mohawk so the sides will be cut that high, then step down to clear the ring gear.
Kiiiinda like this
Unread 06-28-2010, 09:12 PM   #22
Greengc4x4
Doesnt leave much room for diff fluid. lol
Greengc4x4 is offline   Reply With Quote Quick reply to this message
Unread 07-03-2010, 10:45 AM   #23
ratmonkey
R.I.P.
ratmonkey's Avatar
thats why you build the custom cover with a higher fill port.
the solid cover on my 8.8 has me able to put in nearly 5qts.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-04-2010, 02:41 PM   #24
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
thats the plan... also, when you do this, you have to make sure your breather will still work properly with the higher level of fluid.
Unread 07-04-2010, 04:12 PM   #25
ratmonkey
R.I.P.
ratmonkey's Avatar
i tubed it out of the useless abs sensor hole on the 8.8.
Unread 07-04-2010, 04:29 PM   #26
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
good idea.
im thinking that the angry flapjack might have to drill a hole in the cast housing and then insert a breather or something.
Unread 07-04-2010, 04:35 PM   #27
bigbluezj94
1994 ZJ
i drilled a hole in my SOLID cover for the breather. It still leaks tho when it gets hot. Gonna put a bit less fluid when i change it
[CENTER]94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
[COLOR="RoyalBlue"][B]BigBlue build 33s, 6in lift and short arms[/COLOR][/B]
[B][U][URL="http://www.jeepforum.com/forum/showthread.php?t=679496"]http://www.jeepforum.com/forum/showthread.php?t=679496[/URL][/U][/B]
[COLOR="RoyalBlue"][B]BigBlue build 3/4 ton axles, LAs, 37s [/COLOR][/B]
[B][U][url]http://www.jeepforum.com/forum/showthread.php?t=818891[/url] [/U][/B]
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
[color=Black][center][size=4][font=Showcard Gothic][color=Black][url="http://groups.jeepforum.com/Built_Not_Bought"][color=Black]Built Not Bought #033[/color][/url][/color][/font][/size][/center]
[/color]
[/CENTER]
bigbluezj94 is offline   Reply With Quote Quick reply to this message
Unread 07-04-2010, 10:58 PM   #28
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ill keep that in mind.
Unread 07-04-2010, 11:44 PM   #29
soul_Less
1994 ZJ
Originally Posted by AgitatedPancake View Post
Theres easier ways to get the doors off a Jeep.
Subcribed.
soul_Less is offline   Reply With Quote Quick reply to this message
Unread 07-05-2010, 09:20 AM   #30
sadass
sadass's Avatar
Nice Job AgitatedPankake ,Thanks! That is an awesome thing you are doing for Andy, I look forward to the build.
And I want to thank Big blue and Andy any any other Service members /Vets that maybe reading this for your Service to our Country .
If you can find the time to fit in yet another forum guy's. Check out Military Jeepers.com
Be Safe fellas
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline   Reply With Quote Quick reply to this message
